    IMPORTANT ISSUE with bed temp controller
    Firmware developers
    fire risk
    8
    86
    4.0k
    • Luke'sLaboratoryundefined
      Luke'sLaboratory @jrockland
      @jrockland Yes - the ! is to invert the signal, in this case, for the duet to turn "on" the expected output, it needs to turn "off" the on-board output.
      Luke
      http://lukeslab.online
      jrocklandundefined 1 Reply Last reply Reply Quote 0
        jay_s_uk
        which definitely isn't very fail safe...
        Luke'sLaboratoryundefined 1 Reply Last reply Reply Quote 0
        • Vetiundefined
          Veti @jrockland
          @jrockland said in IMPORTANT ISSUE with bed temp controller:
          M308 S0 P"temp0" Y"thermistor" A"HOT END" T100000 B4138
          M308 S1 P"temp1" Y"thermistor" A"BED CORE" T100000 B4138
          M308 S2 P"temp3" Y"thermistor" A"BED ACTUAL" T100000 B4138
          those settings rre incorrect.find the correct beta value in the thermistor documentation.
          M950 H1 C"!io3.out" T1
          i would suggest that you connect it to out0
          jay_s_ukundefined Luke'sLaboratoryundefined jrocklandundefined 3 Replies Last reply Reply Quote 1
            Luke'sLaboratory @jay_s_uk
            @jay_s_uk Agreed, this makes me anxious
            Luke
              jay_s_uk @Veti
              @Veti said in IMPORTANT ISSUE with bed temp controller:
              doesn't really matter in this case as its using an external relay
                Luke'sLaboratory @Veti
                @Veti Depending on the actual thermistors they could be, but having all 3 be identical is suspect for sure! - would need validation to be 100% sure. For relay outputs, any output is fine, I prefer to use a connectorized output for my SSR ones.
                Luke
                • Vetiundefined
                  Veti @Luke'sLaboratory
                  @Luke-sLaboratory
                  B4138 thermistors have not been used in years. so its very unlikely that its correct.
                  Luke'sLaboratoryundefined jrocklandundefined 2 Replies Last reply Reply Quote 1
                    @Veti Fair, I have some in a cabinet somewhere as a backup to my backup's backups. 😄
                    Luke
                    • jrocklandundefined
                      jrockland @jay_s_uk
                      @jay_s_uk Jan 14 00:00:09 raspberrypi rsyslogd: [origin software="rsyslogd" swVersion="8.1901.0" x-pid="388" x-info="https://www.rsyslog.com"] rsyslogd was HUPed
                      Jan 14 00:00:10 raspberrypi systemd[1]: man-db.service: Succeeded.
                      Jan 14 00:00:10 raspberrypi systemd[1]: Started Daily man-db regeneration.
                      Jan 14 00:02:30 raspberrypi DuetControlServer[14574]: [warn] Lost connection to Duet (Board is not available (no header))
                      Jan 14 00:02:30 raspberrypi DuetControlServer[14574]: [info] Connection to Duet established
                      Jan 14 00:04:45 raspberrypi rngd[377]: stats: bits received from HRNG source: 480064
                      Jan 14 00:04:45 raspberrypi rngd[377]: stats: bits sent to kernel pool: 424096
                      Jan 14 00:04:45 raspberrypi rngd[377]: stats: entropy added to kernel pool: 424096
                      Jan 14 00:04:45 raspberrypi rngd[377]: stats: FIPS 140-2 successes: 24
                      Jan 14 00:04:45 raspberrypi rngd[377]: stats: FIPS 140-2 failures: 0
                      Jan 14 00:04:45 raspberrypi rngd[377]: stats: FIPS 140-2(2001-10-10) Monobit: 0
                      Jan 14 00:04:45 raspberrypi rngd[377]: stats: FIPS 140-2(2001-10-10) Poker: 0
                      Jan 14 00:04:45 raspberrypi rngd[377]: stats: FIPS 140-2(2001-10-10) Runs: 0
                      Jan 14 00:04:45 raspberrypi rngd[377]: stats: FIPS 140-2(2001-10-10) Long run: 0
                      Jan 14 00:04:45 raspberrypi rngd[377]: stats: FIPS 140-2(2001-10-10) Continuous run: 0
                      Jan 14 00:04:45 raspberrypi rngd[377]: stats: HRNG source speed: (min=238.614; avg=440.907; max=492.430)Kibits/s
                      Jan 14 00:04:45 raspberrypi rngd[377]: stats: FIPS tests speed: (min=3.285; avg=14.301; max=31.423)Mibits/s
                      Jan 14 00:04:45 raspberrypi rngd[377]: stats: Lowest ready-buffers level: 2
                      Jan 14 00:04:45 raspberrypi rngd[377]: stats: Entropy starvations: 0
