    Set current to zero?
    805
    • tenajaundefined
      tenaja @garyd9
      @garyd9 , Yes, that is what I meant. This is not an axis that is "homed"--it is rotary, which needs to freewheel at times. So, how do I do that? I'm getting a "axis not homed" error or something like that.
      Should I just issue a G92 to set it to zero right before I turn it back on?
      Thanks again!
      • tenajaundefined
        tenaja @fcwilt
        @fcwilt said in Set current to zero?:
        turn individual stepper drivers off with M84
        That did it, now I need to figure out how to "home" an axis that is not homed, and can not be homed.
        • Vetiundefined
          Veti @tenaja
          @tenaja said in Set current to zero?:
          use G92 to set a position
          https://duet3d.dozuki.com/Wiki/Gcode#Section_G92_Set_Position
          tenajaundefined 1 Reply Last reply Reply Quote 0
          • tenajaundefined
            tenaja @Veti
            @Veti said in Set current to zero?:
            G92
            I did that, from the command line (top of DWC web page), and it did not work.
            Perhaps G92 after a M913?
            coming back after Duet restart (because it always loses connection)
            Yes!
            M913 Y100 does not turn power back on... It's still freewheeling after that....but the commands do work. (M913 then G92)
            Thanks, I'm back in business!
            Vetiundefined tenajaundefined dc42undefined 3 Replies Last reply Reply Quote 0
            • Vetiundefined
              Veti @tenaja
              whats the exact G92 command you issued?
              • tenajaundefined
                tenaja @tenaja
                I guess the only question left is how you cancel an M84 (Stop Idle Hold), without issuing a move command? Or to put it another way, how do you Resume Idle Hold?
                • tenajaundefined
                  tenaja @Veti
                  G92 Y0
                  • fcwiltundefined
                    fcwilt @tenaja
                    What is the letter assigned to this axis and what G92 command did you issue?
                    Issuing a G1 command for that axis should turn the driver back on - is there some reason you cannot do that?
                    • Vetiundefined
                      Veti
                      I just tested it and the axis became homed
                      • tenajaundefined
                        tenaja @Veti
                        @Veti
                        Thanks, as I pointed out in Post #8, it does work if you put it in the gcode. But you have to do it in sequence, with the M913 first.
                        And, the motor does not have power, even though you issued an M913 Y100. ("Set motor percentage of normal current", to 100%)
                        • Vetiundefined
                          Veti @tenaja
                          @tenaja
                          try a small movement G0 Y0.1 followed by G0 Y0
                          • tenajaundefined
                            tenaja @Veti
                            @tenaja
                            As expected, that will do it. It seems odd there's a way to power-down a motor, but not a "safe" way to power it back up. ("Safe" = no-motion).
                            I would like to know how to restore it safely, for trivial/future reasons, but for my current application, my needs are met.
                            I really appreciate all of the help provided.
                              dc42 administrators @tenaja
                              Any movement command will turn it back on. RRF 3.3 (for which we will soon release a beta) also supports M17 to turn on motor current.
                              oozeBotundefined tenajaundefined 2 Replies Last reply Reply Quote 0
                              • oozeBotundefined
                                oozeBot @dc42
                                @dc42 said in Set current to zero?:
                                I'm very interested in testing this as I believe it will really help when releasing the stepper brake on our z-axis.. currently, we have to slightly move the z-axis to energize the steppers to keep the gantry from dropping.
                                • tenajaundefined
                                  tenaja @dc42
                                  Thanks...
                                  Will a "relative" move of zero, like G1 Y0 do it? Or is physical motion the only way to get power back on?
                                    If you work out your step resolution you could have a move of exactly a single motor step.
                                      dc42 administrators @oozeBot
                                      @oozeBot said in Set current to zero?:
                                      I expect to provide an unofficial 3.3beta tomorrow.
