    Duet 3 mini 5+ need help with wiring and config
    Firmware installation
    2.7k
    • Alucardiundefined
      Alucardi @Phaedrux
      @Phaedrux Why cant i pick io3.in on drive z in config? i can only pick io1/io2 but i cant pick them for the bl touch.
        Can you show a screenshot of what you mean?
        Alucardiundefined 1 Reply Last reply Reply Quote 0
        • Alucardiundefined
          Alucardi @Phaedrux
          @Phaedrux nwm i figured it out. You set to sue bltouch further ahead in the config.
            0cda00ea-3d80-4f88-bf81-fa734347214c-image.png Screen Shot 2021-01-05 at 11.40.08 PM.png
            cd537727-7d20-4fd2-8f73-4aea1292d7b0-image.png Screen Shot 2021-01-06 at 12.02.24 AM.png
            • Alucardiundefined
              Alucardi @Phaedrux
              @Phaedrux i got everything wired up and the pin extend and retract but it does not light blue and it does not report a value. What could be wrong?
              • Vetiundefined
                Veti
                you will not see the bltouch value change, it triggers for a fraction of a second.
                test it with g30 and triggering it by hand so you can power off if it does not stop.
                • Alucardiundefined
                  Alucardi @Veti
                  @Veti i tried and the value on the webui will just show 0. I have tried while homing to and it will not report a value, so bed will continue even if the pin is triggered by me. Pretty sure it should light blue when active also.
                  I used these steps tio manually test also
                  "To test the setup with the nozzle maybe a 100mm up from the bed you can check if the trigger signal is reaching the Duet by attempting to extend the pin by using the following command:
                  M280 P0 S10
                  If all is well the web interface should report a value of ”0” or "N/A" in the Z probe column when the pin is extended. You can then lightly touch the extended probe pin to check that the value in the Z probe Column changes to “1000”
                  You can retract the pin again with
                  M280 P0 S90"
                    How exactly do you have it wired? And what does the M558 M950 commands look like in your config.g? Does it match what I showed above?
                    Are you wired to IO3 like this?
                    • Alucardiundefined
                      Alucardi @Phaedrux
                      @Phaedrux it is just like in the picture, i made sure i have connection all the way to the probe using a multimeter so no broken wire.
                      i have not amde any changes to M950 or M558, It is just as the config did them.
                      M950 S0 C"io3.out"                                       ; create servo pin 0 for BLTouch
                      M558 P9 C"^io3.in" H350 F350 T4800  B1                   ; set Z probe type to bltouch and the dive height + speeds + heater off while probing
                        Phaedrux Moderator @Alucardi
                        @Alucardi said in Duet 3 mini 5+ need help with wiring and config:
                        H350
                        Change that to H5. 350mm dive height is possibly problematic. But maybe not your problem here.
                        So just to recap. You're wired up to io_3 just like in the photo. Your config looks ok for io_3. And your deploy and retract macros look correct.
                        When you power on does the BLTouch do a self test?
                        Does sending M401 and M402 deploy and retract the pin?
                        Does sending G30 deploy the pin?
                        Does touching the pin after doing the G30 stop movement?
                        • Alucardiundefined
                          Alucardi @Phaedrux
                          @Phaedrux
                          When you power on does the BLTouch do a self test? Yes
                          Does sending M401 and M402 deploy and retract the pin? Yes
                          Does sending G30 deploy the pin? Yes it deploys during homing.
                          Does touching the pin after doing the G30 stop movement? It reacts to me pushing it but wont stop bed going up.
                            Then I suspect a bad connection on the white wire to io_3.in. That's the trigger signal wire. Retest continuity. Recrimp it. Make sure it's in the shell properly. Make sure it's on the right pin.
                            As an additional check, please send M98 P"config.g" and report any errors. Also send M558 P9 and see if it reports back what you'd expect.
                            Also post your homeall.g
                            • Alucardiundefined
                              Alucardi @Phaedrux
                              @Phaedrux said in Duet 3 mini 5+ need help with wiring and config:
                              M558 P9
                              Gives me error
                              M558 P9
                              Error: M558: Missing Z probe pin name(s)
                              • Alucardiundefined
                                Alucardi
                                Homeall will be cleaned up and call for separate axels instead but i did it like this when i was trying to config sensorless homeing.
                                M400							; finishes all current moves and and thus clears the buffer
                                M913 X50 Y50 					; drop motor current to 33%
                                M569 P0.0 D3 V60   		 		; reduce V to ensure stealthChop is enabled
                                M569 P0.1 D3 V60   		 		; reduce V to ensure stealthChop is enabled
                                M915 P0.0 S1 R0 F0 H400		; sensitivity X, don’t take action, don’t filter
                                M915 P0.1 S1 R0 F0 H400		; sensitivity Y, don’t take action, don’t filter
                                G91								; relative positioning
                                G1 H1 Z10 F5000	    	   		; lift Z relative to current position
                                G1 H1 X5
                                G4 P300
                                G1 H1 X20 F3000
                                G1 H1 X-400 F3000		   		; move to X
                                G1 H1 Y-5
                                G4 P200
                                G1 H1 Y-20 F3000
                                G1 H1 Y400 F3000 				; move to Y
                                M913 X100 Y100 					; return current to 100%
                                G90                   	  		; absolute positioning
                                G1 X167.5 Y167.5 F5000
                                G30 	  			    		; home Z by probing the bed
                                M402 							; retract probe
                                G1 Z5 F5000
                                M569 P0.0 D2  	    			; restore default for motor
                                M569 P0.1 D2					; restore default for motor
                                  Ok how bout just M558
                                  • Alucardiundefined
                                    Alucardi @Phaedrux
                                    @Phaedrux M558
                                    Error: M558: Z probe 0 not found
                                      Try again after a reboot, and post your entire config.g please.
