    BLTouch Config.
    2.3k
    • fcwiltundefined
      fcwilt @Hélder Rocha
      @Hélder-Rocha said in BLTouch Config.:
      I don't know how to allocate the 0.02mm I intend for the 1st layer!
      That is handled by the slicer when it creates a file to be printed.
      I don't find any "Config-Override.g" folder on my system so that I can eliminate any errors that may exist!
      config-override.g is created by the M500 command. That command is often used after heater tuning to save the results in config-override.g.
      To include the information that may be in config-override.g you need to have a M501 at the end of config.g.
      I myself do not use config-override.g - I keep everthing in config.g.
      Please post your
      • config.g
      • homeall.g
      file using the </> tag.
      frederick
      • Hélder Rochaundefined
        Hélder Rocha
        Hi, tks a lot fcwilt, here it goes:
        Config.g:
        ; generated by RepRapFirmware Configuration Tool v2 on Wed Dec 26 2018 13:31:24 GMT+0000 (Hora padrão da Europa Ocidental)
        M111 S0 ; Debugging off
        G21 ; Work in millimetres
        M555 P2 ; Set firmware compatibility to look like Marlin
        M550 P"Cr 10 - S" ; Set machine name
        M552 S1 ; Enable network
        ;*** Access point is configured manually via M587
        M586 P0 S1 ; Enable HTTP
        M586 P1 S0 ; Disable FTP
        M586 P2 S0 ; Disable Telnet
        M569 P0 S0 ; Drive 0 goes backwards
        M569 P1 S0 ; Drive 1 goes backwards
        M92 X80.00 Y80.00 Z408.00 E820.00 ; Set steps per mm Z400
        M566 X600.00 Y600.00 Z24.00 E1200.00 ; Set maximum instantaneous speed changes (mm/min)
        M203 X30000.00 Y30000.00 Z300.00 E1500.00 ; Set maximum speeds (mm/min)
        M201 X1000.00 Y1000.00 Z100.00 E10000.00 ; Set accelerations (mm/s^2)
        M906 X750.00 Y1150.00 Z750.00 E1050.00 I30 ; Set motor currents (mA) and motor idle factor in per cent
        M84 S300 ; Set idle timeout
        M208 X300 Y300 Z400 S0 ; Set axis maxima
        M574 X1 Y1 S1 ; Set active high endstops
        M574 Z1 S2 ; Set endstops controlled by probe
        M307 H3 A-1 C-1 D-1 ; Disable heater on PWM channel for BLTouch
        M558 P9 H5 F120 T6000 A5 S0.02 ; Set Z probe type to bltouch and the dive height + speeds
        G31 P25 X-40 Y-10 Z1.20 ; Set Z probe trigger value, offset and trigger height
        M557 X50:250 Y50:250 S50 ; Define mesh grid
        M305 P0 T100000 B3950 C0 R4700 ; Set thermistor + ADC parameters for heater 0
        M305 P1 T100000 B4725 C7.060000e-8 R4700 ; Set thermistor + ADC parameters for heater 1
        M143 H1 S290 ; Set temperature limit for heater 1 to 290C
        M106 P0 S0 I0 F30 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
        M106 P1 S0.5 I0 F500 H1 T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
        M106 P2 S0 I0 F500 H-1 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned off
        M563 P0 D0 H1 ; Define tool 0
        ; Automatic power saving
        M911 S22 R23 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; Set voltage thresholds and actions to run on power loss
        M912 P0 S-1 ; calibrate MCU Temp
        ; pressure advance
        M572 D0 S0.3 ; pressure advance
        Homeall:
        ; homeall.g
        ; called to home all axes
        G91 ; relative positioning
        M98 Pdeployprobe.g ; deploy mechanical Z probe
        G1 S1 X-305 Y-305 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
        G1 S1 X-305 Y-305 F360 ; move slowly to X and Y axis endstops once more (second pass)
        G90 ; absolute positioning
        G1 X200 Y150 F6000 ; go to first bed probe point and home Z
        ;G91 ; relative positioning
        ;G1 S2 Z5 F100 ; lift Z relative to current position
        ;G90 ; absolute positioning
        M98 Pretractprobe.g ; retract mechanical Z probe
          Hélder Rocha
          what is "file using the </> tag."?
