    duet3d sd not detected, rejects http, com5 denied
    2.7k
      And you're using the upload file button?
      Can you post a screen shot of the error?
      radcadundefined 1 Reply Last reply Reply Quote 0
      • radcadundefined
        radcad @Phaedrux
        @Phaedrux
        what file format do i need to save the screen shot as to upload it here?
          If you're on windows you can use the print screen button on your keyboard and paste that into paint and save it as a jpeg.
          • radcadundefined
            radcad
            • radcadundefined
              radcad
              I kept retrying it over and over and eventually it uploaded.
              trying to get the 2nd file to load now. it wont get past the 4th file tho
              WiFi module is connected to access point 111111 IP address 11111111
              Trying to connect at 230400 baud: success
              Erasing 4096 bytes...
              Erasing 212992 bytes...
              Uploading file...
              5% complete
              10% complete
              15% complete
              20% complete
              25% complete
              30% complete
              35% complete
              40% complete
              45% complete
              50% complete
              55% complete
              60% complete
              65% complete
              70% complete
              75% complete
              80% complete
              85% complete
              90% complete
              95% complete
              Upload successful
              • radcadundefined
                radcad
                2nd file finally uploaded
                  Are you uploading the zip file as is? Don't extract it first.
                  • radcadundefined
                    radcad @Phaedrux
                    @Phaedrux
                    Im not unzipping it. I go to upload the file it fails.... upload file it fails...
                    upload the file it loads 1/17 then fails... upload again 2/17 then fails and eventually it loads all the files then updates. usually between files Im having to wait some time to try the next file or it doesn't work at all.
                    im working on the 3rd zip now
                    Im having more trouble with the 3rd then the first 2
                    I can only get it to 5 / 55 files before failing
                      When and where did you purchase the Duet?
                      Uploading the zip files shouldn't be this painful. Could be SD card writing problem or it could be the wifi module.
                      • radcadundefined
                        radcad @Phaedrux
                        @Phaedrux
                        i just got it a few days ago and i ordered it from matter hackers because the duet page was sold out.
                          Did the last zip file finally upload successfully?
                          If you go to the general and machine specific tabs in the DWC what versions are shown for the firmware and web interface? 3.2?
                          Are you able to upload a sliced gcode file to the gcodes tab successfully?
                          • radcadundefined
                            radcad
                            No I still have not gotten it to load yet.
                            • radcadundefined
                              radcad
                              is there another way to do this ? maybe through YAT. it keeps saying network error.
                              • radcadundefined
                                radcad
                                I called the cable company and complained about my connection and they did some reset test that took several minutes, after that i was able to upload the 3rd file with no issue at all.
                                so what do i do next
                                  Ok, so now you have reliable access to the web interface of the Duet?
                                  You're now on 3.2?
                                  You'll need a config file set to get going now.
                                  https://configtool.reprapfirmware.org/Start
                                  Try and fill out the pages to the best of your knowledge. Ask if you have any questions.
                                  At the end you'll be able to download a zip file with all of the config files. Do that and then upload that zip file to the system tab as well. After it reboots you can do some careful testing for motor movement, homing, heaters, fans, etc.
                                  • radcadundefined
                                    radcad
                                    yes 3.2 is installed
                                    • radcadundefined
                                      radcad @Phaedrux
                                      @Phaedrux I have a ender 3 pro but I put a dual z motor on it. is there anything special i need to set up on the config?
                                      I also have a upgraded heated-bed and use a 500c Nova hotend.
                                      it came with a daughter board RTD 100 but im not sure how to hook it up. or what options to select in the config.
                                        Dual Z motors can either be used with the existing dual connector on the board with no special config needed, or if you want to use two separate drivers for each Z motor for lead screw leveling you can do that too, but will need to be added manually. See here: https://duet3d.dozuki.com/Wiki/Bed_levelling_using_multiple_independent_Z_motors
                                        @radcad said in duet3d sd not detected, rejects http, com5 denied:
                                        500c Nova hotend.
                                        I'm not sure what that is. Do you have any documentation for it? Or a link to it? Photo?
                                        • radcadundefined
                                          radcad @Phaedrux
                                          @Phaedrux
                                          This is the hotend 500 C capable and claims to be unclogging
                                          https://3dpassion.com/nova
                                          I currently have the second Z plugged into the second port. I don't need any special z movements.
                                          This is the daughter board for the hotend that is 500c
                                          https://duet3d.dozuki.com/Wiki/Connecting_PT100_temperature_sensors
                                            Then you don't need to do anything special for the Z axis. Just treat it as a single motor z axis.
                                            For the PT100 you can choose the PT100 sensor in the config tool. (bottom of the sensor dropdown list)
