Duet2 WiFi Firmware on Raise 3d E2 ?
Firmware installation
10.9k
    Veti
    well people do tend to take some days off between christmas and new years.
      Proschi3D
      But they have answered enough questions from other users. I think it is simply ignored
      Love my Duet 3 Mini.
      https://www.instagram.com/proschi3d
      https://youtube.com/@proschi3d
      https://www.proschi3d.de
        Proschi3D
        Wish you all a healthy and better year 2021
          Proschi3D
          Now I have installed the original Duet firmware.
          The problem now is that the extruder thermistors at 250c are idling. If I then let it heat up to 300c, the temperature display goes backwards
          What could that be?
            Veti
            post the config.g
              Proschi3D
              ; generated by RepRapFirmware Configuration Tool v3.2.2 on Sun Jan 24 2021 10:56:38 GMT+0100 (Mitteleuropäische Normalzeit)
              M550 P"My Printer" ; set printer name
              M569 P0 S0
              M569 P1 S0
              M569 P2 S0
              M569 P3 S1
              M569 P4 S1
              M569 P5 S0 ; physical drive 4 goes forwards
              M584 X0 Y1 Z2 E3:4 U5 ; set drive mapping
              M350 X256 Y256 Z256 E256:256 I0 ; configure microstepping without interpolation
              M92 X1280.00 Y1280.00 Z4000.00 E420.00:420.00 ; set steps per mm
              M566 X480 Y300 U480 Z24 E300:300 ; set maximum instantaneous speed changes (mm/min)
              M203 X9000 U9000 Y9000 Z720 E3000:3000 ; set maximum speeds (mm/min)
              M201 X1000 U1000 Y500 Z100 E3000:3000 ; set accelerations (mm/s^2)
              M906 X900 U900 Y900 Z900 E800:800 I30 ; set motor currents (mA) and motor idle factor in per cent
              M84 S30 ; Set idle timeout
              M208 X-3 Y0 Z0 U35 S1 ; set axis minima
              M208 X327 Y240 Z240 U355 S0 ; set axis maxima
              M574 X1 Y1 U2 S1 ; set active high endstops
              M574 Z2 S1
              M558 X100 P5 H7 F100 T9000 R2 ; set Z probe type to unmodulated and the dive height + speeds
              G31 P2 X15 Y18 Z0.515 ; set Z probe trigger value, offset and trigger height
              M557 X15:335 Y18:245 S80:50 ; define mesh grid
              M305 P0 T100000 B3950 C0 R4700
              M143 H0 S115
              M305 P1 S1 T100000 B4138 C200433 R4700
              M143 H1 S310
              M305 P2 S1 T100000 B4138 C200433 R4700
              M143 H2 S310
              M106 P0 S0 I1 F500 H-1 ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
              M106 P1 S0 I0 F500 H-1 ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned off
              M106 P2 S0 I0 F500 H-1 ; set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned off
              M563 P0 D0 H1 ; define tool 0
              M563 P1 D1 H2 X3 ; define tool 1
              G10 P1 U13.2 Y-0.4 Z0 ; set tool 1 axis offsets
              M563 P2 D0:1 H1:2 X0:3
              M567 P2 E1.0:1.0
              G10 P2 X0 U0 Y0.4 Z0
              G10 P2 R0 S0
              M591 D0 C6 P1 S1
              M591 D1 C7 P1 S1
              M555 P6
              M501
                Veti
                @Proschi78 said in Duet2 WiFi Firmware on Raise 3d E2 ?:
                dont do that, it will overload the cpu. use x16 and interpolation
                that config is wrong. find the correct B and C values in the thermistor documentation.
                which firmware did you install?
                  Proschi3D
                  DUET firmware is v2.05
                  dont do that, it will overload the cpu. use x16 and interpolation?
                  What should I enter?
                  Phaedruxundefined 1 Reply Last reply 24 Jan 2021, 19:25 Reply Quote 0
                    Phaedrux Moderator @Proschi3D
                    M350 X16 Y16 Z16 E16:16 I1
                    Make sure your steps per mm in M92 is correct for x16.
                      Proschi3D
                      This is how it is entered in the original Raise 3D config
                        Don't do that, it will overload the CPU. Use x16 and interpolation instead.
                          Proschi3D
                          Perhaps that was the problem of pausing in printing with the original firmware?
                          undefined 1 Reply Last reply 24 Jan 2021, 19:39 Reply Quote 0
                            Veti @Proschi3D
                            very likely
                              Proschi3D
                              Can I calculate the steps?
                              undefined 1 Reply Last reply 25 Jan 2021, 06:03 Reply Quote 0
                                Veti @Proschi3D
                                https://blog.prusaprinters.org/calculator_3416/
                                undefined 1 Reply Last reply 25 Jan 2021, 06:11 Reply Quote 1
                                  Proschi3D @Veti
                                  M92 X1280.00 Y1280.00 Z4000.00 E420.00:420.00 ; set steps per mm @256
                                  M92 X1280=1280/4=320 ? @16
                                    Veti
                                    256 / 16 = 16
                                    1280 / 16 = 80
                                      Proschi3D
                                      Now I have one more problem. When I go z home the printer moves to the upper limit switch and the pin of the Z probe remains extended
                                        Post your homeall.g
                                        Also, you don't have any steps per mm or microstepping set for the U axis.
                                        undefined 1 Reply Last reply 25 Jan 2021, 21:38 Reply Quote 1
                                          Proschi3D @Phaedrux
                                          @Phaedrux It works now, many thanks for your help. Now I just have to get the Idex to work properly. Single extruder and dual function, only the mirtor mode and duplicate mode not yet
