    Dual Z-axis endstops
    89
    19.9k
      I can think of two potential solutions, both requiring firmware changes:
      1. Implement support for multiple Z homing switches directly in firmware, so you don't need to configure additional axes. This is what I had planned before I realised that you could do it using additional axes.
      2. Add a facility to specify a number of displayed axes that is lower than the total number of configured axes.
      In the meantime, you could avoid the risk of moving only one Z axis by mapping the U axis to a non-existent motor except during Z homing
      • efficientAFundefined
        efficientAF
        Are there any updates to official firmware that has support for this? If not, would it be possible to use a macro to temporarily reassign drivers, home both sides, then revert back to the assignments in config.g (or manually copy and paste those settings into the macro)?
        I'm hoping to avoid the need to have extra axes controls that can be messed with on accident or the need to mod the firmware to mitigate this. Plus, I only intend to perform this action once at startup, not before each print since I want to level my gantry and let my probe handle normal homing. Once current is applied to the motors I shouldn't need to do this again.
          Firmware 1.19beta6 will support hidden axes. So you will be able to use the U axis for the second motor during homing, but the user interface will not provide a Home U button, nor jog controls for the U axis.
          The firmware changes for this are already implemented, but not tested yet.
            efficientAF
            Marvelous! I think I'm on 1.17 so I'm due for an update! I only see the beta5 on github, is there somewhere I can get the latest? Is there any documentation on the new functionality and how to setup?
              1.19beta6 will be released when I have tested it. The M584 command has a new optional parameter P which specifies the maximum number of visible axes. So if you use M584 to create a U axis but also specify P3 in that command then the U axis will be hidden.
                efficientAF
                Ahh, I'll keep an eye out for that and let you know if I have any questions, thanks David!
                • dintidundefined
                  dintid
                  Is the dual Z-endstops implemented, or going to be implemented in 1.19, or do we use the solution you outlined below?
                  I'm homing to Z-max using 2 independent motors and want them to "sync up" when homing, as all sorts of things can happen to make them go out of sync.
                  @dc42:
                  I expect to implement multiple Z homing switches in firmware 1.19. In the meantime I think you can achieve the same thing as follows:
                  1. Put this command in config.g:
                  M584 X0 Y1 Z2:3 U3 E4
                  This assigns your second Z motor (connected to the E0 motor output) to both the Z and U axes.
                  2. In your homez.g file, do this:
                  M584 Z2
                  G1 S1 Zxxx Uxxx
                  G92 Zxxx
                  M584 Z2:3
                  This splits Z into the Z and U axes, homes them simultaneously, and then restores normal Z movement. Fill in the xxx values to suit your machine - see https://duet3d.com/wiki/Configuring_RepRapFirmware_for_a_Cartesian_printer#Homing_files.
                  3. Change the Z homing section of homeall.g to do the same.
                  4. Connect the second Z endstop switch (the one you use for the U motor) to the E0 endstop input.
                  Test the above carefully, with low motor current and a hand on the power switch, in case I have forgotten something.
                  RepRapFirmware supported G-codes: https://duet3d.com/wiki/G-code
                    The advice remains the same for now, except the detail has changed. I now suggest the following:
                    M584 X0 Y1 Z2:3 U9 E4 P3
                    This assigns your second Z motor (connected to the E0 motor output) to the Z axis, and creates a U axis that uses driver 9 (which I am assuming is not connected to any motor). The P3 parameter limits the number of visible axes to 3 in firmware 1.19beta6 and later, so that the U axis is not visible in the user interface.
                    M584 Z2 U3
                    G1 S1 Zxxx Uxxx
                    G92 Zxxx
                    M584 Z2:3 U9
                    Assuming that driver 9 is not connected, assigning the U axis to it other than during Z homing prevents inadvertent movement of the U motor if a G1 command with a U parameter is executed.
                    • dintidundefined
                      dintid
                      I Just need to add some config to make it go back from z-max (where my bed is homing currently) to z-min and use a probe to get the right distance from nozzle to bed 🙂
                      • SpeedyDadundefined
                        SpeedyDad
                        This may be a stupid question but when doing this, I assume you move the extruder to the E1 connector?
                          @SpeedyDad:
                          You can either use the E0 motor output for the second Z motor and E1 for the extruder (which is what I assumed in the config examples I gave above), or vice versa. Just tell the firmware which way round you have them in the M584 command.
                            SpeedyDad
                            Thanks
                            • FrankNPrinterundefined
                              FrankNPrinter
                              yes there are several FT5 owners running dual home z. I am still waiting to see if going to 1 z motor and linking the 2 z axis would be a better option. I have Duet WIFI so if i don't, i will eatu p my extra extruder spot if I split Z. In series you only get half the power any way so not sure if there is an up side to 2 motors in series? I know we talked about that briefly, your thoughts are always appreciated DC42! (https://www.youtube.com/watch?v=askVj4_5f9c)
                                If you connect two Z motors in series, you don't lose torque at low speeds. Each provides the same torque that a single motor would at the same current setting. However, the maximum speed you can run the motors at before the torque starts dropping is halved. This isn't normally a problem because high Z speeds are not required.
                                Firmware 1.19beta9 includes most of the implementation of bed leveling using multiple Z motors connected to individual drivers.
                                  SpeedyDad
                                  This works great. Implemented it on my big machine and I no longer have to worry if one side sags at idle. The only oddity I've noticed is that regardless of how long the machine has been on or if the Z has already been homed, when I home the Z axis from full height, the right side is hitting the endstop before the left side by about 2 seconds. However, once I have homed it and take it back to Z0, I can do a G0 to run the machine down to 10mm above the endstop and then slowly manually move it down and the hit together. Then if I run it to Z0 and home again, same 2 second lag. Must have a digit out of place somewhere. Steps are set the same. Hmmmmm.
                                  For reference, this machine is like an Ultimaker but about twice the size so Z0 is up.
                                    SpeedyDad
                                    Got it homing evenly now. just mirrored all the settings for Z to U in the config file.
                                      I'm glad you sorted it!
                                        SpeedyDad
                                        I think it was the steps
                                          Bear in mind that in firmware 1.19beta10, an alternative to using dual Z endstops now is to use auto bed levelling to adjust your 2 leadscrews independently to get the bed level after homing.
                                          • kazolarundefined
                                            kazolar
                                            I am considering using my 2 lead screws independently also, since I can add driver 12 to the LCD connector.
                                            Your example shows assigning U axis to an unconnected driver, which in my case there will be none. So how would I configure dual lead screw (don't have auto bed leveling setup yet – I will add that in after I get the basics configured)
                                            This is what I have now:
                                            M584 X0 Y1 U2 V3 W4 A5 E6:7:8:9 Z10
                                            so if I were to add 11 it would change to
                                            M584 X0 Y1 U2 V3 W4 A5 E6:7:8:9 Z10:11 then presumably I would define B somehow? would be also 11?
                                            I can remap other axis to -- as in U etc kinda like this:
                                            M584 X0 Y1 V2 W3 A4 B5 E6:7:8:9 Z10:11 -- then I have U freed up as a limit switch on the primary duet as apposed to the expansion board, though I haven't notice any performance difference with 19.11 support for end stops on the expansion board.
                                            Being that I have a large bed and there is the ability to add the 12th driver -- I can drop in another TB6600 and run my 2 lead screws independently.
