possible error in firmware 3.2x
PanelDue
1.1k
    wummelfrosch
    Hello, since I updated to the 3.2.7 shows my Paneldue 7i 0% on the component fan, even though the fan is running ! On the web interface it is displayed correctly ! The error can only be solved once I set the fan to a desired level on the panel due. from this point on, it then also takes over the correct fan setting at the next fan change in the pressure ! I have now fused on the panel due 3.2.9 and the error is still present ! What could that be? First of all, thank you for your ideas. best regards from Germany
    another funny thing is that since the RRF 3 the component fans continue to run when I pause the print and then break ! I always have to turn it off manually !
    Duet Web Control 3.2.0
    RRF 3.2
    config (1).g
    1.Modified Prusa Style Printer:Duet2 Eth, 24V MW 750W, E3D Chimera+ Dual Wakü, 2x Bondt QR 500mm Bowden, 2x FTS 2.0 Sensor, BLTouch , 15mm CTC Linear Rails Y-Axis, 2xKGT-12x4 Z-Axis,10mm Linear X-Axis, Laing DDC Pump,120mm Radiator 2.Bcn3d Sigma R19
    undefined undefined 2 Replies Last reply 23 Jan 2021, 00:09 Reply Quote 0
      garyd9 @wummelfrosch
      @wummelfrosch said in possible error in firmware 3.2x:
      For the issue of the fans (and heaters) staying on after canceling, you can create a cancel.g file to turn things off. Just use "M106 S0" to turn off the fan. Here's an example that turns off the bed heater, current tool heater and current tool fan:
      M106 S0 ; turn off the current tool part fan
      M104 S0 ; turn off the current tool heater
      M140 S0 ; turn off the bed heater
      undefined 1 Reply Last reply 23 Jan 2021, 14:43 Reply Quote 1
        User3D @wummelfrosch
        @wummelfrosch I too feel paneldue's new version has bugs. In my case, after running following code my view used to refresh itself. But now it kinda stucks. even though temperature is set and is rising but it is not reflected on screen.
        M104 S205 T0
        M109 S205 T0
        M140 S60
        M190 S60
        undefined 1 Reply Last reply 12 Feb 2021, 10:09 Reply Quote 0
          wummelfrosch @garyd9
          @garyd9
          ok thank you ! such variant already came to my mind , I would have tried it over the pause.g :-), but I would have thought that such a thing should also go automatically in the RRF 3.2 🙂
          I will adapt it
            wummelfrosch
            Hello, is there already a solution for the component fan problem ? Can I do something wrong? at felt one of 10 print it goes and at all other .. Not.
            I slice with s3D
            even if I manually set the fan on the Panel Due it often does not work !
            undefined 1 Reply Last reply 12 Feb 2021, 10:08 Reply Quote 0
              wilriker @wummelfrosch
              @wummelfrosch Sorry, I missed that thread before. In versions of PanelDueFirmware 3.2.6 there was a change that it will only show the fan speed of the first fan of the currently selected tool. In the just released 3.2.10 it will fall-back to fan 0 in case there is no tool selected. Can you please check if this solves your problem? If not, please post your config.g so I can try to reproduce it.
              Also have you assigned the fan to your tool with M563 Pnn Fnn where Pnn is your tool number and Fnn is the fan number (unless it's 0)?
              Manuel
              My Tool Collection
              undefined undefined 2 Replies Last reply 12 Feb 2021, 21:30 Reply Quote 0
                wilriker @User3D
                @User3D said in possible error in firmware 3.2x:
                Which version of RRF are you using? This was a known issue in RRF 3.2-beta versions but has been fixed since.
                Manuel
                My Tool Collection
                undefined 1 Reply Last reply 15 Feb 2021, 04:49 Reply Quote 0
                  wummelfrosch @wilriker
                  @wilriker
                  Hello, thank you for the answer. I've tested it and it's not working. I used the latest RRF and until the update of the Panel Due Firmware it still went. I have to say that I use a Chimera Dual Wakü Hotend and always use both component fans, i.e. right and left at the same time. The firmware was created with the Config tool. In the Config.g, the fans are assigned to both tools ( (F 0:1) ! I need no Hotend fan because i use Wakü. That has always been the case and I haven't changed anything about it.
                  config (2).g
                  I will try the new Firmware bundle 3.2.2 🙂
                  undefined 1 Reply Last reply 12 Feb 2021, 21:54 Reply Quote 0
                    @wummelfrosch Thanks, I'll check your config next week - unless you report meanwhile that your issue magically disappeared. 😉
                    Manuel
                    My Tool Collection
                    undefined 1 Reply Last reply 15 Feb 2021, 18:41 Reply Quote 0
                      User3D @wilriker
                      @wilriker using RRF version - 3.3beta
                      undefined 1 Reply Last reply 15 Feb 2021, 09:36 Reply Quote 0
                        wilriker @User3D
                        @User3D I put this on the list to investigate. But for clarification, this is (if at all) a problem with RepRapFirmware. PanelDueFirmware is only a passive consumer of status updates and if RepRapFirmware does not send them PanelDueFirmware cannot process them.
                        Manuel
                        My Tool Collection
                          @wilriker
                          Hello, nothing changes even after the update to rrf3.2.2. However, I have now noticed the following : if I print with tool 1 it goes ! only with tool2 it is not possible ! I think that could help a lot in the solution. maybe I can fix it with the slicer startcode ?
                          undefined 1 Reply Last reply 16 Feb 2021, 14:47 Reply Quote 0
                            @wummelfrosch I found the issue. The reason is that you have both fans assigned to both tools and when PD sees an update for fan 0 (it only looks at the first fan of each tool anyway) it will search for the tool that this fan is assigned to and will find tool 0 but since tool 0 is not the current tool it will discard this value.
                            Manuel
                            My Tool Collection
                            undefined 1 Reply Last reply 16 Feb 2021, 14:58 Reply Quote 1
                              @wilriker
                              oh super... Thank you very much. Just how can I solve you best? as written above I always need both fans, no matter which tool I'm using
                              undefined 1 Reply Last reply 16 Feb 2021, 15:04 Reply Quote 0
                                @wummelfrosch You cannot solve it, I have to fix it in the firmware (in fact I already did so but need to release it after testing).
                                For version 3.3 a revised fan handling is planned so you can control all fans of all tools in all situations. But no work in this direction has yet been implemented.
                                Manuel
                                My Tool Collection
                                undefined 1 Reply Last reply 16 Feb 2021, 15:10 Reply Quote 0
                                  @wilriker said in possible error in firmware 3.2x:
                                  ok thank you. I wait for v 3.3 and would be happy if this change is implemented then 🙂
                                  undefined 1 Reply Last reply 16 Feb 2021, 15:11 Reply Quote 0
                                    @wummelfrosch I will do a 3.2.11 probably tomorrow before I start working on 3.3.0-beta1.
                                    Manuel
                                    My Tool Collection
                                    undefined 1 Reply Last reply 16 Feb 2021, 15:14 Reply Quote 2
                                      @wilriker
                                      Great ! I will test it and give you a feeedback again 🙂
                                        wummelfrosch
                                        @wilriker
                                        at first... sorry for the delay of my reply, because there are a lot of work in business and at home 🙂
                                        I have testing the Firmware 3.2.11 and it seems to work fine for me 🙂
                                        Thank you
                                          gnydick @wilriker
                                          @wilriker there is a "Tool Fan" slider I'm the DWC that controls all of the fans for a tool. Why doesn't the due show that instead?
