    Duet2 WiFi Firmware on Raise 3d E2 ?
    Firmware installation
    10.9k
    • Proschi3Dundefined
      Proschi3D
      Now I have installed the original Duet firmware.
      The problem now is that the extruder thermistors at 250c are idling. If I then let it heat up to 300c, the temperature display goes backwards
      What could that be?
      Love my Duet 3 Mini.
      https://www.instagram.com/proschi3d
      https://youtube.com/@proschi3d
      https://www.proschi3d.de
      • Vetiundefined
        Veti
        post the config.g
          Proschi3D
          ; generated by RepRapFirmware Configuration Tool v3.2.2 on Sun Jan 24 2021 10:56:38 GMT+0100 (Mitteleuropäische Normalzeit)
          M550 P"My Printer" ; set printer name
          M569 P0 S0
          M569 P1 S0
          M569 P2 S0
          M569 P3 S1
          M569 P4 S1
          M569 P5 S0 ; physical drive 4 goes forwards
          M584 X0 Y1 Z2 E3:4 U5 ; set drive mapping
          M350 X256 Y256 Z256 E256:256 I0 ; configure microstepping without interpolation
          M92 X1280.00 Y1280.00 Z4000.00 E420.00:420.00 ; set steps per mm
          M566 X480 Y300 U480 Z24 E300:300 ; set maximum instantaneous speed changes (mm/min)
          M203 X9000 U9000 Y9000 Z720 E3000:3000 ; set maximum speeds (mm/min)
          M201 X1000 U1000 Y500 Z100 E3000:3000 ; set accelerations (mm/s^2)
          M906 X900 U900 Y900 Z900 E800:800 I30 ; set motor currents (mA) and motor idle factor in per cent
          M84 S30 ; Set idle timeout
          M208 X-3 Y0 Z0 U35 S1 ; set axis minima
          M208 X327 Y240 Z240 U355 S0 ; set axis maxima
          M574 X1 Y1 U2 S1 ; set active high endstops
          M574 Z2 S1
          M558 X100 P5 H7 F100 T9000 R2 ; set Z probe type to unmodulated and the dive height + speeds
          G31 P2 X15 Y18 Z0.515 ; set Z probe trigger value, offset and trigger height
          M557 X15:335 Y18:245 S80:50 ; define mesh grid
          M305 P0 T100000 B3950 C0 R4700
          M143 H0 S115
          M305 P1 S1 T100000 B4138 C200433 R4700
          M143 H1 S310
          M305 P2 S1 T100000 B4138 C200433 R4700
          M143 H2 S310
          M106 P0 S0 I1 F500 H-1 ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
          M106 P1 S0 I0 F500 H-1 ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned off
          M106 P2 S0 I0 F500 H-1 ; set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned off
          M563 P0 D0 H1 ; define tool 0
          M563 P1 D1 H2 X3 ; define tool 1
          G10 P1 U13.2 Y-0.4 Z0 ; set tool 1 axis offsets
          M563 P2 D0:1 H1:2 X0:3
          M567 P2 E1.0:1.0
          G10 P2 X0 U0 Y0.4 Z0
          G10 P2 R0 S0
          M591 D0 C6 P1 S1
          M591 D1 C7 P1 S1
          M555 P6
          M501
          • Vetiundefined
            Veti
            @Proschi78 said in Duet2 WiFi Firmware on Raise 3d E2 ?:
            dont do that, it will overload the cpu. use x16 and interpolation
            that config is wrong. find the correct B and C values in the thermistor documentation.
            which firmware did you install?
              Proschi3D
              DUET firmware is v2.05
              dont do that, it will overload the cpu. use x16 and interpolation?
              What should I enter?
                Phaedrux Moderator @Proschi3D
                M350 X16 Y16 Z16 E16:16 I1
                Make sure your steps per mm in M92 is correct for x16.
                  Proschi3D
                  This is how it is entered in the original Raise 3D config
                    Don't do that, it will overload the CPU. Use x16 and interpolation instead.
                      Proschi3D
                      Perhaps that was the problem of pausing in printing with the original firmware?
