    BLtouch does not work after changing to DUEX5 board
    2.4k
    • Vetiundefined
      Veti
      try 5 or 7. they are often used for bltouch
        dc42 administrators @Haggan90
        @Haggan90 said in BLtouch does not work after changing to DUEX5 board:
        @Veti Yes of course, which heater do I need to disable if I wan to use PWM_2?
        Try disabling heater 7 and use PWM5 on the DueX, that's a common combination.
        Haggan90undefined 2 Replies Last reply Reply Quote 0
        • Haggan90undefined
          Haggan90 @dc42
          @dc42 Thank you, I will try that!
          • Haggan90undefined
            Haggan90 @dc42
            @dc42 said in BLtouch does not work after changing to DUEX5 board:
            Do I need to change anything more then this: M307 H7 A-1 C-1 D-1 ?
            And remove the M307 from config-override.g
              You'll also have to update your deploy and retract macros to reference the new pin number as well.
              Haggan90undefined 1 Reply Last reply Reply Quote 0
              • Haggan90undefined
                Haggan90 @Phaedrux
                @Phaedrux Should that be M280 P5 S10 then?
                  P7 for heater pin 7
                  By the way using pins gets a lot easier in RRF3. Might be time to consider updating.
                  • Haggan90undefined
                    Haggan90 @Phaedrux
                    @Phaedrux Right now I just want the printer to work again, been down for almost a year now 😕
                    Changing to heater 7 did not work, still the same problem..
                      Please post the current version of your config.g, config-override.g, deploy and retract macros, and please double check which pin you're connected to. And refresh me on which wires are going where.
                      • Haggan90undefined
                        Haggan90 @Phaedrux
                        @Phaedrux Ok!
                        Config.g
                        G21												; work in millimeters
                        G90                                             ; Send absolute coordinates...
                        M83                                             ; ...but relative extruder moves
                        M552 S1                                         ; Enable network
                        M586 P0 S1                                      ; Enable HTTP
                        M586 P1 S0                                      ; Disable FTP
                        M586 P2 S0                                      ; Disable Telnet
                        M584 X6 Y1 Z2:5:4 E3							; set 3 Z drivers
                        M569 P1 S0                                      ; Drive 1 goes backwards
                        M569 P2 S0                                      ; Drive 2 goes backwards
                        M569 P3 S1                                      ; Drive 3 goes forwards
                        M569 P4 S1                                      ; Drive 4 goes forwards
                        M569 P5 S0                                      ; Drive 5 goes backwards
                        M569 P6 S1                                      ; Drive 6 goes forwards
                        M669 K0 Y-1.005:1:0:							; set Y to react with X
                        ; Defining X and Y coordinates of the leadscrews
                        M671 X-80:580:580 Y245:490:0 S5 				; leadscrews at front right, rear right and middle left
                        M350 U16 X16 Y16 E16 Z16 I1                    	; Configure microstepping with interpolation
                        M92  X133.33 Y242.00 Z200 E415.00      			; Set steps per mm
                        M566 X900.00 Y900.00 Z20.00 E200.00		     	; Set maximum instantaneous speed changes (mm/min)
                        M203 X15000.00 Y15000.00 Z600.00 E3600.00		; Set maximum speeds (mm/min)
                        M201 X1000.00 Y1000.00 Z30.00 E3000		     	; Set accelerations (mm/s^2)
                        M906 X1000.00 Y1500.00 Z1000.00 E700.00 I30 	; Set motor currents (mA) and motor idle factor in per cent
                        M84 S30                                         ; Set idle timeout
                        ;Energize Z steppers
                        M906 I100 										; prevent idle current reduction
                        G91 											; relative mode
                        G1 S2 Z0.1 										; energize all 3 motors
                        G90 											; absolute mode
                        M208 X0 Y0 Z0 S1                       	 		; Set axis minima
                        M208 X500 Y500 Z750 S0                 			; Set axis maxima
                        M574 X1 S0										; Set active low endstops
                        M574 Y2 S1                               		; Set active high endstops
                        ; Pressure advance
                        M572 D0 S0.05
                        ; BLTouch - Heaters
                        M307 H7 A-1 C-1 D-1 							; Disable the Heater7 to free up PWM channel 5 on the Duex board
                        M574 Z1 S2 										; Define Z to use Probe. Home to Min.