          Stephen6309undefined 1 Reply Last reply Reply Quote 0
          • fcwiltundefined
            fcwilt
            Please get in the habit of using the </> tag.
            Your config.g file using </>
            ; pressure advance
            Your homeall.g file using </>
            I will look at them now.
              Hélder Rocha
              Ok...Tks
              • Stephen6309undefined
                Stephen6309 @Hélder Rocha
                @Hélder-Rocha It's the 5th symbol from the right at the top of the reply dialog.
                • fcwiltundefined
                  fcwilt
                  You are using firmware that is very old.
                  The most recent v2 firmware is v2.05.1 but my memory may be faulty on that.
                  The most recent v3 firmware is v3.2.
                  I suggest you update to at least the most recent v2 firmware.
                  I cannot be sure about your files as I have no idea what those files should look like for v1.21
                    Hélder Rocha
                    Well, Frederick, there´s a big problem right there. Let me see if a find out how is that done, because i am a complete noob on this stuff. 😲
                    • fcwiltundefined
                      I cannot help you with firmware that old.
                      There are special steps that sometimes need to be taken when make a big jump in versions.
                      For example, when I wanted to go from 2.05.1 to 3.1.1 (the most recent v3 at the time) I had to first go to 3.0.0 before I could go to 3.1.1.
                      I'm sure somewhere here can advise you or point you to the need references.
                      Perhaps if you started a new topic regarding your firmware upgrade situation?
                        Can you send M122 and post the response here so we can see what firmware version is actually flashed?
                          Hélder Rocha
                          @fcwilt said in BLTouch Config.:
                          Well i have the V2 2.05.01 at the momment!
                            Hélder Rocha
                            but i ll send the M122 just to check it out
                              Ok, so the config for the BLTouch looks fine for 2.05
                              What problems exactly are you having?
                              Does the Bltouch work to home the Z axis?
                              After homing, does sending the nozzle to Z0 lead to the nozzle just touching the bed surface?
                              If you've gone through the test and calibrate page to set your XYZ offsets, have you now tried running G29 to get a map of your bed surface?
                              https://duet3d.dozuki.com/Wiki/Using_mesh_bed_compensation
                              Hélder Rochaundefined 2 Replies Last reply Reply Quote 1
                                Hélder Rocha @Phaedrux
                                @Phaedrux HI... the problem i am having is that, after i calibrate the offset on G31, defining the 0.0 position etc etc, when i do the first probe, the nozzle gets agaist the bed! If i increase or decrease the z value on the G31, it goes allways agaist the bed! Also, i dont haveproperly constant values when i try to define the z offset! It changes constantly. I read that a anti-backlash nut could help. I dont know!
                                  @Phaedrux Oh, and yes, Bltouch work to home the Z axis.
                                  After homing z, it stays on 5mm plus the z offset value above the bed.
                                  I made all the steps that are on that link you sent and yes, i made also the map. Dont know hou to use it, but yes, i made it!
                                  • Vetiundefined
                                    Veti @Hélder Rocha
                                    do you mean it does not stop when its triggerd.
                                    or the nozzle hits the bed before its triggered?
                                    Hélder Rochaundefined 1 Reply Last reply Reply Quote 0
                                      Hélder Rocha @Veti
                                      @Veti i beleave it stops when triggered, and goes up for 5mm. At this moment the Z offset is marked with 1,90. So, after it makes the probe, Z ascend 5mm, in the panel i can check z height is 6,90 (5mm+1,90)... all good, but if i down it 5mm, it stops on Z 1,90, but against the bed. After slice a test cube, just to see if it runs ok, the nozzle does not get the 0,02 mm height i nead for the fisrt layer, because its touching the bed!! But Veti, i starded to download the new versions of firmware, i all strt over. Lets forget this for now. Different issues just appear. Ill open a different topic. Tks a lot for your help.
                                      • Vetiundefined
                                        Veti
                                        this means that your trigger height is incorrect
                                        • shubharora734undefined
                                          shubharora734
                                          • Vetiundefined
                                            Veti @shubharora734
                                            @shubharora734
                                            so decrease your trigger height by 1,9
