    New stable firmware bundle 3.2 released
    Firmware installation
    18
    41
    3.8k
    • amjm22undefined
      amjm22
      When installing The Webserver to 3.2 I get this error -
      RepRapFirmware for Duet 3 MB6HC version 3.2 running on Duet 3 MB6HC v0.6 or 1.0 (SBC mode)
      1/10/2021, 11:39:15 AM Failed to upload materialdesignicons-webfont.4187121a.woff2
      Operation failed (Reason: Access to the path '/opt/dsf/sd/www/fonts/materialdesignicons-webfont.4187121a.woff2' is denied.)
      Has anyone seen this before?
      • Tapetenhobelundefined
        Tapetenhobel
        I update from a Duet2 Wifi to the new mini+ and hooked it to a raspberry pi.
        A friend and me are currently developing a multi-Platform print monitor and I've used queries via /rr_status?type=2 and so on before, but with DWC running on the pi I only get a 404:Not found when I try to query DWC. It was running fine on the Duet2 with the beta and RC-versions. I also didn't found anything in the release notes regarding this.
        Do I miss something?
        Thanks
        Sapphire Pro, Mini 5+, BLTouch, PanelDue 3 5"
        Anycubic i3 Mega, SKR 1.4, Klipper
        resamundefined 1 Reply Last reply Reply Quote 0
        • resamundefined
          resam @Tapetenhobel
          @Tapetenhobel not really a v3.2 problem, or is it?
          I think you are looking for the new API when running in "SBC mode" with DuetSoftwareFramework:
          https://github.com/Duet3D/DuetSoftwareFramework#get-machinestatus
          Tapetenhobelundefined 1 Reply Last reply Reply Quote 0
            Phaedrux Moderator @amjm22
            @amjm22 How are you updating? If using the SBC you should be using sudo apt update/upgrade method.
            amjm22undefined 1 Reply Last reply Reply Quote 0
            • amjm22undefined
              amjm22 @Phaedrux
              @Phaedrux - sudo apt update/upgrade. I did that, I'm still on Duet Web Control 3.1.1
              Thanks for your reply
              • amjm22undefined
                amjm22 @amjm22
                @amjm22 I did again and it worked! unreal
                  Tapetenhobel @resam
                  @resam
                  Cool, thanks 🙂
                  • damaged_goodsundefined
                    damaged_goods
                    This post is deleted!
                    1 Reply Last reply Reply Quote -1
                    • garyd9undefined
                      garyd9
                      Will DSF ever reach feature parity with RRF?
                      I remember that early in the 3x series, there was a push to get DSF at the same level of functionality as RRF, and while the version numbers now match, the supported feature set doesn't.
                      It's confusing that "version 3.2" means different things depending on if a SBC is being used or not, and those differences don't appear to be documented anywhere. (If they are, please point me to that document so I can read about any other differences before they surprise me.)
                      As an example (and asked about in the DSF section), conditional gcode functions (https://duet3d.dozuki.com/Wiki/GCode_Meta_Commands#Section_Functions) don't seem to be implemented in DSF 3.2, but have been supported in RRF for almost a year now (at least since version 3.1.)
                        A Former User @garyd9
                        @garyd9 said in New stable firmware bundle 3.2 released:
                        this was a demand from other users that had issues with having to keep up with using dsf version x, rrf version y and dwc version z - and nothing to do with reflecting features.
                        which ones are you finding not working, i think the majority has been working for a while at least
                        garyd9undefined 1 Reply Last reply Reply Quote 0
                        • garyd9undefined
                          garyd9 @A Former User
                          @bearer said in New stable firmware bundle 3.2 released:
                          None of them appear to be implemented. I've only tried "abs", "min", and "max" in my own gcode (and then had to rewrite some stuff to not use them), but then I searched the DSF code for other function names (via github's search) and found nothing. From an earlier post I made, I specifically searched for the strings "atan2", "acos", and "radians" with no results.
                          Here's the other thread I mentioned: https://forum.duet3d.com/topic/20852/conditional-gcode-with-dsf-3-2-error-works-standalone/4
                          (Note that I used the search facility built into github which is lacking to begin with.)
