    Nozzle rams into bed when not near center
    761
    • deltwalrusundefined
      deltwalrus @Phaedrux
      @Phaedrux said in Nozzle rams into bed when not near center:
      Include your homedelta.g and bed.g as well as the out put put M122 and M98 P"config.g" please.
      homedelta.g bed.g
      M122
      RepRapFirmware for Duet 2 WiFi/Ethernet version 2.05.1 running on Duet WiFi 1.02 or later
      Board ID: 08DGM-917DA-G4MSJ-6JTD6-3S86L-19N7A
      Used output buffers: 3 of 24 (6 max)
      Static ram: 25712
      Dynamic ram: 92664 of which 336 recycled
      Exception stack ram used: 392
      Never used ram: 11968
      Tasks: NETWORK(ready,764) HEAT(blocked,1232) MAIN(running,3816) IDLE(ready,160)
      Owned mutexes:
      Last reset 00:02:19 ago, cause: power up
      Last software reset at 2021-01-20 13:59, reason: User, spinning module GCodes, available RAM 11944 bytes (slot 3)
      Error status: 0
      Free file entries: 10
      MCU temperature: min 2.6, current 8.6, max 8.7
      Supply voltage: min 12.7, current 12.8, max 13.0, under voltage events: 0, over voltage events: 0, power good: yes
      Driver 0: standstill, SG min/max 0/378
      Driver 1: standstill, SG min/max 0/391
      Driver 2: standstill, SG min/max 0/369
      Date/time: 2021-01-20 15:47:44
      Cache data hit count 413972580
      Slowest loop: 3.60ms; fastest: 0.06ms
      Hiccups: 0, FreeDm: 160, MinFreeDm: 154, MaxWait: 126689ms
      === DDARing ===
      Scheduled moves: 5, completed moves: 5, StepErrors: 0, LaErrors: 0, Underruns: 0, 0
      Heater 1 is on, I-accum = 0.0
      Segments left: 0
      Movement lock held by null
      http is idle in state(s) 0
      telnet is idle in state(s) 0
      file is idle in state(s) 0
      serial is idle in state(s) 0
      aux is idle in state(s) 0
      daemon is idle in state(s) 0
      queue is idle in state(s) 0
      Code queue is empty.
      === Network ===
      Slowest loop: 15.46ms; fastest: 0.00ms
      HTTP sessions: 1 of 8
      - WiFi -
      Network state is running
      WiFi firmware version 1.23
      WiFi MAC address 60:01:94:2e:12:42
      WiFi Vcc 3.38, reset reason Turned on by main processor
      WiFi flash size 4194304, free heap 23648
      WiFi IP address 192.168.1.36
      WiFi signal strength -55dBm, reconnections 0, sleep mode modem
      M98 P"config.g"
      HTTP is enabled on port 80
      FTP is disabled
      TELNET is disabled
      Have you seen these?
      https://duet3d.dozuki.com/Wiki/Calibrating_a_delta_printer
      https://duet3d.dozuki.com/Wiki/ConfiguringRepRapFirmwareDeltaPrinter
      I have read them and followed them, yes.
        Cura start gcode?
        deltwalrusundefined 1 Reply Last reply Reply Quote 0
          Cura start gcode?
          G32          ; auto-calibration
          G21          ; metric values
          G90          ; absolute positioning
          M107         ; start with the fan off
          G92 E0       ; zero the extruded length
          G1 F4000 E3  ; extrude 3mm of feed stock
          G92 E0       ; zero the extruded length again
          G1 F{speed_travel}
            Thanks. I'm not a delta user, so I can't really see anything that is obvious to my eyes, but at least we now have all your relevant files posted so someone with a better feel for deltas might spot something off.
            • garyd9undefined
              garyd9
              Contrary to many (most?) other duet (+ smart effector) delta users, I do NOT include G32 in my slicer's start gcode. I've found that, depending on the filament in use, the bit of ooze from the nozzle can impact the calibration negatively.
              What I typically do is, whenever I change the filament to something that requires different heating parameters, I heat the bed and plate to what new filament requires, clean the nozzle (cleaning filament, then wire brush the nozzle until there's no oozing whatsoever) and manually run G32 a few times until the deviation values are consistent, and then save that to config-override.g (via M500.)
              (I have the re-running of G32 automated via conditional gcode, but it's best to do everything manually until you understand what's going on.)
              Then in my slicer config, I use G28 (to just home the printer) before it starts printing.
                dc42 administrators @deltwalrus
                @deltwalrus, please run G29 after auto calibration and shown us the resulting height map.
                  deltwalrus
                  G29
                  89 points probed, min error -0.240, max error 0.062, mean -0.035, deviation 0.046
                  heightmap.csv
                  • Vetiundefined
                    Veti
                    the picture please
                      deltwalrus
                      Sorry about that.
                      • Vetiundefined
                        Veti
                        did you use M500 to save the calibration or did you put the values in config.g?
                          deltwalrus
                          I did not run an M500 immediately after running the mesh grid compensation, no. I wasn't aware that was necessary, I figured it stored that information automatically after it ran. Thanks for the tip on that.
                          I will run another auto-calibration, then another mesh bed compensation routine, then I will run an M500 and try the print again.
                          As a side note, is there ever an instance where you would not want to store the results of a calibration or mesh bed routine? Shouldn't that be done automatically (in a macro maybe)?
                          Phaedruxundefined Vetiundefined 2 Replies Last reply Reply Quote 0
                            deltwalrus
                            No change in behaviour after running calibration, G29, M500, then starting print. Nozzle hits the bed near the "top left" part of the print, starts to actually rotate the glass bed with it, and even managed to dislodge one of the magnetic arms from the ball before the emergency stop halted the motion and reset the board.
                              deltwalrus
                              This post is deleted!
                                Phaedrux Moderator @deltwalrus
                                @deltwalrus said in Nozzle rams into bed when not near center:
                                It does, but only while the printer is powered on. The values are lost after a power cycle unless they are either saved to config-override.g with M500 and adding M501 to the end of config.g to load it. Or manually copying the resulting calibration command into config.g
                                • Vetiundefined
                                  Veti @deltwalrus
                                  G32 not G29.
                                    deltwalrus
                                    I just got the new mirrors today, will test them for thermal suitability then give the problematic print another go.
                                      deltwalrus
                                      It appears either my old glass plate was warped, or in the process of removing it and installing the mirror I fixed this issue, because a larger print is going right now and the bed ramming seems to be resolved.
                                      Go figure.
