Mesh levelling on 3.1.1
post your homeall
; homeall.g
; called to home all axes
; generated by RepRapFirmware Configuration Tool v3.1.4 on Tue Oct 20 2020 12:22:07 GMT+1100 (Australian Eastern Daylight Time)
G91 ; relative positioning
G1 H1 X-265 Y-265 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
G1 H2 X5 Y5 F6000 ; go back a few mm
G1 H1 X-265 Y-265 F360 ; move slowly to X and Y axis endstops once more (second pass)
G1 H1 Z-265 F360 ; move Z down stopping at the endstop
G1 H2 Z5 F6000 ; go back a few mm
G1 H1 Z-265 F180 ; move Z down stopping at the endstopG90 ; absolute positioning
G92 Z0 ; set Z position to axis minimum (you may want to adjust this) -
M122
RepRapFirmware for Duet 2 WiFi/Ethernet version 3.2 running on Duet WiFi 1.02 or later
Board ID: 08DJM-9178L-L2MSD-6J1F8-3S46P-TSFUP
Used output buffers: 3 of 24 (14 max)
Static ram: 23460
Dynamic ram: 73588 of which 60 recycled
Never used RAM 14972, free system stack 189 words
Tasks: NETWORK(blocked,160) HEAT(blocked,295) MAIN(running,452) IDLE(ready,19)
Owned mutexes: WiFi(NETWORK)
Last reset 00:01:52 ago, cause: software
Last software reset details not available
Error status: 0x00
Aux0 errors 0,0,0
MCU temperature: min 29.8, current 30.3, max 30.7
Supply voltage: min 24.0, current 24.1, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes
Driver 0: position 0, standstill, SG min/max not available
Driver 1: position 0, standstill, SG min/max not available
Driver 2: position 0, standstill, SG min/max not available
Driver 3: position 0, standstill, SG min/max not available
Driver 4: position 0, standstill, SG min/max not available
Driver 5: position 0
Driver 6: position 0
Driver 7: position 0
Driver 8: position 0
Driver 9: position 0
Driver 10: position 0
Driver 11: position 0
Date/time: 2021-01-18 10:56:12
Cache data hit count 141319080
Slowest loop: 5.41ms; fastest: 0.23ms
=== Storage ===
Free file entries: 10
SD card longest read time 3.8ms, write time 0.0ms, max retries 0
=== MainDDARing ===
=== AuxDDARing ===
Bed heaters = 0 -1 -1 -1, chamberHeaters = 2 -1 -1 -1
Segments left: 0
Movement lock held by null
HTTP is idle in state(s) 0
Telnet is idle in state(s) 0
File is idle in state(s) 0
USB is idle in state(s) 0
Aux is idle in state(s) 0
Trigger is idle in state(s) 0
Queue is idle in state(s) 0
LCD is idle in state(s) 0
Daemon is idle in state(s) 0
Code queue is empty.
=== Network ===
Slowest loop: 16.24ms; fastest: 0.00ms
HTTP sessions: 1 of 8- WiFi -
Network state is active
WiFi firmware version 1.25
WiFi MAC address redacted
WiFi Vcc 3.48, reset reason Turned on by main processor
WiFi flash size 4194304, free heap 23360
WiFi IP address 192.168.1.57
WiFi signal strength -47dBm, mode 802.11n, reconnections 0, sleep mode modem
Clock register 00002002
=== Filament sensors ===
Extruder 0 sensor: no data received
- WiFi -
@lael said in Mesh levelling on 3.1.1:
G1 H1 Z-265 F180 ; move Z down stopping at the endstop G90 ; absolute positioning G92 Z0 ; set Z position to axis minimum (you may want to adjust this)
What is the actual Z position after triggering the endstop?
For the G92 Z0 to be valid the actual Z position must also be zero.
