    BLtouch does not work after changing to DUEX5 board
    2.4k
    • Haggan90undefined
      Haggan90
      This is my M122
      M122
      RepRapFirmware for Duet 2 WiFi/Ethernet version 2.05.1 running on Duet WiFi 1.02 or later + DueX5
      Board ID: 08DGM-956GU-DJMSJ-6JTDD-3S86L-1APHG
      Used output buffers: 3 of 24 (20 max)
      Static ram: 25712
      Dynamic ram: 93624 of which 0 recycled
      Exception stack ram used: 296
      Never used ram: 11440
      Tasks: NETWORK(ready,628) HEAT(blocked,1232) DUEX(suspended,160) MAIN(running,3736) IDLE(ready,160)
      Owned mutexes:
      Last reset 00:18:03 ago, cause: power up
      Last software reset time unknown, reason: User, spinning module GCodes, available RAM 11400 bytes (slot 2)
      Error status: 0
      Free file entries: 10
      SD card longest block write time: 18.2ms, max retries 0
      MCU temperature: min 26.5, current 35.2, max 35.5
      Supply voltage: min 24.3, current 24.5, max 24.8, under voltage events: 0, over voltage events: 0, power good: yes
      Driver 5: standstill, SG min/max not available
      Driver 6: standstill, SG min/max not available
      Driver 7: standstill, SG min/max not available
      Date/time: 2021-01-19 20:58:36
      Cache data hit count 3312721499
      Slowest loop: 35.52ms; fastest: 0.07ms
      Hiccups: 0, FreeDm: 160, MinFreeDm: 159, MaxWait: 162ms
      === DDARing ===
      Scheduled moves: 1, completed moves: 1, StepErrors: 0, LaErrors: 0, Underruns: 0, 0
      Bed heaters = -1 -1 -1 -1, chamberHeaters = -1 -1
      Segments left: 0
      Movement lock held by null
      http is idle in state(s) 0
      telnet is idle in state(s) 0
      file is idle in state(s) 0
      serial is idle in state(s) 0
      aux is idle in state(s) 0
      daemon is idle in state(s) 0
      queue is idle in state(s) 0
      Code queue is empty.
      === Network ===
      Slowest loop: 102.91ms; fastest: 0.00ms
      HTTP sessions: 1 of 8
      - WiFi -
      Network state is running
      WiFi firmware version 1.23
      WiFi MAC address bc:dd:c2:53:09:3f
      WiFi Vcc 3.32, reset reason Turned on by main processor
      WiFi flash size 4194304, free heap 25824
      WiFi IP address 192.168.1.214
      WiFi signal strength -78dBm, reconnections 0, sleep mode modem
        Hmm. That's a bit strange.
        Can you try removing the Duex entirely and connect the BLTouch directly to the Duet to test? You can use the same config if you connect to heater pin 7 on the expansion port.
        Normally the BLtouch will perform a self test when connected to 5v.
        What version of BLTouch is it?
        Haggan90undefined DIY-O-Sphereundefined 2 Replies Last reply Reply Quote 0
        • Haggan90undefined
          Haggan90 @Phaedrux
          @Phaedrux The strange thing is that it worked perfect when I used a duex2 board...
          Could there be anything wrong with the firmware on this new duex5? I have not updated any firmware after I installed it.
          • DIY-O-Sphereundefined
            DIY-O-Sphere @Phaedrux
            @Phaedrux said in BLtouch does not work after changing to DUEX5 board:
            But he has to invert signal in deploy and retract....
            Edit:
            M280 P7 S10 I1
            M280 P7 S90 I1
            (UTC+1)
              This post is deleted!
                Phaedrux Moderator @DIY-O-Sphere
                @DIY-O-Sphere said in BLtouch does not work after changing to DUEX5 board:
                Edit:
                M280 P7 S10 I1
                M280 P7 S90 I1
                Yes of course, when using the Duet expansion header directly it must be inverted. Thanks.
                Haggan90undefined 1 Reply Last reply Reply Quote 0
                • Haggan90undefined
                  Haggan90 @Phaedrux
                  @Phaedrux Tried it and still the same thing, nothing happends but red LED
                    Can you try connecting it to a different 5v source?
                    Does the pin move freely if you pull it out by hand?
                    Maybe check the pin itself by removing the grub screw at the top and sliding the pinout entirely. Sometimes cleaning it and reseating it can help.
                    • Haggan90undefined
                      Haggan90 @Phaedrux
                      I'm not sure what version it is but it's the one with a metal pin.
                      Yes, the pin moves freely and I have tried adjusting the grub screw.
                        Is it a version with a trace to cut?
                        • Haggan90undefined
                          Haggan90 @Phaedrux
                          No ther's no trace.
                          Just tried to re-crimp all the cables.. no success..
                            Just to confirm, you are now testing with just the Duet using heater pin 7 on the expansion header? And your deploy/retract commands are M280 P7 S10 I1 and M280 P7 S90 I1?
                            • Haggan90undefined
                              Haggan90 @Phaedrux
                              Yes correct.
                              The bltouch acts just the same, light up constant red.
                                I'm beginning to think your BLTouch may be failed.
                                • Haggan90undefined
                                  Haggan90 @Phaedrux
                                  Dammit... couldn't there be any other reason for the bltouch to light up red all the time?
                                    Photo of the BLTouch? It doesn't have a trace to cut, but it also has a metal pin, so perhaps it's a very old version that requires the resistor?
                                    It was working on a Duex2? Do you still have the Duex2 to test with to see if it works there again?
                                    If you really need to return to printing you could set the probe type to 0 and use manual probing. M558 P0
                                    • Haggan90undefined
                                      Haggan90 @Phaedrux
                                      Problem is that I manage to connect 12VDC to 5VDC and burned the duex2 🙂
                                      I manage to fix the DuetWIFI but not the Duex2, that's why I bought a new Duex5. 20210119_204733.jpg
                                        Phaedrux Moderator @Haggan90
                                        @Haggan90 said in BLtouch does not work after changing to DUEX5 board:
                                        The BLTouch is on 5v as well...
                                        • Haggan90undefined
                                          Haggan90 @Phaedrux
                                          Well... that's something I had NOT thought of >.<
                                          But how is it still lighting up?
                                            Well the led is still getting 5v but I think maybe the logic portion got fried.
                                            Haggan90undefined 2 Replies Last reply Reply Quote 1
