    Endstop instantly triggered when homing (y-axis)
    497
    • Visionaryundefined
      Visionary @fcwilt
      @fcwilt
      It is for stealthchop. My machine used to be corexy
      and I have not yet optimized/checked best values for stealthchop with the new kinematics.
      Main printer: 3-5 Axis, 400x400x450 Duet 6HC || https://grabcad.com/eetu-4/models
      • Vetiundefined
        Veti
        @Visionary said in Endstop instantly triggered when homing (y-axis):
        M915
        comment them for now
        Visionaryundefined 1 Reply Last reply Reply Quote 0
          Visionary @Veti
          @Veti
          It was set high as possible for silent movement.
          I will try lower values, though 16x seems very low?
          Can I use something like 64x or 128x?
          • Vetiundefined
            Veti @Visionary
            @Visionary
            the driver interpolation will run them interally at x256
              Visionary @Veti
              @Veti
              I changed all microstepping to 16x and commented stealthchop related commands. This didn't change y-axis homing. It still seems to instantly "reach" endstop. After homing y-axis can be moved normally, though the position won't be correct.
              • Vetiundefined
                Veti @Visionary
                M915 not M569
                  Visionary @Veti
                  @Veti
                  That is also related to stealthchop according to some post. Stall detections doesn't work with stealthchop .
                  • Vetiundefined
                    Veti
                    what kind of endstop are you using?
                      Visionary @Veti
                      @Veti
                      Regular normally open microswitches. I think ill change it just be sure because I have crashed into it few times.
                      • fcwiltundefined
                        fcwilt @Visionary
                        @Veti
                        Can you wire them to use the NC connection - using the NO connection is discouraged.
                        Visionaryundefined 1 Reply Last reply Reply Quote 1
                          Visionary @fcwilt
                          @fcwilt
                          That worked! thanks.