M98 P"config.g"
HTTP is enabled on port 80
FTP is disabled
TELNET is disabled
Z probe 0: current reading 0, threshold 500, trigger height 0.700, offsets X0.0 Y0.0
Error: bad model parameters
Error: bad model parameters -
@Phaedrux said in Mesh levelling on 3.1.1:
Post the results of M122 and M98 P"config.g"
Post your config.g and homing files, and bed.g
Post your start.g and your slicer start gcode.config.g
; generated by RepRapFirmware Configuration Tool v3.1.4 on Tue Oct 20 2020 12:22:07 GMT+1100 (Australian Eastern Daylight Time); General preferences
M550 P"Funmat HT #2" ; set printer name; Network
M551 P"redacted" ; set password
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M569 P0 S0 ; X physical drive 0 goes backwards
M569 P1 S1 ; Y physical drive 1 goes forwards
M569 P2 S0 ; Z physical drive 2 goes backwards
M569 P3 S0 ; E physical drive 3 goes forwards
M92 X80.00 Y80.00 Z800.00 E410.00 ; set steps per mmM566 X300.00 Y300.00 Z180.00 E1200 ; set maximum instantaneous speed changes (mm/min)
M203 X9000.00 Y9000.00 Z1800.00 E10000 ;changed to allow faster z for piezo trigger (1200 works)
;M201 X3000.00 Y3000.00 Z15.00 E500.00 ;recommended settings and PA currently tuned PA on this value
M201 X1000.00 Y1000.00 Z30.00 E700.00 ; set max accelerations (mm/s^2) ;upped z to 25 for z probeM204 P800.00 T1500.00 ;set default acceleration P=x,y,z T=extruder
M906 X1150 Y1150 Z1300 E700 I45 ; set motor currents (mA) and motor idle factor in per cent
M208 X255 Y250 Z260 S0 ; set axis maxima; Endstops
M574 X1 S1 P"!xstop" ; configure active-low endstop for Min X axis via pin !xstop //omron limit switch
M574 Y1 S1 P"!ystop" ; configure active-low endstop for Min Y axis via pin !ystop //omron limit switch
M574 Z1 S1 P"zstop" ; configure active-low endstop for min Z axis via pin zstop inverting the signal. //biqu optical sensor;Z Emergency-Stop
M950 J1 C"!e1stop" ; configure active-low input (endstop) via pin e1stop //omron limit switch on z just prior to min limit ball screw crash.
M581 P1 T0 C0 S1 ;T0 = emergency stop on trigger; C0 or C1 = when it may trigger: C0 is anytime; C1 is only during a print, S1 or S0 = sets it as raising edge (S1) or falling edge (S0); Z-Probe
M558 C"!^zprobe.in" P8 F7000 T7000 H10 I1 R0.3 A5 S0.005 ; Z probe type to PIEZO (P8 = unfiltered, F = feed mm/min dive speed 116mm/sec,
; T-travel between spots mm/min H=dive height mm, I1 - invert reading, R0.5 - pause 0.5sec
; before each probe, A3 - probe 3 times, S0.01 - tolerance between probes required) and theG31 -0.777 ; set the z height at which the probe will recognise it's z
;M558 P0 H5 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed (old before piezo)
;M557 X20:240 Y20:240 S44 ; define mesh grid - max bed size
M557 X30:230 Y20:230 S40 ; define mesh grid - reduced bed size to avoid cooling duct on back bed holders; Heaters
M308 S0 P"bedtemp" Y"thermistor" T122000 B4050 ; configure sensor 0 as thermistor on pin bedtemp
M307 H0 A=143 C=1300 D=20 B0 ; enable pid mode for the bed heater
M143 H0 S160 ; set temperature limit for heater 0 to 160CM308 S1 P"spi.cs1" Y"rtd-max31865" ; configure sensor 1 as thermocouple via CS pin spi.cs1
M307 H1 A=450 C=160 D=5.3 V=24 B0 ; disable bang-bang mode for heater and set PWM limitM308 S2 P"e1temp" Y"thermistor" T100000 B3950 ; configure sensor 2 as thermistor on pin e1temp
M950 H2 C"e1heat" T2 ; create chamber heater output on e1heat and map it to sensor 2
M307 H2 A145 C1600 D4.5 V24 B0 S1 ; enable bang-bang mode for the chamber heater and set PWM limit
