    Endstop instantly triggered when homing (y-axis)
    513
    • Visionaryundefined
      Visionary
      I got working other axes homing, but Y-axis does not seem to work. It is as if the endstop is immediately triggered when trying to move to endstop.
      M119 Reports:
      Endstops - X: not stopped, Y: not stopped, Z: not stopped, U: not stopped, Z probe: at min stop
      The machine I have is markforged kinematics style idex-printer (one motor for each axis).
      My homey.g file:
      G91
      G1 H2 Z5 F6000    ; lift Z relative to current position
      G1 H1 Y-405 F1800 ; move quickly to Y axis endstop and stop there (first pass)
      G1 Y5 F6000       ; go back a few mm
      G1 H1 Y-405 F600  ; move slowly to Y axis endstop once more (second pass)
      G1 H2 Z-5 F6000   ; lower Z again
      G90               ; absolute positioning
      ; generated by RepRapFirmware Configuration Tool v3.2.0 on Tue Dec 29 2020 21:29:27 GMT+0200 (Itä-Euroopan normaaliaika)
      G90                                                ; send absolute coordinates...
      M83                                                ; ...but relative extruder moves
      M550 P"My Printer"                                 ; set printer name
      M669 K11 Y-1:-1:0:1
      M552 P0.0.0.0 S1                                   ; enable network and acquire dynamic address via DHCP
      M586 P0 S1                                         ; enable HTTP
      M586 P1 S0                                         ; disable FTP
      M586 P2 S0                                         ; disable Telnet
      M569 P0.0 S1                              		   ; physical drive 0.0 goes forwards X
      M569 P0.1 S1                               		   ; physical drive 0.1 goes forwards U
      M569 P0.2 S1                                       ; physical drive 0.2 goes forwards Y
      M569 P0.3 S1                                       ; physical drive 0.3 goes forwards Z
      M569 P0.4 S0                                       ; physical drive 0.4 goes forwards E0
      M569 P0.5 S0                                       ; physical drive 0.5 goes forwards E1
      M584 X0.1 U0.0 Y0.2 Z0.3 E0.4:0.5                          ; set drive mapping
      M350 X256 U256 Y256 Z64 I1                              ; configure microstepping without interpolation
      M350 E64:256 I1                                       ; configure microstepping with interpolation
      M92 X1280.00 U1280.00 Y1280.00 Z2560.00 E10800.00:1000          ; set steps per mm
      M566 X600.00 U600.00 Y600.00 Z60.00 E40.00:300              ; set maximum instantaneous speed changes (mm/min)
      M203 X12000.00 U12000.00 Y12000.00 Z180.00 E1800.00:1000          ; set maximum speeds (mm/min)
      M201 X600.00 U600.00 Y600.00 Z20.00 E120.00:600                ; set accelerations (mm/s^2)
      M906 X500 U500 Y500 Z700 E980:980 I45                    ; set motor currents (mA) and motor idle factor in per cent
      M84 S30                                            ; Set idle timeout
      M569 P0.0 V25 H25 D3
      M569 P0.1 V25 H25 D3
      M569 P0.2 V25 H25 D3
      M915 P0.0 S3 R0 H134 T25 F1
      M915 P0.1 S3 R0 H134 T25 F1
      M915 P0.2 S3 R0 H134 T25 F1
      M208 X0 U0 Y0 Z0 S1                                   ; set axis minima
      M208 X400 U400 Y400 Z375 S0                             ; set axis maxima
      M574 X1 S1 P"!^io1.in"                             ; configure active-high endstop for low end on X via pin !^io2.in
      M574 U2 S1 P"!^io2.in"                             ; configure active-high endstop for high end on U via pin !^io1.in
      M574 Y1 S1 P"!^io3.in"                             ; configure active-high endstop for low end on Y via pin !^io3.in
      M574 Z1 S1 P"!^io4.in"                             ; configure active-high endstop for low end on Z via pin !^io4.in
      M558 P0 H5 F120 T6000                              ; disable Z probe but set dive height, probe speed and travel speed
      M557 X15:215 Y15:195 S20                           ; define mesh grid
      M308 S0 P"temp0" Y"thermistor" T100000 B3974       ; configure sensor 0 as thermistor on pin temp0
      M950 H0 C"out0" T0                                 ; create bed heater output on out0 and map it to sensor 0
      M307 H0 B1 S1.00                                   ; enable bang-bang mode for the bed heater and set PWM limit
      M140 H0                                            ; map heated bed to heater 0
