    Mesh levelling on 3.1.1
    1.5k
    • fcwiltundefined
      fcwilt
      @lael said in Mesh levelling on 3.1.1:
      G1 H1 Z-265 F180 ; move Z down stopping at the endstop
      G90 ; absolute positioning
      G92 Z0 ; set Z position to axis minimum (you may want to adjust this)
      What is the actual Z position after triggering the endstop?
      For the G92 Z0 to be valid the actual Z position must also be zero.
      laelundefined 1 Reply Last reply Reply Quote 1
      • laelundefined
        lael
        M98 P"config.g"
        HTTP is enabled on port 80
        FTP is disabled
        TELNET is disabled
        Z probe 0: current reading 0, threshold 500, trigger height 0.700, offsets X0.0 Y0.0
        Error: bad model parameters
        • laelundefined
          lael
          @Phaedrux said in Mesh levelling on 3.1.1:
          Post the results of M122 and M98 P"config.g"
          Post your config.g and homing files, and bed.g
          Post your start.g and your slicer start gcode.
          config.g
          ; generated by RepRapFirmware Configuration Tool v3.1.4 on Tue Oct 20 2020 12:22:07 GMT+1100 (Australian Eastern Daylight Time)
          M550 P"Funmat HT #2" ; set printer name
          M551 P"redacted" ; set password
          M552 S1 ; enable network
          M586 P0 S1 ; enable HTTP
          M586 P1 S0 ; disable FTP
          M586 P2 S0 ; disable Telnet
          M569 P0 S0 ; X physical drive 0 goes backwards
          M569 P1 S1 ; Y physical drive 1 goes forwards
          M569 P2 S0 ; Z physical drive 2 goes backwards
          M569 P3 S0 ; E physical drive 3 goes forwards
          M92 X80.00 Y80.00 Z800.00 E410.00 ; set steps per mm
          M566 X300.00 Y300.00 Z180.00 E1200 ; set maximum instantaneous speed changes (mm/min)
          M203 X9000.00 Y9000.00 Z1800.00 E10000 ;changed to allow faster z for piezo trigger (1200 works)
          ;M201 X3000.00 Y3000.00 Z15.00 E500.00 ;recommended settings and PA currently tuned PA on this value
          M201 X1000.00 Y1000.00 Z30.00 E700.00 ; set max accelerations (mm/s^2) ;upped z to 25 for z probe
          M204 P800.00 T1500.00 ;set default acceleration P=x,y,z T=extruder
          M906 X1150 Y1150 Z1300 E700 I45 ; set motor currents (mA) and motor idle factor in per cent
          M84 S30 ; Set idle timeout
          M208 X255 Y250 Z260 S0 ; set axis maxima
          M574 X1 S1 P"!xstop" ; configure active-low endstop for Min X axis via pin !xstop //omron limit switch
          M574 Y1 S1 P"!ystop" ; configure active-low endstop for Min Y axis via pin !ystop //omron limit switch
          M574 Z1 S1 P"zstop" ; configure active-low endstop for min Z axis via pin zstop inverting the signal. //biqu optical sensor
          ;Z Emergency-Stop
          M950 J1 C"!e1stop" ; configure active-low input (endstop) via pin e1stop //omron limit switch on z just prior to min limit ball screw crash.
          M581 P1 T0 C0 S1 ;T0 = emergency stop on trigger; C0 or C1 = when it may trigger: C0 is anytime; C1 is only during a print, S1 or S0 = sets it as raising edge (S1) or falling edge (S0)
          M558 C"!^zprobe.in" P8 F7000 T7000 H10 I1 R0.3 A5 S0.005 ; Z probe type to PIEZO (P8 = unfiltered, F = feed mm/min dive speed 116mm/sec,
          ; T-travel between spots mm/min H=dive height mm, I1 - invert reading, R0.5 - pause 0.5sec
          ; before each probe, A3 - probe 3 times, S0.01 - tolerance between probes required) and the
          G31 -0.777 ; set the z height at which the probe will recognise it's z
          ;M558 P0 H5 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed (old before piezo)
          ;M557 X20:240 Y20:240 S44 ; define mesh grid - max bed size
          M557 X30:230 Y20:230 S40 ; define mesh grid - reduced bed size to avoid cooling duct on back bed holders
          M308 S0 P"bedtemp" Y"thermistor" T122000 B4050 ; configure sensor 0 as thermistor on pin bedtemp
          M307 H0 A=143 C=1300 D=20 B0 ; enable pid mode for the bed heater
          M143 H0 S160 ; set temperature limit for heater 0 to 160C
          M308 S1 P"spi.cs1" Y"rtd-max31865" ; configure sensor 1 as thermocouple via CS pin spi.cs1
          M307 H1 A=450 C=160 D=5.3 V=24 B0 ; disable bang-bang mode for heater and set PWM limit
          M308 S2 P"e1temp" Y"thermistor" T100000 B3950 ; configure sensor 2 as thermistor on pin e1temp
          M950 H2 C"e1heat" T2 ; create chamber heater output on e1heat and map it to sensor 2
          M307 H2 A145 C1600 D4.5 V24 B0 S1 ; enable bang-bang mode for the chamber heater and set PWM limit
          M141 H2 ; map chamber to heater 2
          M950 F0 C"fan0" Q500 ; create fan 0 on pin fan0 and set its frequency to 500Hz (default for 2 wire)
          M106 P1 S1.0 H1:2 T45 ; set fan 1 value to full speed. Thermostatic control is turned on for heater 1 & 2
          ; Screw positions
          M671 X28:228:129 Y188:188:16 P0.5
          M302 S180 R180 ; min extruder temp and retraction
          M911 S21 R23 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss
          ;BigTreeTech Filament Runout Sensor
          ;see: https://forum.duet3d.com/topic/17107/how-to-setup-the-bigtreetech-smart-filament-sensor/48
          M591 D0 P7 C"^e0stop" L7 R75:200 E22 S1 ;
          • laelundefined
            lael @fcwilt
            @fcwilt 0.00 is what shows up in web control
            • laelundefined
              lael
              ; homex.g
              ; called to home the X axis
              G91 ; relative positioning
              G1 H1 X-265 F1800 ; move quickly to X axis endstop and stop there (first pass)
              G1 H2 X5 F6000 ; go back a few mm
              G1 H1 X-265 F360 ; move slowly to X axis endstop once more (second pass)
              G1 H2 Z-5 F6000 ; lower Z again
              • laelundefined
                lael
                ; homey.g
                ; called to home the Y axis
                G1 H1 Y-265 F1800 ; move quickly to Y axis endstop and stop there (first pass)
                G1 H2 Y5 F6000 ; go back a few mm
                G1 H1 Y-265 F360 ; move slowly to Y axis endstop once more (second pass)
                • fcwiltundefined
                  fcwilt
                  That line is incorrect.