                      Jan 14 00:04:45 raspberrypi rngd[377]: stats: Time spent starving for entropy: (min=0; avg=0.000; max=0)us
                      Jan 14 00:17:01 raspberrypi CRON[32185]: (root) CMD ( cd / && run-parts --report /etc/cron.hourly)
                      Jan 14 00:25:30 raspberrypi DuetControlServer[14574]: [warn] Lost connection to Duet (Board is not available (no header))
                      Jan 14 00:25:30 raspberrypi DuetControlServer[14574]: [info] Connection to Duet established
                      Jan 14 00:32:49 raspberrypi DuetControlServer[14574]: [warn] Lost connection to Duet (Board is not available (no header))
                      Jan 14 00:32:49 raspberrypi DuetControlServer[14574]: [info] Connection to Duet established
                      Jan 14 00:51:21 raspberrypi DuetControlServer[14574]: [warn] Bad header CRC32 (expected 0x6d61620f, got 0x45d967fb)
                      Jan 14 00:51:21 raspberrypi DuetControlServer[14574]: [warn] Note: RepRapFirmware didn't receive valid data either (code 0x00000005)
                      Jan 14 00:56:55 raspberrypi DuetControlServer[14574]: [warn] Bad header CRC32 (expected 0xd5e94b60, got 0x4319b529)
                      Jan 14 00:56:55 raspberrypi DuetControlServer[14574]: [warn] Note: RepRapFirmware didn't receive valid data either (code 0x00000005)
                      Jan 14 01:04:29 raspberrypi DuetControlServer[14574]: [warn] Lost connection to Duet (Board is not available (no header))
                      Jan 14 01:04:29 raspberrypi DuetControlServer[14574]: [info] Connection to Duet established
                      Jan 14 01:04:45 raspberrypi rngd[377]: stats: bits received from HRNG source: 500064
                      Jan 14 01:04:45 raspberrypi rngd[377]: stats: bits sent to kernel pool: 454336
                      Jan 14 01:04:45 raspberrypi rngd[377]: stats: entropy added to kernel pool: 454336
                      Jan 14 01:04:45 raspberrypi rngd[377]: stats: FIPS 140-2 successes: 25
                      Jan 14 01:04:45 raspberrypi rngd[377]: stats: FIPS 140-2 failures: 0
                      Jan 14 01:04:45 raspberrypi rngd[377]: stats: FIPS 140-2(2001-10-10) Monobit: 0
                      Jan 14 01:04:45 raspberrypi rngd[377]: stats: FIPS 140-2(2001-10-10) Poker: 0
                      Jan 14 01:04:45 raspberrypi rngd[377]: stats: FIPS 140-2(2001-10-10) Runs: 0
                      Jan 14 01:04:45 raspberrypi rngd[377]: stats: FIPS 140-2(2001-10-10) Long run: 0
                      Jan 14 01:04:45 raspberrypi rngd[377]: stats: FIPS 140-2(2001-10-10) Continuous run: 0
                      Jan 14 01:04:45 raspberrypi rngd[377]: stats: HRNG source speed: (min=238.614; avg=440.930; max=492.430)Kibits/s
                      Jan 14 01:04:45 raspberrypi rngd[377]: stats: FIPS tests speed: (min=3.285; avg=14.314; max=31.423)Mibits/s
                      Jan 14 01:04:45 raspberrypi rngd[377]: stats: Lowest ready-buffers level: 2
                      Jan 14 01:04:45 raspberrypi rngd[377]: stats: Entropy starvations: 0
                      Jan 14 01:04:45 raspberrypi rngd[377]: stats: Time spent starving for entropy: (min=0; avg=0.000; max=0)us
                      Jan 14 01:17:01 raspberrypi CRON[3031]: (root) CMD ( cd / && run-parts --report /etc/cron.hourly)
                      Jan 14 01:30:42 raspberrypi DuetControlServer[14574]: [error] Heater 1 fault: temperature excursion exceeded 15.0°C (target 90.0°C, actual 128.2°C)
                      Jan 14 01:30:42 raspberrypi DuetControlServer[14574]: [info] Job has been paused at byte 8469316, reason HeaterFault
                      Jan 14 01:30:42 raspberrypi DuetControlServer[14574]: [info] Starting macro file pause.g on channel Autopause
                      Jan 14 01:30:42 raspberrypi DuetControlServer[14574]: [info] Finished macro file pause.g
                      Jan 14 01:30:46 raspberrypi DuetControlServer[14574]: [info] Printing paused at X182.6 Y50.4 Z40.6 U10.0 V10.0
                      Jan 14 01:40:42 raspberrypi DuetControlServer[14574]: [info] Cancelled printing file 0:/gcodes/MEGATOR P1.gcode, print time was 8h 15m
                      Jan 14 01:40:42 raspberrypi DuetControlServer[14574]: [error] Shutting down due to un-cleared heater fault after 600 seconds
                      Jan 14 01:59:09 raspberrypi systemd[1]: Starting Daily apt download activities...
