    IMPORTANT ISSUE with bed temp controller
    Firmware developers
    fire risk
    8
    86
    4.1k
    • jrocklandundefined
      jrockland @fcwilt
      @fcwilt not from my computer. I need the geek squad to get on their computer for that.
      also lot of information is confidential so I can only quick fix manually from the firmware user page and can't copy paste anything.
      • Luke'sLaboratoryundefined
        Luke'sLaboratory @Veti
        @jrockland
        However - some explanation on why the config.g is useful here - it helps diagnose some other issues from weird or overriding settings.
        Have you ran a new PID tune with the update to 3.2? The heater tuning uses feedforward algorithms to improve performance and may be one of the reasons for not heating fast enough.
        Luke
        http://lukeslab.online
        jrocklandundefined 1 Reply Last reply Reply Quote 0
        • engikeneerundefined
          engikeneer
          @jrockland you can see everyone is very interested with the amount of people replying!
          First thing the developers will need to know to investigate will be some steps to recreate the issue. Eg. Your config file now, and your config file & firmware version from when it worked (3.1.1?).
          There are many commands in your config that could impact this (e.g. M143, which IO port you're using etc).
          i3 clone with a bunch of mods
            jrockland @Luke'sLaboratory
            @Luke-sLaboratory Yes, I ran a pid tuning on everything since the new format seem to work much better and did improved stability.
            I gave more info in a response (not sure how to edit my post) about m307, how the bed is connected and which port it use. not sure if anything else is relevant.
            Luke'sLaboratoryundefined 1 Reply Last reply Reply Quote 0
              jrockland @engikeneer
              @engikeneer M143 is at 150.
              latest firmware used was 3.1.1 stable.
              it also happen on my other machines at least once, on hot ends. I disregarded as I was around and was busy so I just forced reset and get it going again.
                Luke'sLaboratory @jrockland
                @jrockland
                I know that sometimes the relay/SSR used can have unintended behaviors if not properly accounted for, they can "latch" on if too warm or if not properly configured. If you're able to provide part #'s for the relays and some pictures of wiring, etc, That could help evaluate the issue.
                Luke
                  jay_s_uk
                  well are you running in SBC mode or standalone for starters?
                    jrockland
                    G90
                    M83
                    M569 P0.1 S1
                    M569 P0.0 S1
                    M569 P0.2 S0
                    M569 P0.5 S1
                    M569 P0.3 S1
                    M569 P0.4 S1
                    M584 X0.0 Y0.1 Z0.3:0.4:0.5 E0.2 U0.4 V0.5 P5
                    M671 X149.0:-15.0:305.0 Y-70:180.0:180.0 S50.0
                    M350 X16 Y16 Z16 U16 V16 E16 I1
                    M92 X88.50 Y88.50 Z2085.3 E435.00 U2085.3 V2085.3
                    M566 X600.00 Y600.0 Z30.00 U30.00 V30.00 E10000
                    M203 X8000.00 Y8000.00 Z300.00 U300.00 V300.00 E10000.00
                    M201 X650.00 Y650.00 Z60.00 U60.00 V60.00 E6000.00
                    M906 X400 Y800 Z400 E400 U400 V400
                    M208 X0 Y0 Z0 U0 V0 S1
                    M208 X280 Y140 Z120 U120 V120 S0
                    M574 X1 S1 P"!io6.in"
                    M574 Y1 S1 P"!io0.in"
                    M574 U1 S1 P"!io2.in"
                    M581 T0 U1 S1 C0
                    M558 P5 C"!io7.in" I1
                    G31 P100 Z2.40
                    M308 S0 P"temp0" Y"thermistor" A"HOT END" T100000 B4138
                    M308 S1 P"temp1" Y"thermistor" A"BED CORE" T100000 B4138
                    M308 S2 P"temp3" Y"thermistor" A"BED ACTUAL" T100000 B4138
                    M950 H0 C"out1" T0
                    M307 H0 R3.444 C172.8 D4.15 S1.00 V24.3
                    M950 H1 C"!io3.out" T1
                    M307 H1 R0.310 C706.9 D6.34 S1.00
                    M140 H1
                    M570 H1 P360
                    M143 H1 S150
                    M950 F0 C"out7" Q500
                    M106 P0 S0 H0 T100
                    M950 F3 C"out8"
                    M106 P3 S127.5
                    M950 F2 C"out9"
                    m106 P2 S255
                    M563 P0 S"REPLICATOR" D0 H0 F1
                    G10 P0 X0 Y0 Z0
                    G10 P0 R0 S0
                    jay_s_ukundefined Vetiundefined 2 Replies Last reply Reply Quote 0
                      @Luke-sLaboratory Yea it is the first thing I looked at. wasn't the case.
                        jrockland @jay_s_uk
                        @jay_s_uk sadly SBC mode.. I know it isn't the most stable but it is the only effective way for us.
                          jay_s_uk @jrockland
                          @jrockland said in IMPORTANT ISSUE with bed temp controller:
                          seems odd to invert an output
                          and you have no frequency set which means that SSR/relay would be running way faster than is good for it
                          jrocklandundefined Luke'sLaboratoryundefined 2 Replies Last reply Reply Quote 0
                            jay_s_uk @jrockland
                            Can you provide the contents of /var/logs/syslog for the day it happened on?
                            May be something of interest in there...
                              jrockland @jay_s_uk
                              @jay_s_uk not a programmer here.. but I figure it is inverted because of the "!" ? Ill check that out.
                                Luke'sLaboratory @jay_s_uk
                                @jay_s_uk @jrockland
                                Wait - this means that to have the bed be "off" - the duet needs to run with out3 "on"
                                so if the duet doesn't send signal (or if a wire gets cut, loose, etc) the relays will be turned on?
                                Otherwise, yeah, the frequency thing is definitely a non-recommended setup as well - Could @jrockland confirm that they're SSR's and not "traditional" relays?
                                Luke
                                jrocklandundefined 1 Reply Last reply Reply Quote 1
                                  @jrockland Yes - the ! is to invert the signal, in this case, for the duet to turn "on" the expected output, it needs to turn "off" the on-board output.
                                  Luke
                                    jay_s_uk
                                    which definitely isn't very fail safe...
                                    • Vetiundefined
                                      Veti @jrockland
                                      those settings rre incorrect.find the correct beta value in the thermistor documentation.
                                      i would suggest that you connect it to out0
                                      jay_s_ukundefined Luke'sLaboratoryundefined jrocklandundefined 3 Replies Last reply Reply Quote 1
                                        @jay_s_uk Agreed, this makes me anxious
                                        Luke
                                          jay_s_uk @Veti
                                          @Veti said in IMPORTANT ISSUE with bed temp controller:
                                          doesn't really matter in this case as its using an external relay
                                            @Veti Depending on the actual thermistors they could be, but having all 3 be identical is suspect for sure! - would need validation to be 100% sure. For relay outputs, any output is fine, I prefer to use a connectorized output for my SSR ones.
                                            Luke