                  You should have at least the P X Y and Z parameters but you have none and a value all on it's own.
                  • fcwiltundefined
                    fcwilt @lael
                    If you comment out the G92 Z0 in homeall.g what value is displayed?
                    laelundefined 1 Reply Last reply Reply Quote 0
                    • laelundefined
                      lael
                      ; homez.g
                      ; called to home the Z axis
                      G1 H2 Z5 F600 ; increase (drop) Z relative to current position by 5mm @300mm/min (5mm/sec)
                      G1 H1 Z-265 F600 ; decrease Z until the endstop is triggered @10mm / sec
                      G1 H2 Z5 F300 ; lift Z relative to current position - Z=5 @6000mm/min (100mm/sec)
                      G1 H1 Z-10 F180 ; move Z down until the endstop is triggered @3mm/sec
                      ;G91 ; relative positioning
                      ;G90 ; absolute positioning
                      • laelundefined
                        lael
                        start.g
                        G28 ;home all axis
                        G0 X130 Y130 Z10 ; go to bed center, 10mm above
                        G30 ; probe for datum ref point
                        G29 S1 ; Load Grid Compensation
                        T0 ; Selects Tool 0 (active temp)
                        M703 ; Ensure filament specific settings are loaded
                        G1 X10 Y10 ; move close to origin
                        • laelundefined
                          lael
                          G28 ;Home All Axis
                          G92 E0 ;zero extruded length
                          G0 X0 Y0 F9000 ; Go to front
                          Slicer Start G Code:
                          G0 Z0.20 ; Drop to 0.2 above bed
                          G92 E0 ; zero the extruded length
                          G1 X40 E35 F600 ; Extrude 35mm of filament in a 4cm line @600mm/min 60mm/sec
                          G1 E-1 F30 ; Retract a little
                          G1 X80 F4000 ; Quickly wipe away from the filament line
                          G0 F3600 X20 Y20 ;rapid movement to X20, Y20
                          I had G29 S1 which was removed after creating the start.g macro
                          • laelundefined
                            lael @fcwilt
                            @fcwilt 0.71mm
                            • fcwiltundefined
                              fcwilt @lael
                              @fcwilt 0.71mm
                              OK so the end stop triggers are 0.71 and at the point the Z axis stops moving.
                              Is that the actual Z position of the nozzle.
                              If you include the G92 Z0 you are telling the firmware that the Z position is 0.
                              So where exactly is the nozzle tip - at Z = 0.71 or Z = 0.00 or perhaps something else?
                              Thanks
                              • fcwiltundefined
                                fcwilt
                                Can we see the code that you use to create the height map?
                                • laelundefined
                                  lael @fcwilt
                                  @fcwilt so far I've just been running through the mesh levelling tutorial / example and haven't made a macro for it. To remap I've gone through the entire procedure manually.
                                  In terms of the nozzle tip, you mean relative to the bed?
                                  • fcwiltundefined
                                    fcwilt @lael
                                    Did you do a G30 prior to the G29 that actually started the probing of the bed?
                                    Yes.
                                    • laelundefined
                                      lael @fcwilt
                                      @fcwilt said in Mesh levelling on 3.1.1:
                                      yes
                                      The bed is quite warped, but at the center where I run the G30's for printing etc, it is just the right height above the bed to grip a piece of paper lightly. So I guess ~0.1 or a little less or so.
                                      • fcwiltundefined
                                        fcwilt @lael
                                        @lael
                                        If you are going to use the G92 Znnn command you should determine as best you can what the actual nozzle position is and use that value.
                                        Did you correct your G31 command and include the P X Y and Z parameters?
                                        • laelundefined
                                          lael
                                          So what is the relationship between all of the Z points?
                                          Here is my understanding so far:
                                          G92 Z0 sets printing 0 - so the firmware is expecting 0 to be where the nozzle should be when putting down the first layer.
                                          G31 sets the location where the probe will be triggered - so in my case it is a piezo sensor which is triggered when the nozzle impacts the bed. So a -0.7mm makes sense as that is when the nozzle will actually contact the bed?
                                          Home Z will move the head/bed (bed in my case) to the end stop, which will reference that location as zero.
                                          Then mesh compensation will apply the additional compensation it has found above or below the Z point. The G30 datum point - sets the location at which the mesh map will be applied from? or does it overrride the G31 in config.g?
                                          Phaedruxundefined fcwiltundefined 2 Replies Last reply Reply Quote 0
                                            Phaedrux Moderator @lael
                                            G30 uses the trigger height from G31
                                            Usually when you have a probe, you don't use a Z min endstop at all. You use the probe for homing Z and creating the mesh. That way the Z0 reference is always the same based on the probe.