                      Jan 14 01:59:11 raspberrypi systemd[1]: apt-daily.service: Succeeded.
                      Jan 14 01:59:11 raspberrypi systemd[1]: Started Daily apt download activities.
                      Jan 14 02:04:45 raspberrypi rngd[377]: stats: bits received from HRNG source: 540064
                      Jan 14 02:04:45 raspberrypi rngd[377]: stats: bits sent to kernel pool: 484096
                      Jan 14 02:04:45 raspberrypi rngd[377]: stats: entropy added to kernel pool: 484096
                      Jan 14 02:04:45 raspberrypi rngd[377]: stats: FIPS 140-2 successes: 27
                      Jan 14 02:04:45 raspberrypi rngd[377]: stats: FIPS 140-2 failures: 0
                      Jan 14 02:04:45 raspberrypi rngd[377]: stats: FIPS 140-2(2001-10-10) Monobit: 0
                      Jan 14 02:04:45 raspberrypi rngd[377]: stats: FIPS 140-2(2001-10-10) Poker: 0
                      Jan 14 02:04:45 raspberrypi rngd[377]: stats: FIPS 140-2(2001-10-10) Runs: 0
                      Jan 14 02:04:45 raspberrypi rngd[377]: stats: FIPS 140-2(2001-10-10) Long run: 0
                      Jan 14 02:04:45 raspberrypi rngd[377]: stats: FIPS 140-2(2001-10-10) Continuous run: 0
                      Jan 14 02:04:45 raspberrypi rngd[377]: stats: HRNG source speed: (min=238.614; avg=443.777; max=492.430)Kibits/s
                      Jan 14 02:04:45 raspberrypi rngd[377]: stats: FIPS tests speed: (min=3.285; avg=14.223; max=31.423)Mibits/s
                      Jan 14 02:04:45 raspberrypi rngd[377]: stats: Lowest ready-buffers level: 2
                      Jan 14 02:04:45 raspberrypi rngd[377]: stats: Entropy starvations: 0
                      Jan 14 02:04:45 raspberrypi rngd[377]: stats: Time spent starving for entropy: (min=0; avg=0.000; max=0)us
                      Vetiundefined Luke'sLaboratoryundefined 2 Replies Last reply Reply Quote 0
                      • Vetiundefined
                        Veti @jrockland
                        this suggest a failure of the relay
                          My take from this is that it shut down the duet after 10 min of heater fault, and if the relays need a high signal to turn off, by having no signal (from a shut down duet) it just stayed on and caused the issue.
                          Luke
                            jrockland @Veti
                            @Veti didnt understand the first part but Ill change it to out.0
                            • Vetiundefined
                              Veti @jrockland
                              it means your bed will be reporting the wrong temperature.
                              it will display 100C but it wont be 100C
                                jrockland @Luke'sLaboratory
                                @Luke-sLaboratory I dont know what SSR mean, but they look like normal relays to me.
                                • Vetiundefined
                                  Veti @jrockland
                                  SSR
                                  Solid State Relay.
                                  Using cheap ones is a sure way to burn your house down.
                                    Luke'sLaboratory
                                    @jrockland https://duet3d.dozuki.com/Wiki/Connecting_thermistors_or_PT1000_temperature_sensors - Relevant documentation.
                                    I'd take a serious look at what relays you are using (whether they're SSR's or traditional) the correct switching frequency, which thermistors you actually have in all of your machines, and the configuration of using a high Signal from the duet to turn relays off.
                                    Preferably you'd drop the frequency to ~10hz (by adding a Q10 to your M950 where you set up the output for out3 (or out1)), and reconfigure/aquire new relays that require a high signal from the duet to turn on. That way, if your duet goes offline for whatever reason, your relays will not turn on.
                                    Next I'd definitely recommend high-quality SSRs. Cheap/underrated/undercooled ones will latch on and have the exact behavior that may have caused this issue in the first place. Thats why I was looking for specifics on the relays used.
                                    Luke
                                      @Luke-sLaboratory the board send a ON signal as soon as I power it up if I remove the "!".. Ill need the tech to look into that asap. seem like it working the wrong way.
                                        @jrockland Do you mean that your relay turns on if you take off the ! from the duet config? or is the duet's output turning on when you remove the !
                                        Luke
                                          @Luke-sLaboratory not the ssr's, im testing the board with a meter right now. relays had been tested and work good.
                                            jrockland @Veti
                                            @Veti yea I looked at the picture and it is what we use.
