    Firmware restart while refreshing DWC and pausing
    880
    • felekundefined
      felek
      @Phaedrux My mistake. Can you change category to Firmware Developers?
        Phaedrux Moderator @felek
        @felek said in Firmware restart while refreshing DWC and pausing:
        First of all, I don't want to go to firmware 3.x because 2.x works fine for me.
        Except for the bug you mean?
        I also suspect that firmware 3.x is vulnerable.
        I don't understand. What is vulnerable?
        2.05 is over a year old now. All work on RRF2 has stopped and moved to RRF3. The bug you've found is likely fixed in 3.2.
        If you still have access to DWC. Upload these 3 zip files, one at a time. Don't extract them. Reboot after each. Use M115 to verify the firmware has been applied.
        https://github.com/Duet3D/RepRapFirmware/releases/download/3.0/Duet2and3Firmware-3.0.zip
        https://github.com/Duet3D/RepRapFirmware/releases/download/3.2/Duet2and3Firmware-3.2.zip
        That will get your firmware and DWC up to date.
        For your config, might be a good idea to run through the configurator tool and generate a fresh set for RRF3.
        https://configtool.reprapfirmware.org/Start
        felekundefined 1 Reply Last reply Reply Quote 0
        • felekundefined
          felek @Phaedrux
          @Phaedrux Thanks!
          So, I've updated RepRap firmware(3.2), PanelDue(3.2.9) and DWC(3.2.0) in standalone mode (without SBC)
          I put micro SD card to the PanelDue and started simulation. After a few seconds I lost DWC communication and main board rebooted. I tested different sd cards, cables and it doesn't work.
          I repeated this a few times and firmware still reboot.
          External SD card is slow but it shouldn't cause a reboot.
          config.g
          ; generated by RepRapFirmware Configuration Tool v3.1.10 on Sat Dec 05 2020 19:46:54 GMT+0100 (Central European Standard Time)
          G90                                           ; send absolute coordinates...
          M83                                           ; ...but relative extruder moves
          M550 P"TT Sapphire"                        ; set printer name
          M669 K1                                       ; select CoreXY mode
          M552 P192.168.60.14						; Set IP address
          M553 P255.255.255.0						; Set Netmask
          M552 S1								; Turn network on
          M575 P1 B57600 S1					; Turn PanelDue on
          M569 P0 S0                                    ; physical drive 0 goes forwards
          M569 P1 S0                                    ; physical drive 1 goes forwards
          M569 P2 S0                                    ; physical drive 2 goes forwards
          M569 P3 S0                                    ; physical drive 3 goes forwards
          M584 X0 Y1 Z2 E3                              ; set drive mapping
          M350 X32 Y32 Z32 E16 I1                       ; configure microstepping with interpolation
          M92 X160.60 Y160.60 Z3200.00 E392.40          ; set steps per mm
          M566 X800.00 Y800.00 Z60.00 E420.00 P1      ; set maximum instantaneous speed changes (mm/min)
          M203 X18000.00 Y18000.00 Z1200.00 E30000.00   ; set maximum speeds (mm/min)
          M201 X2500.00 Y2500.00 Z200.00 E10000.00      ; set accelerations (mm/s^2)
          M204 P2000 T4000							  ; set acceleration for printing moves
          M906 X1200 Y1200 Z1200 E800 I50               ; set motor currents (mA) and motor idle factor in per cent
          M84 S30                                       ; Set idle timeout
          M208 X0 Y0 Z0 S1                              ; set axis minima
          M208 X223 Y223 Z235 S0                        ; set axis maxima
          M574 X1 S1 P"!xstop"
          M574 Y2 S1 P"!ystop"
          M574 Z1 S1 P"!zstop"                           ; configure active-high endstop for low end on Z via pin zstop
          M558 P1 C"zprobe.in" H5 F120 T6000            ; set Z probe type to unmodulated and the dive height + speeds
          G31 P500 X0 Y0 Z2.5                           ; set Z probe trigger value, offset and trigger height
          M557 X15:215 Y15:195 S20                      ; define mesh grid
          M308 S0 P"bedtemp" Y"thermistor" T100000 B4138    ; configure sensor 0 as PT1000 on pin bedtemp
          M950 H0 C"bedheat" T0                         ; create bed heater output on bedheat and map it to sensor 0
          M307 H0 B0 S1.00                              ; disable bang-bang mode for the bed heater and set PWM limit
          M140 H0                                       ; map heated bed to heater 0
          M143 H0 S120                                  ; set temperature limit for heater 0 to 120C
