    Endstops unstable and EMERGENCY STOP NOT STOPPING EXT.BOARD ???
    616
    • jrocklandundefined
      jrockland
      Also endstops on extension board are ignored when homing after a print.
      -Yes endstops are connected on the same ext board as the related stepper motors.
        jrockland @dc42
        @dc42 Just realised when I do a M115, it say firmware_version 3.1.1 BUT Firmware_date 2020-05-19.b2. is it right ?
          Can you post the results of M122 so we can see what boards you're talking about?
          jrocklandundefined 2 Replies Last reply Reply Quote -1
            jrockland @Phaedrux
            @Phaedrux m122
            RepRapFirmware for Duet 3 MB6HC version 3.1.1 running on Duet 3 MB6HC v1.01 or later (SBC mode)
            Board ID: 08DJM-956L2-G43S4-6J1F8-3SD6T-9V56D
            Used output buffers: 1 of 40 (16 max)
            Static ram: 154604
            Dynamic ram: 163276 of which 60 recycled
            Exception stack ram used: 224
            Never used ram: 75052
            Tasks: NETWORK(ready,1972) HEAT(blocked,1188) CanReceiv(suspended,3408) CanSender(suspended,1488) CanClock(blocked,1436) TMC(blocked,204) MAIN(running,4952) IDLE(ready,76)
            Owned mutexes:
            Last reset 00:29:43 ago, cause: software
            Last software reset at 2020-12-31 18:49, reason: User, spinning module LinuxInterface, available RAM 74620 bytes (slot 2)
            Software reset code 0x0010 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0444a000 BFAR 0x00000000 SP 0xffffffff Task MAIN
            Error status: 0
            MCU temperature: min 34.1, current 35.2, max 37.0
            Supply voltage: min 24.1, current 24.2, max 24.3, under voltage events: 0, over voltage events: 0, power good: yes
            12V rail voltage: min 12.0, current 12.0, max 12.2, under voltage events: 0
            Driver 0: standstill, reads 1982, writes 14 timeouts 0, SG min/max 0/0
            Driver 1: standstill, reads 1982, writes 14 timeouts 0, SG min/max 0/0
            Driver 2: standstill, reads 1983, writes 14 timeouts 0, SG min/max 0/0
            Driver 3: standstill, reads 1983, writes 14 timeouts 0, SG min/max 0/0
            Driver 4: standstill, reads 1983, writes 14 timeouts 0, SG min/max 0/0
            Driver 5: standstill, reads 1984, writes 14 timeouts 0, SG min/max 0/0
            Date/time: 2020-12-31 20:31:34
            Slowest loop: 6.29ms; fastest: 0.14ms
            === Storage ===
            Free file entries: 10
            === MainDDARing ===
            Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
            === AuxDDARing ===
            Bed heaters = -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamberHeaters = -1 -1 -1 -1
            Segments left: 0
            Movement lock held by null
            HTTP* is ready with "M122" in state(s) 0
            Telnet is idle in state(s) 0
            File is idle in state(s) 0
            USB is idle in state(s) 0
            Aux is idle in state(s) 0
            Queue is idle in state(s) 0
            LCD is idle in state(s) 0
            SBC is idle in state(s) 0
            Daemon* is idle in state(s) 0
            Aux2 is idle in state(s) 0
            Code queue is empty.
            === Network ===
            Slowest loop: 0.66ms; fastest: 0.01ms
            HTTP sessions: 0 of 8
            • Ethernet -
              State: disabled
              Error counts: 0 0 0 0 0
              === CAN ===
              Messages sent 23204, longest wait 1ms for type 6018
              === Linux interface ===
              State: 0, failed transfers: 0
              Last transfer: 16ms ago
              RX/TX seq numbers: 45704/29677
              SPI underruns 0, overruns 0
              Number of disconnects: 0
              Buffer RX/TX: 0/0-0
              === Duet Control Server ===
              Duet Control Server v3.1.1
              Code buffer space: 4096
              Full transfers per second: 33.53
              jrockland @Phaedrux
              @Phaedrux So I managed to get my expension board to actually update to the last version, and none of my 6hc. half is giving me duet3_sbciap_mb6hc.bin canot be find, other half doest update. (I have 3 machines running 6hc + exp)
                jrockland @dc42
                @dc42 your 3.2 cant be installed on any of my board. tried every way possible and it always fail.
                I did a hard reset with bossa using the last firmware and now I have a dead machine. "DSC isnt started".
                • oliofundefined
                  oliof
                  Sounds like your raspberry pi is not up and running
                  jrocklandundefined 1 Reply Last reply Reply Quote 0
                    jrockland @oliof
                    @oliof would be hard to do all those update since im working directly on it -_-"
                    I also connected it to my other board and it work so it is from the board 100%.
                    Most useless comment yet.
                      jrockland
                      Ill mark this one as "solved" for now as obviously it didnt update right, and start one about why I cant update ??
                      Multisaftundefined 1 Reply Last reply Reply Quote 0
                      • Multisaftundefined
                        Multisaft @jrockland
                        @jrockland I had the same problem therefor I installed 3.1.1 fw package on both, hc6 and on hc3. After this the update package 3.2 did properly updated both boards.
                        Maybe u need to do this also.