                        M558 P9 H5 F100 T2000							; Set Z probe type/mode 9.
                        G31 P50 X0 Y73.8 Z2.55							; Z probe trigger value, offset in relation to nozzle. And trigger height adjustment
                        M557 X0:500 Y0:400 S100							; define mesh grid
                        M140 H-1 					; Disable heated bed
                        ;M305 P0 T100000 B4138 R4700                    ; Set thermistor + ADC parameters for heater 0
                        ;M143 H0 S120                                   ; Set temperature limit for heater 0 to 120C
                        M305 P1 T100000 B4138 R4700                     ; Set thermistor + ADC parameters for heater 1
                        M143 H1 S280                                   	; Set temperature limit for heater 1 to 280C
                        M106 P0 S0 I0 F600 H-1                        	; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
                        M106 P1 S1 I0 F500 H1 T45                       ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
                        M563 P0 D0 H1 F0                                ; tool 0 uses extruder 0 and heater 1
                        G10 P0 X0 Y0 Z0 R0 S0                           ; set tool 0 offsets and temperatures
                        M501;
                        Config-override.g
                        0:/sys/config-override.g
                        ; config-override.g file generated in response to M500
                        ; Heater model parameters
                        M307 H0 A90.0 C700.0 D10.0 S1.00 V0.0 B1
                        M307 H1 A351.8 C150.9 D9.0 S0.80 V24.4 B0
                        M307 H2 A340.0 C140.0 D5.5 S1.00 V0.0 B0
                        M307 H4 A340.0 C140.0 D5.5 S1.00 V0.0 B0
                        M307 H5 A340.0 C140.0 D5.5 S1.00 V0.0 B0
                        M307 H6 A340.0 C140.0 D5.5 S1.00 V0.0 B0
                        G10 L2 P1 X0.00 Y0.00 Z0.00 U0.00
                        G10 L2 P2 X0.00 Y0.00 Z0.00 U0.00
                        G10 L2 P3 X0.00 Y0.00 Z0.00 U0.00
                        G10 L2 P4 X0.00 Y0.00 Z0.00 U0.00
                        G10 L2 P5 X0.00 Y0.00 Z0.00 U0.00
                        G10 L2 P6 X0.00 Y0.00 Z0.00 U0.00
                        G10 L2 P7 X0.00 Y0.00 Z0.00 U0.00
                        G10 L2 P8 X0.00 Y0.00 Z0.00 U0.00
                        G10 L2 P9 X0.00 Y0.00 Z0.00 U0.00
                        My Duet
                        Send code...
                        Status
                        Idle
                        Tool Position
                        X
                        0.0
                        Y
                        0.0
                        Z
                        0.10
                        Extruder Drives
                        Drive 0
                        0.0
                        Speeds
                        Requested Speed
                        0 mm/s
                        Top Speed
                        0 mm/s
                        Sensors
                        Vin
                        24.5 V
                        MCU Temperature
                        33.2 C
                        Fan RPM
                        0
                        Z-Probe
                        0
                         Tools
                         Extra
                         Control All
                        Tool	Heater	Current	Active	Standby
                        Tool 0
                        T0 - Load Filament	Heater 1
                        off	22.1 C
                        0
                        0
                        Temperature Chart
                        System Directory
                        deploy
                        ; deployprobe.g
                        ; called to deploy a physical Z probe
                        ; generated by RepRapFirmware Configuration Tool v2 on Tue Nov 20 2018 21:58:16 GMT+0100 (centraleuropeisk normaltid)
                        M280 P7 S10
                        Retract
                        ; retractprobe.g
                        ; called to retract a physical Z probe
                        M280 P7 S90
                          Does the BLTouch do a self test at power on?
                          Does sending M401 and M402 deploy and retract the pin?
                          • Haggan90undefined
                            Haggan90 @Phaedrux
                            @Phaedrux said in BLtouch does not work after changing to DUEX5 board:
                            No it does not.
                            Nothing hapends at all.. The bltouch just lights constantly red.
