    amps for steppers
    343
    • hotrodfordundefined
      hotrodford
      I have and bondtech ddx extruder and it need 0.7 amps just want to make sure
      I adjusted it right.
      "Due to the fact that the DDX uses a 3:1 gearing ratio and includes a stepper motor that is rated to run at 0.7A, nearly half of the current stock "
      M906 X800 Y800 Z800 E700 I30
      Also when the print ends it backs the filament all the way out. how can I adjust that?
      Thanks
      Vetiundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
        jay_s_uk
        if the maximum current is 700ma, you should be setting a value that is roughly 85% of that value. i.e. 595ma (which i think will get rounded up to 600ma)
        • Vetiundefined
          Veti @hotrodford
          @hotrodford said in amps for steppers:
          that would be configured in the slicer normally.
            Phaedrux Moderator @hotrodford
            Change your slicer to use relative extruder moves instead of absolute extrusion.
            • fmaundefined
              fma
              Sorry to hijack this thread, but it is correlated : what is max current given in motors datasheets? RMS or peak? And so, what does 85% represent?
              Frédéric
                jay_s_uk @fma
                @fma 85% of peak
                • fmaundefined
                  fma
                  To be sure to understand: I have to set the RMS current of the driver to be 85% of peak current of the motor?
                  And the motors datasheets give peak current per phase?
                  Frédéric
                  • Dougal1957undefined
                    Dougal1957 @fma
                    @fma that depends on the motor manufacturer for example OMC afaik use peak but LDO use RMS.
                    • fmaundefined
                      fma
                      Ok, thanks!
                      Frédéric