          M308 S1 P"e0temp" Y"thermistor" T100000 B4138     ; configure sensor 1 as thermistor on pin e0temp
          M950 H1 C"e0heat" T1                          ; create nozzle heater output on e0heat and map it to sensor 1
          M307 H1 B0 S1.00                              ; disable bang-bang mode for heater  and set PWM limit
          M143 H1 S280                                  ; set temperature limit for heater 1 to 280C
          M950 F0 C"fan0" Q500                          ; create fan 0 on pin fan0 and set its frequency
          M106 P0 S0 H-1                                ; set fan 0 value. Thermostatic control is turned off
          M950 F1 C"fan1" Q500                          ; create fan 1 on pin fan1 and set its frequency
          M106 P1 S1 H-1                                ; set fan 1 value. Thermostatic control is turned off
          M563 P0 D0 H1 F0                              ; define tool 0
          G10 P0 X0 Y0 Z0                               ; set tool 0 axis offsets
          G10 P0 R0 S0                                  ; set initial tool 0 active and standby temperatures to 0C
          M501                                          ; load saved parameters from non-volatile memory
          M593 F51	  	; cancel ringing at 51Hz
          ;M572 D0 S0.7
          M122 after reboot
          RepRapFirmware for Duet 2 WiFi/Ethernet version 3.2 running on Duet Ethernet 1.02 or later
          Board ID: 0JD0M-9P6M2-NWNS4-7J1DG-3S86K-9A1RL
          Used output buffers: 3 of 24 (15 max)
          Static ram: 23460
          Dynamic ram: 68656 of which 0 recycled
          Never used RAM 19964, free system stack 208 words
          Tasks: NETWORK(ready,186) HEAT(blocked,331) MAIN(running,474) IDLE(ready,19)
          Owned mutexes:
          Last reset 00:00:13 ago, cause: software
          Last software reset at 2021-01-29 10:32, reason: StuckInSpinLoop, GCodes spinning, available RAM 19964, slot 1
          Software reset code 0x4083 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0040080f BFAR 0xe000ed38 SP 0x20003424 Task IDLE Freestk 33 ok
          Stack: 00454679 004550bc 61000000 a5a5a5a5 00454679 a5a5a5a5 a5a5a5a5 20003e04 0000714e 200046e8 20001804 20003440 200046e0 00000004 2000cbe0 2000cbe0 20003440 2000cbd8 00000001 200034a0 4e49414d 00000000 00000000 00000001 00000000 00000001 00000003
          Error status: 0x00
          Aux0 errors 0,0,0
          MCU temperature: min 41.8, current 42.3, max 42.5
          Supply voltage: min 1.7, current 1.7, max 1.8, under voltage events: 0, over voltage events: 0, power good: no
          Driver 0: position 0, ok, SG min/max not available
          Driver 1: position 0, ok, SG min/max not available
          Driver 2: position 0, ok, SG min/max not available
          Driver 3: position 0, ok, SG min/max not available
          Driver 4: position 0, ok, SG min/max not available
          Driver 5: position 0
          Driver 6: position 0
          Driver 7: position 0
          Driver 8: position 0
          Driver 9: position 0
          Driver 10: position 0
          Driver 11: position 0
          Date/time: 2021-01-29 10:32:39
          Cache data hit count 20356317
          Slowest loop: 3.95ms; fastest: 0.13ms
          === Storage ===
          Free file entries: 10
          SD card longest read time 3.2ms, write time 0.0ms, max retries 0
          === MainDDARing ===
          === AuxDDARing ===
          Segments left: 0
          Movement lock held by null
          HTTP is idle in state(s) 0
          Telnet is idle in state(s) 0
          File is idle in state(s) 0
          USB is idle in state(s) 0
          Aux is idle in state(s) 0
          Trigger is idle in state(s) 0
          Queue is idle in state(s) 0
          LCD is idle in state(s) 0
          Daemon is idle in state(s) 0
          Code queue is empty.
          === Network ===
          Slowest loop: 6.41ms; fastest: 0.01ms
          HTTP sessions: 1 of 8
          Interface state active, link 100Mbps full duplex
          • Vetiundefined
            Veti
            how are you powering the duet?
            • felekundefined
              felek @Veti
              @Veti I test setup on my desk
              • Vetiundefined
                Veti
                have you tested with a real power supply?
                also
                this is not valid for the duet 2. interpolation only works at x16
                felekundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
                • felekundefined
                  felek @Veti
                  @Veti I removed I1 from config.g
                  I tested on 3d printer and It still ocurrs
                  Simulation works fine on 2.05.1 firmware, however there is issue when I want to load DWC (or refres).