                                      • Alucardiundefined
                                        Alucardi @Phaedrux
                                        @Phaedrux
                                        now it worked. M558 P9 still give same error though
                                        "m558
                                        Z Probe 0: type 9, input pin io3.in, output pin nil, dive height 350.0mm, probe speed 350mm/min, travel speed 4800mm/min, recovery time 0.00 sec, heaters suspended, max taps 1, max diff 0.03"
                                        G90                                                      ; send absolute coordinates...
                                        M83                                                      ; ...but relative extruder moves
                                        M550 P"Hevo"                                             ; set printer name
                                        M669 K1                                                  ; select CoreXY mode
                                        M552 S1                                                  ; enable network
                                        M586 P0 S1                                               ; enable HTTP
                                        M586 P1 S0                                               ; disable FTP
                                        M586 P2 S0                                               ; disable Telnet
                                        M569 P0.0 S1 D2 	                        	         ; physical drive 0.0 goes forwards
                                        M569 P0.1 S1 D2                      		             ; physical drive 0.1 goes forwards
                                        M569 P0.2 S1 D2                                          ; physical drive 0.2 goes forwards
                                        M569 P0.3 S1 D2                                          ; physical drive 0.3 goes forwards
                                        M569 P0.4 S1 D2                                          ; physical drive 0.4 goes forwards
                                        M584 X0.0 Y0.1 Z0.2:0.3 E0.4                             ; set drive mapping
                                        M350 E16 I0	                                             ; configure microstepping without interpolation
                                        M350 X16 Y16 Z8 I1                                       ; configure microstepping with interpolation
                                        M92 X160.00 Y160.00 Z1600.00 E407.00                     ; set steps per mm
                                        M566 X380.00 Y380.00 Z20.00 E4000.00                     ; set maximum instantaneous speed changes (mm/min)
                                        M203 X12000.00 Y12000.00 Z500.00 E4000.00                ; set maximum speeds (mm/min)
                                        M201 X1200.00 Y1200.00 Z300.00 E5000.00                  ; set accelerations (mm/s^2)
                                        M906 X900 Y900 Z1200 E450 I30           	             ; set motor currents (mA) and motor idle factor in per cent
                                        M84 S30                                                  ; Set idle timeout
                                        M208 X0 Y0 Z-0.5 S1                                      ; set axis minima
                                        M208 X330 Y343 Z450 S0                                   ; set axis maxima
                                        M671 X-45:380 Y170:170 S1								 ; leadscrew positions
                                        M574 X1 S3                                               ; configure sensorless endstop for high end on X
                                        M574 Y2 S3                                               ; configure sensorless endstop for high end on Y
                                        M574 Z1 S2                                               ; configure Z-probe endstop for low end on Z
                                        G31 P500 X25 Y-20 Z0.85                                  ; set Z probe trigger value, offset and trigger height
                                        M557 X25:310 Y25:310 P6                                  ; define mesh grid + Probe points
                                        M308 S0 P"temp0" Y"thermistor" T100000 B4138             ; configure sensor 0 as thermistor on pin temp0
                                        M950 H0 C"out0" T0                                       ; create bed heater output on out0 and map it to sensor 0
                                        M307 H0 B0 S0.70                                         ; disable bang-bang mode for the bed heater and set PWM limit
                                        M140 H0                                                  ; map heated bed to heater 0
                                        M143 H0 S120                                             ; set temperature limit for heater 0 to 120C
                                        M308 S1 P"temp1" Y"thermistor" T500000 B4723 C1.19622e-7 ; configure sensor 1 as thermistor on pin temp1
                                        M950 H1 C"out1" T1                                       ; create nozzle heater output on out1 and map it to sensor 1
                                        M307 H1 B0 S1.00                                         ; disable bang-bang mode for heater  and set PWM limit
                                        M143 H1 S350                                             ; set temperature limit for heater 1 to 350C
                                        M950 F0 C"out5" Q50                                      ; create fan 0 on pin out5 and set its frequency
                                        M106 P0 C"Hotend fan " S0 H1 T50                         ; set fan 0 name and value. Thermostatic control is turned on
                                        M950 F1 C"out6" Q1000                                    ; create fan 1 on pin out6 and set its frequency
                                        M106 P1 C"Blower" S0 H-1                                 ; set fan 1 name and value. Thermostatic control is turned off
                                        M563 P0 D0 H1 F0 										 ; define tool 0
                                        G10 P0 X0 Y0 Z0 										 ; set tool 0 axis offsets
                                        G10 P0 R0 S0 											 ; set initial tool 0 active and standby temperatures to 0C
                                        M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000"       ; set voltage thresholds and actions to run on power loss
                                          Forget the M558 P9
                                          Please fix the dive height M558 H5
                                          Other than that it's down to the white trigger signal wire on io_3.in
                                          Alucardiundefined 2 Replies Last reply Reply Quote 0
                                          • Alucardiundefined
                                            Alucardi @Phaedrux
                                            @Phaedrux guess it decided to break it self then during me changing the card. I have continuity all the way to under the connector on the blTouch it self down to the end of the connector going into the card.
                                            I will however before i order a new one make a short harness and try it on the bench.
