    Bricked Duet2 SBC Ethernet
    707
    • smoki3undefined
      smoki3
      I have a problem with my Duet2. Everything started with that the E5 and E6 Heater on my Duex5 was always on. Then I turned off the printer completely and unplugged the Duex5. But the printer is still not starting.
      Then I tried to flash the firmware again. But this also doesn't work. My PC is not detecting the Duet. The VIN, 5V and 3.3V and Diag LED is on as soon I turn on VIN.
      Looks like it is broken completely
        https://duet3d.dozuki.com/Wiki/What_to_do_if_your_Duet_won't_respond
        How far along do you get?
        • smoki3undefined
          smoki3
          Already tried to do this. Already tried to erase everything but this also doesn't work
            Photos of the board? Maybe we can see a blown chip.
            Checked fuses if present?
            Do any chips get hot when connected to USB power and with the SD card removed?
            • smoki3undefined
              smoki3
              The fuses are okay. Already checked them. But as far I know the fuses are only for the power unit not for the programming interface.
              Have to check if chip is gone. I also disconnected everything from the board but this doesn't make any difference.
              • smoki3undefined
                smoki3
                So I disassembled my other duet from another machine and changed it on my broken tool changer.
                It looks like my duex5 is also brocken still the same Heater 5 and 6 not Controllable anymore.
                I did some research that on the duex5 maybe the 74HCT02PW are broken. So I will replace this.
                But how can I fix my Duet2? Or what can be broken?
                • smoki3undefined
                  smoki3
                  IMG_20210126_080404.jpg IMG_20210126_080357.jpg IMG_20210126_080349.jpg IMG_20210126_080337.jpg
                    A Former User @smoki3
                    @smoki3 said in Bricked Duet2 SBC Ethernet:
                    i'd test the mosfets first
                    if the 3.3v rail on the duet is good and the erase jumper doesn't help then make sure the issue isn't usb (port, cable, socket) related before replacing the cpu.
                    the usb port goes directly to the cpu and the bootloader is in rom so bricking usually requires damaging the cpu or usb connection.
                    smoki3undefined 1 Reply Last reply Reply Quote 0
                    • smoki3undefined
                      smoki3 @A Former User
                      @bearer said in Bricked Duet2 SBC Ethernet:
                      The to the fact that the two heater (heater 5 and 6) which are connected to U9 74HCT02PW both are powered on permanently I think the is not a mosfet failure. Unlikely that both fail at a time. I am pretty sure that the 74HCT02PW is broken.
                      So my usb equipment is fine tested with my other duet2 wifi.
                      Is it there a possiblity to flash the cpu via a serial connection to rewrite the bootloader?
                      I looked for the cpu, this costs around 30 euros to get it in germany. I think this is not economically
                      • smoki3undefined
                        smoki3
                        So I managed to get the broken duex5 working again.
                        I desoldered the 74HCT02PW from the broken duet and placed it on the duex5. Now this is working again.
                        But I thing the duet2 is ready for the garbage.
                          Was this a new Duet?
                          When and where was it purchased?
                          Do you suspect a possible short somewhere?
                          • smoki3undefined
                            smoki3 @Phaedrux
                            @Phaedrux
                            No I use it for almost 2 years.
                            I am pretty sure that the CPU is gone