M141 H2 ; map chamber to heater 2; Fans
M950 F0 C"fan0" Q500 ; create fan 0 on pin fan0 and set its frequency to 500Hz (default for 2 wire)
M106 P1 S1.0 H1:2 T45 ; set fan 1 value to full speed. Thermostatic control is turned on for heater 1 & 2; Tools
; Screw positions
M671 X28:228:129 Y188:188:16 P0.5; Miscellaneous
M302 S180 R180 ; min extruder temp and retraction
M911 S21 R23 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss;BigTreeTech Filament Runout Sensor
;see: https://forum.duet3d.com/topic/17107/how-to-setup-the-bigtreetech-smart-filament-sensor/48M591 D0 P7 C"^e0stop" L7 R75:200 E22 S1 ;
@fcwilt 0.00 is what shows up in web control
; homex.g
; called to home the X axis
G1 H1 X-265 F1800 ; move quickly to X axis endstop and stop there (first pass)
G1 H2 X5 F6000 ; go back a few mm
G1 H1 X-265 F360 ; move slowly to X axis endstop once more (second pass)
G1 H2 Z-5 F6000 ; lower Z again
G90 ; absolute positioning -
; homey.g
; called to home the Y axis
G1 H1 Y-265 F1800 ; move quickly to Y axis endstop and stop there (first pass)
G1 H2 Y5 F6000 ; go back a few mm
G1 H1 Y-265 F360 ; move slowly to Y axis endstop once more (second pass)
That line is incorrect.
You should have at least the P X Y and Z parameters but you have none and a value all on it's own.
If you comment out the G92 Z0 in homeall.g what value is displayed?
; homez.g
; called to home the Z axis
G1 H2 Z5 F600 ; increase (drop) Z relative to current position by 5mm @300mm/min (5mm/sec)
G1 H1 Z-265 F600 ; decrease Z until the endstop is triggered @10mm / sec
G1 H2 Z5 F300 ; lift Z relative to current position - Z=5 @6000mm/min (100mm/sec)
G1 H1 Z-10 F180 ; move Z down until the endstop is triggered @3mm/sec; Uncomment the following lines to lift Z after probing
;G91 ; relative positioning
;G90 ; absolute positioning -
start.g
G28 ;home all axis
G0 X130 Y130 Z10 ; go to bed center, 10mm above
G30 ; probe for datum ref point
G29 S1 ; Load Grid Compensation
T0 ; Selects Tool 0 (active temp)
M703 ; Ensure filament specific settings are loaded
G1 X10 Y10 ; move close to origin -
G28 ;Home All Axis
G92 E0 ;zero extruded lengthG0 X0 Y0 F9000 ; Go to front
Slicer Start G Code:G0 Z0.20 ; Drop to 0.2 above bed
G92 E0 ; zero the extruded length
G1 X40 E35 F600 ; Extrude 35mm of filament in a 4cm line @600mm/min 60mm/sec
G1 E-1 F30 ; Retract a little
G1 X80 F4000 ; Quickly wipe away from the filament lineG0 F3600 X20 Y20 ;rapid movement to X20, Y20
I had G29 S1 which was removed after creating the start.g macro
@fcwilt 0.71mm
@fcwilt 0.71mm
OK so the end stop triggers are 0.71 and at the point the Z axis stops moving.
Is that the actual Z position of the nozzle.
If you include the G92 Z0 you are telling the firmware that the Z position is 0.
So where exactly is the nozzle tip - at Z = 0.71 or Z = 0.00 or perhaps something else?
Thanks
Can we see the code that you use to create the height map?
@fcwilt so far I've just been running through the mesh levelling tutorial / example and haven't made a macro for it. To remap I've gone through the entire procedure manually.
In terms of the nozzle tip, you mean relative to the bed?
Did you do a G30 prior to the G29 that actually started the probing of the bed?
Yes.
@fcwilt said in Mesh levelling on 3.1.1:
yes
The bed is quite warped, but at the center where I run the G30's for printing etc, it is just the right height above the bed to grip a piece of paper lightly. So I guess ~0.1 or a little less or so.