                  M122
                  RepRapFirmware for Duet 2 WiFi/Ethernet version 3.2 running on Duet WiFi 1.02 or later
                  Board ID: 0JD0M-9K662-MGPSS-6J1FJ-3SN6M-9SSUW
                  Used output buffers: 5 of 24 (11 max)
                  Static ram: 23460
                  Dynamic ram: 73392 of which 0 recycled
                  Never used RAM 15228, free system stack 193 words
                  Tasks: NETWORK(ready,179) HEAT(blocked,295) MAIN(running,452) IDLE(ready,19)
                  Owned mutexes:
                  Last reset 00:00:11 ago, cause: software
                  Last software reset at 2021-01-29 11:37, reason: StuckInSpinLoop, GCodes spinning, available RAM 15228, slot 0
                  Software reset code 0x4083 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f80f BFAR 0xe000ed38 SP 0x20003424 Task IDLE Freestk 33 ok
                  Stack: 00454679 004550bc 61000000 a5a5a5a5 00454679 a5a5a5a5 a5a5a5a5 20003eac 00012d50 200046e8 20001804 20003440 200046e0 00000004 20001140 20001140 20003440 20001138 00000001 200034a0 4e49414d 00000000 00000000 00000001 00000000 00000001 00000003
                  Error status: 0x00
                  Aux0 errors 0,0,0
                  MCU temperature: min 22.1, current 22.8, max 22.9
                  Supply voltage: min 24.1, current 24.1, max 24.3, under voltage events: 0, over voltage events: 0, power good: yes
                  Driver 0: position 0, standstill, SG min/max not available
                  Driver 1: position 0, standstill, SG min/max not available
                  Driver 2: position 0, standstill, SG min/max not available
                  Driver 3: position 0, standstill, SG min/max not available
                  Driver 4: position 0, standstill, SG min/max not available
                  Date/time: 2021-01-29 11:37:47
                  Cache data hit count 12795529
                  Slowest loop: 99.99ms; fastest: 0.20ms
                  === Storage ===
                  SD card longest read time 0.8ms, write time 0.0ms, max retries 0
                  === MainDDARing ===
                  === AuxDDARing ===
                  Segments left: 0
                  === Network ===
                  Slowest loop: 39.85ms; fastest: 0.00ms
                  - WiFi -
                  Network state is active
                  WiFi firmware version 1.25beta0
                  WiFi MAC address 40:f5:20:3a:0b:d7
                  WiFi Vcc 3.29, reset reason Power up
                  WiFi flash size 4194304, free heap 22048
                  WiFi IP address 192.168.1.28
                  WiFi signal strength -75dBm, mode 802.11n, reconnections 0, sleep mode modem
                  Clock register 00002002
                  • felekundefined
                    felek
                    I tried to print but duet rebooted
                    AFAIK when duet has issue with external SD card it should indicate error like: "Cannot read file, error code X"
                    29.01.2021, 12:00:41: m122: === Diagnostics ===
                    Used output buffers: 3 of 24 (14 max)
                    Static ram: 23460
                    Never used RAM 15228, free system stack 189 words
                    Tasks: NETWORK(ready,186) HEAT(blocked,309) MAIN(running,452) IDLE(ready,19)
                    Owned mutexes: WiFi(NETWORK)
                    Last reset 00:00:35 ago, cause: software
                    Last software reset at 2021-01-29 11:59, reason: StuckInSpinLoop, PrintMonitor spinning, available RAM 15192, slot 0
                    Software reset code 0x4089 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f80f BFAR 0xe000ed38 SP 0x20003424 Task IDLE Freestk 33 ok
                    Stack: 00454679 004550bc 61000000 a5a5a5a5 00454679 a5a5a5a5 a5a5a5a5 20004334 0005f2d0 200046e8 20001804 20003440 200046e0 00000004 2000cbe0 2000cbe0 20003440 2000cbd8 00000001 200034a0 4e49414d 00000000 00000000 00000001 00000000 00000001 00000002
                    Error status: 0x00
                    Aux0 errors 0,0,0
                    MCU temperature: min 24.7, current 25.5, max 25.8
                    Supply voltage: min 24.0, current 24.1, max 24.3, under voltage events: 0, over voltage events: 0, power good: yes
                    Date/time: 2021-01-29 12:00:41
                    Cache data hit count 42753898
                    Slowest loop: 96.96ms; fastest: 0.20ms
                    === Storage ===
                    SD card longest read time 0.5ms, write time 0.0ms, max retries 0
                    === MainDDARing ===
                    === AuxDDARing ===
                    Segments left: 0
                    === Network ===
                    Slowest loop: 39.81ms; fastest: 0.00ms
                    - WiFi -
                    WiFi flash size 4194304, free heap 24616
                    WiFi signal strength -72dBm, mode 802.11n, reconnections 0, sleep mode modem
                      Please post the GCode file that caused the reset when you simulated it.
