Solved possible error in firmware 3.2x
@wummelfrosch Thanks, I'll check your config next week - unless you report meanwhile that your issue magically disappeared.
@wilriker using RRF version - 3.3beta
@User3D I put this on the list to investigate. But for clarification, this is (if at all) a problem with RepRapFirmware. PanelDueFirmware is only a passive consumer of status updates and if RepRapFirmware does not send them PanelDueFirmware cannot process them.
@wilriker
Hello, nothing changes even after the update to rrf3.2.2. However, I have now noticed the following : if I print with tool 1 it goes ! only with tool2 it is not possible ! I think that could help a lot in the solution. maybe I can fix it with the slicer startcode ? -
@wummelfrosch I found the issue. The reason is that you have both fans assigned to both tools and when PD sees an update for fan 0 (it only looks at the first fan of each tool anyway) it will search for the tool that this fan is assigned to and will find tool 0 but since tool 0 is not the current tool it will discard this value.
@wilriker
oh super... Thank you very much. Just how can I solve you best? as written above I always need both fans, no matter which tool I'm using -
@wummelfrosch You cannot solve it, I have to fix it in the firmware (in fact I already did so but need to release it after testing).
For version 3.3 a revised fan handling is planned so you can control all fans of all tools in all situations. But no work in this direction has yet been implemented.
@wilriker said in possible error in firmware 3.2x:
ok thank you. I wait for v 3.3 and would be happy if this change is implemented then
@wummelfrosch I will do a 3.2.11 probably tomorrow before I start working on 3.3.0-beta1.
Great ! I will test it and give you a feeedback again
@wilriker
at first... sorry for the delay of my reply, because there are a lot of work in business and at homeI have testing the Firmware 3.2.11 and it seems to work fine for me
Thank you
@wilriker there is a "Tool Fan" slider I'm the DWC that controls all of the fans for a tool. Why doesn't the due show that instead?
Closing due to inactivity.