                      • Vetiundefined
                        Veti @Proschi3D
                        very likely
                          Proschi3D
                          Can I calculate the steps?
                          • Vetiundefined
                            Veti @Proschi3D
                            https://blog.prusaprinters.org/calculator_3416/
                            Proschi3Dundefined 1 Reply Last reply Reply Quote 1
                              Proschi3D @Veti
                              M92 X1280.00 Y1280.00 Z4000.00 E420.00:420.00 ; set steps per mm @256
                              M92 X1280=1280/4=320 ? @16
                              • Vetiundefined
                                Veti
                                256 / 16 = 16
                                1280 / 16 = 80
                                  Proschi3D
                                  Now I have one more problem. When I go z home the printer moves to the upper limit switch and the pin of the Z probe remains extended
                                    Post your homeall.g
                                    Also, you don't have any steps per mm or microstepping set for the U axis.
                                      Proschi3D @Phaedrux
                                      @Phaedrux It works now, many thanks for your help. Now I just have to get the Idex to work properly. Single extruder and dual function, only the mirtor mode and duplicate mode not yet
                                        Proschi3D
                                        As expected, the Idex setup did not work;)
                                        Here are my settings
                                        ; Configuration file for Duet WiFi (firmware version 2.00)
                                        ; generated by RepRapFirmware Configuration Tool v3.2.2 on Mon Jan 25 2021 18:31:38 GMT+0100 (Mitteleuropäische Normalzeit)
                                        M575 P1 S1 B57600
                                        M552 S1
                                        G90                                               ; send absolute coordinates...
                                        M83                                               ; ...but relative extruder moves
                                        M569 P0 S0
                                        M569 P1 S1
                                        M569 P2 S0
                                        M569 P3 S1
                                        M569 P4 S1
                                        M350 X128 Y128 U128 Z128 E128:128 I1                 ; configure microstepping without interpolation
                                        M92 X640 Y640 U640 Z6400 E2150:2150     ; set steps per mm
                                        M204 P800 T1500
                                        M574 X1 Y1 U2 S1
                                        M574 Z2 S1                                  ; set active high endstops
                                        M558 X100 P5 H7 F100 T9000 R2 I1                             ; set Z probe type to unmodulated and the dive height + speeds
                                        M305 P0 T100000 B3950 C0 R4700                       ; set thermistor + ADC parameters for heater 0
                                        M143 H0 S120                                      ; set temperature limit for heater 0 to 120C
                                        M305 P1 T100000 B4725 C200433 R4700          ; set thermistor + ADC parameters for heater 1
                                        M143 H1 S320                                      ; set temperature limit for heater 1 to 320C
                                        M305 P2 T100000 B4725 C200433 R4700          ; set thermistor + ADC parameters for heater 2
                                        M143 H2 S320                                      ; set temperature limit for heater 2 to 320C
                                        M106 P0 S0 I0 F500 H-1                            ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
                                        G10 P0 X0 Y0 Z0                                   ; set tool 0 axis offsets
                                        G10 P0 R0 S0                                      ; set initial tool 0 active and standby temperatures to 0C
                                        G10 P1 U0 Y0 Z0                             ; set tool 1 axis offsets
                                        M567 P2 E1.0:1.0
                                        G10 P2 X0 U0 Y0 Z0
                                        G10 P2 R0 S0
                                        M591 D0 C6 P1 S1
                                        M591 D1 C7 P1 S1
                                        ;Idex Setup
                                        M563 P0 D0 H1               S"X" ; define tool X
                                        M563 P1 D1 H2     X3    F2    S"U" ; define tool U
                                        M563 P2 D0:1 H1:2 X0:3  F0:2  S"XU" ; define tool X+U copy mode
                                        G10 P2 X50 Y0 U-50 S0 R0 ; set tool offsets and temperatures
                                        M567 P2 E1:1 ; set mix ratio 100% on both extruders
                                        M555 P6
                                        M501
                                        T0
                                        • Vetiundefined
                                          Veti
                                          you still have not fixed your thermistor setting C200433 is incorrect
                                          Proschi3Dundefined 1 Reply Last reply Reply Quote 0
                                            Proschi3D @Veti
                                            @Veti But it only works with these settings