      M143 H0 S130                                       ; set temperature limit for heater 0 to 120C
      M308 S1 P"temp1" Y"thermistor" T100000 B4725 C7.06e-8       ; configure sensor 1 as thermistor on pin temp2
      M950 H1 C"out1" T1                                 ; create nozzle heater output on out1 and map it to sensor 1
      M307 H1 B0 S1.00                                   ; disable bang-bang mode for heater  and set PWM limit
      M143 H1 S280                                       ; set temperature limit for heater 1 to 280C
      M308 S2 P"temp2" Y"thermistor" T100000 B4725 C7.06e-8       ; configure sensor 1 as thermistor on pin temp2
      M950 H2 C"out2" T2                                 ; create nozzle heater output on out1 and map it to sensor 1
      M307 H2 B0 S1.00                                   ; disable bang-bang mode for heater  and set PWM limit
      M143 H2 S280                                       ; set temperature limit for heater 1 to 280C
      M307 H0 A110 C180 D5 B1 						   ; Bed slow temperature rise
      M950 F0 C"out7" Q500                               ; create fan 0 on pin out7 and set its frequency
      M106 P0 S0 H-1                                     ; set fan 0 value. Thermostatic control is turned off
      M950 F1 C"out8" Q500                               ; create fan 1 on pin out8 and set its frequency
      M106 P1 S0 H-1                                     ; set fan 1 value. Thermostatic control is turned off
      ; tool 0, X-axis
      M563 P0 D0 H1 X0 F0                                   ; define tool 0
      G10 P0 X0 Y0 Z0                                    ; set tool 0 axis offsets
      ; tool 1, U-axis
      M563 P1 D1 H2 X3 F1
      G10 P0 R0 S0 Y0 U0 Z0                                      ; set initial tool 0 active and standby temperatures to 0C
      M575 P1 S1 B57600                                  ; enable support for PanelDue
      T0													; select tool
      3D-printer part collector || https://grabcad.com/eetu-4/models
      • fcwiltundefined
        fcwilt
        Why do you have stall motor detection configured as well as end stops?
        Visionaryundefined 1 Reply Last reply Reply Quote 0
        • Vetiundefined
          Veti
          @Visionary said in Endstop instantly triggered when homing (y-axis):
          this will overload your cpu. go with x16 unless there is a specific reason
            Visionary @fcwilt
            @fcwilt
            It is for stealthchop. My machine used to be corexy
            and I have not yet optimized/checked best values for stealthchop with the new kinematics.
            • Vetiundefined
              Veti
              M915
              comment them for now
                Visionary @Veti
                @Veti
                It was set high as possible for silent movement.
                I will try lower values, though 16x seems very low?
                Can I use something like 64x or 128x?
                • Vetiundefined
                  Veti @Visionary
                  @Visionary
                  the driver interpolation will run them interally at x256
                    Visionary @Veti
                    @Veti
                    I changed all microstepping to 16x and commented stealthchop related commands. This didn't change y-axis homing. It still seems to instantly "reach" endstop. After homing y-axis can be moved normally, though the position won't be correct.
                    • Vetiundefined
                      Veti @Visionary
                      M915 not M569
                        Visionary @Veti
                        @Veti
                        That is also related to stealthchop according to some post. Stall detections doesn't work with stealthchop .
                        • Vetiundefined
                          Veti
                          what kind of endstop are you using?
                            Visionary @Veti
                            @Veti
                            Regular normally open microswitches. I think ill change it just be sure because I have crashed into it few times.
                            • fcwiltundefined
                              fcwilt @Visionary
                              @Veti
                              Can you wire them to use the NC connection - using the NO connection is discouraged.
                              Visionaryundefined 1 Reply Last reply Reply Quote 1
                                Visionary @fcwilt
                                @fcwilt
                                That worked! thanks.