                          • garyd9undefined
                            garyd9 @garyd9
                            Grepping the actual source (cd DuetSoftwareFramework/src, grep -ri token *) shows the same (non-)results as github searching. I also checked for some other function names via grep with no hits:
                            radians
                            sqrt
                            atan
                            degrees
                            floor
                            That said, it's possible they are implemented, but somehow without actually including the strings that are implemented. Of course, if they ARE implemented, then it's a bug that they don't actually work.
                            Try the following gcode in a macro using the duet3+SBC on RRF/DSF 3.2 (or 3.1.1):
                            echo "debug " ^ abs(3)
                            The same thing works with standalone RRF 3.2 (and RRF 3.1.1.)
                            I do think it's important to point out that I'm not exactly complaining that they aren't implemented. I'm only asking when feature parity will be reached (or if it's even being attempted.)
                            Over the past week or so, I've been trying to migrate to "try out" using the SBC, but it's been a series of disappointments finding that things that work fine with standalone don't with the SBC (and those things aren't documented to be non-functional.)
                            Before I started, I asked on the forum what limitations I might run into and was pointed to a document here: https://duet3d.dozuki.com/Wiki/Duet_3_firmware_configuration_limitations
                            That was a good generic answer, but if you check the document, it's not only out of date, it doesn't mentioned any differences between running RRF and running RRF+DSF.
                            I'd submit new wiki pages describing the differences to future people who might embark on the same journey as I am, but doing that requires factual information. For example: It would be useful to mention if feature parity between DSF and RRF is planned or not. That brings me back to the my question of: "Will DSF ever reach feature parity with RRF?"
                            • DaBitundefined
                              DaBit
                              Small bug, or user error?
                              Renaming the Duet3_SDiap32_Minip5plus.bin file to Duet3_SDiap_Minip5plus.bin works.
                              • Vetiundefined
                                Veti
                                user error. that file should have been on the original sd card.
                                that file is required for the next firmware update
                                • DaBitundefined
                                  DaBit
                                  Before powering the (Mini 5+) board the first time I took out the SD card, inserted it into the PC, renamed the original sys/ directory to sys.original/, copied it's contents into a fresh sys/ and then copied an RRF-configurator generated set into sys/ over the existing files.
                                  There is no Duet3_SDiap_Mini5plus.bin file in the original sys/ ...
                                  Firmware upgrade was done by uploading Duet2and3Firmware-3.2.zip. This initially failed on the missing file, so I renamed the Duet3_SDiap32_Mini5plus.bin and entered M997 S0 manually to perform the upgrade.
                                  This works, I am running 3.2 (2021-01-05) now.
                                  • Vetiundefined
                                    Veti
                                    that look like the content for the duet 2 not the mini 5+
                                    • DaBitundefined
                                      DaBit
                                      The contents are coming from the 8GB Sandisk Edge SD-card that was inserted in the board when it arrived. As-delivered the firmware was RRF 3.2-beta (2?), same for DWC; that was a 3.2 beta too.
                                      Maybe someone swapped cards or images, although the default contents of config.g mention Duet 3 Mini 5+. There is no image on the card for use with a Pi either, but I am not sure if it should have been on it with the Mini 5+.
                                      As a side note: may I suggest putting M550 P"Duet3D" / M552 P0.0.0.0 S1 / M586 P0 S1 in the config of the Ethernet-version as-delivered?
                                      That way the board is accessible on the network out of the box using http://duet3d.local on a regular home network setup. Saves all the initial terminal hassle; since DWC is accessible it is easy to do the config upload from there. A bit more userfriendly.
                                      • ErwinH78undefined
                                        ErwinH78
                                        is there a known problem with the bl touch after the update? my bl touch sometimes doesn't work. sometimes during homing, sometimes during true bed leveling and the z-axis then crashes into the nozzle
                                        • Vetiundefined
                                          Veti @ErwinH78
                                          @ErwinH78
                                          that sounds like a bltouch problem with the wiring
                                          • ErwinH78undefined
                                            ErwinH78
                                            ok i will check thx