                            • Haggan90undefined
                              Haggan90
                              This is my M122
                              M122
                              RepRapFirmware for Duet 2 WiFi/Ethernet version 2.05.1 running on Duet WiFi 1.02 or later + DueX5
                              Board ID: 08DGM-956GU-DJMSJ-6JTDD-3S86L-1APHG
                              Used output buffers: 3 of 24 (20 max)
                              Static ram: 25712
                              Dynamic ram: 93624 of which 0 recycled
                              Exception stack ram used: 296
                              Never used ram: 11440
                              Tasks: NETWORK(ready,628) HEAT(blocked,1232) DUEX(suspended,160) MAIN(running,3736) IDLE(ready,160)
                              Owned mutexes:
                              Last reset 00:18:03 ago, cause: power up
                              Last software reset time unknown, reason: User, spinning module GCodes, available RAM 11400 bytes (slot 2)
                              Error status: 0
                              Free file entries: 10
                              SD card longest block write time: 18.2ms, max retries 0
                              MCU temperature: min 26.5, current 35.2, max 35.5
                              Supply voltage: min 24.3, current 24.5, max 24.8, under voltage events: 0, over voltage events: 0, power good: yes
                              Driver 5: standstill, SG min/max not available
                              Driver 6: standstill, SG min/max not available
                              Driver 7: standstill, SG min/max not available
                              Date/time: 2021-01-19 20:58:36
                              Cache data hit count 3312721499
                              Slowest loop: 35.52ms; fastest: 0.07ms
                              Hiccups: 0, FreeDm: 160, MinFreeDm: 159, MaxWait: 162ms
                              === DDARing ===
                              Scheduled moves: 1, completed moves: 1, StepErrors: 0, LaErrors: 0, Underruns: 0, 0
                              Bed heaters = -1 -1 -1 -1, chamberHeaters = -1 -1
                              Segments left: 0
                              Movement lock held by null
                              http is idle in state(s) 0
                              telnet is idle in state(s) 0
                              file is idle in state(s) 0
                              serial is idle in state(s) 0
                              aux is idle in state(s) 0
                              daemon is idle in state(s) 0
                              queue is idle in state(s) 0
                              Code queue is empty.
                              === Network ===
                              Slowest loop: 102.91ms; fastest: 0.00ms
                              HTTP sessions: 1 of 8
                              - WiFi -
                              Network state is running
                              WiFi firmware version 1.23
                              WiFi MAC address bc:dd:c2:53:09:3f
                              WiFi Vcc 3.32, reset reason Turned on by main processor
                              WiFi flash size 4194304, free heap 25824
                              WiFi IP address 192.168.1.214
                              WiFi signal strength -78dBm, reconnections 0, sleep mode modem
                                Hmm. That's a bit strange.
                                Can you try removing the Duex entirely and connect the BLTouch directly to the Duet to test? You can use the same config if you connect to heater pin 7 on the expansion port.
                                Normally the BLtouch will perform a self test when connected to 5v.
                                What version of BLTouch is it?
                                Haggan90undefined DIY-O-Sphereundefined 2 Replies Last reply Reply Quote 0
                                • Haggan90undefined
                                  Haggan90 @Phaedrux
                                  @Phaedrux The strange thing is that it worked perfect when I used a duex2 board...
                                  Could there be anything wrong with the firmware on this new duex5? I have not updated any firmware after I installed it.
                                  • DIY-O-Sphereundefined
                                    DIY-O-Sphere @Phaedrux
                                    But he has to invert signal in deploy and retract....
                                    Edit:
                                    M280 P7 S10 I1
                                    M280 P7 S90 I1
                                    (UTC+1)
                                      This post is deleted!
                                        Phaedrux Moderator @DIY-O-Sphere
                                        @DIY-O-Sphere said in BLtouch does not work after changing to DUEX5 board:
                                        Edit:
                                        M280 P7 S10 I1
                                        M280 P7 S90 I1
                                        Yes of course, when using the Duet expansion header directly it must be inverted. Thanks.
                                        • Haggan90undefined
                                          Haggan90 @Phaedrux
                                          @Phaedrux Tried it and still the same thing, nothing happends but red LED
                                            Can you try connecting it to a different 5v source?
                                            Does the pin move freely if you pull it out by hand?
                                            Maybe check the pin itself by removing the grub screw at the top and sliding the pinout entirely. Sometimes cleaning it and reseating it can help.