                      felekundefined 2 Replies Last reply Reply Quote 0
                      • felekundefined
                        felek @dc42
                        @dc42 This file is quite big
                        https://www.dropbox.com/s/twebf0ajjvn0bdd/moon6inches.gcode?dl=0
                        • felekundefined
                          felek @dc42
                          @dc42 I was digging in the firmware in order to find solution. I have no idea why Network task cannot Give SD0 mutex when external SD is simulating. It is happen when refresh DWC. Firmware want to send all files to the browser and it got stuck in void NetworkResponder::SendData()
                          I also don't have old releases duet PCB with JTAG socket so I'm not able to use debugger.
                            Phaedrux Moderator @Veti
                            @Veti said in Firmware restart while refreshing DWC and pausing:
                            @felek Rather than remove the I1 to stop the interpolation, better to use x16 microstepping with interpolation enabled to begin with.
                            PanelDue(3.2.9)
                            Would you be able to test again with PanelDue 1.24?
                            • felekundefined
                              felek @Phaedrux
                              @Phaedrux Ok, I changed microstepping to 16 and enabled interpolation.
                              Here is my config.g:
                              M552 S1                                       ; enable network
                              M586 P0 S1                                    ; enable HTTP
                              M586 P1 S1                                    ; enable FTP
                              M586 P2 S0                                    ; disable Telnet
                              ;M350 X32 Y32 Z32 E16 I1	                      ; configure microstepping with interpolation
                              M350 X16 Y16 Z16 E16 I1	                      ; configure microstepping with interpolation
                              ;M572 D0 S0.7
                              I downgraded PanelDue. Now I'm using 1.24 version but the issue still exist.
                              Here is M122:
                              Used output buffers: 3 of 24 (11 max)
                              Static ram: 23460
                              Never used RAM 15228, free system stack 195 words
                              Tasks: NETWORK(ready,182) HEAT(blocked,295) MAIN(running,466) IDLE(ready,19)
                              Last reset 00:00:19 ago, cause: software
                              Last software reset at 2021-02-01 09:45, reason: StuckInSpinLoop, GCodes spinning, available RAM 15192, slot 1
                              Software reset code 0x4083 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f80f BFAR 0xe000ed38 SP 0x20003ea4 Task MAIN Freestk 641 ok
                              Stack: 0042885f 0042885e 21060000 3f800000 00000000 41200000 3d20a0a1 40f6fb48 44e0f026 44e0f026 3dbdae8d 44e0f026 3ca0a0a1 00000000 00000000 00000000 38533333 3f800000 3f800000 60000010 200025a8 000773d0 200025a8 20000f0c 200025a8 200025b8 200025b2
                              Error status: 0x00
                              Aux0 errors 0,0,0
                              MCU temperature: min 19.9, current 20.8, max 21.1
                              Supply voltage: min 24.1, current 24.2, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes
                              Date/time: 2021-02-01 09:46:30
                              Cache data hit count 22936358
                              Slowest loop: 2.95ms; fastest: 0.20ms
                              === Storage ===
                              SD card longest read time 0.7ms, write time 0.0ms, max retries 0
                              === MainDDARing ===
                              === AuxDDARing ===
                              Segments left: 0
                              === Network ===
                              Slowest loop: 139.39ms; fastest: 0.00ms
                              - WiFi -
                              WiFi flash size 4194304, free heap 21968
                              WiFi signal strength -70dBm, mode 802.11n, reconnections 0, sleep mode modem
                              • felekundefined
                                felek
                                @Phaedrux
                                Here is different reset reason:
                                Static ram: 23460
                                Never used RAM 15228, free system stack 200 words
                                Tasks: NETWORK(ready,192) HEAT(blocked,309) MAIN(running,448) IDLE(ready,19)
                                Last reset 00:00:25 ago, cause: software
                                Last software reset at 2021-02-01 09:51, reason: HardFault bfarValid precise, PrintMonitor spinning, available RAM 15228, slot 1
                                Software reset code 0x4069 HFSR 0x40000000 CFSR 0x00008200 ICSR 0x0441f803 BFAR 0x9d03b488 SP 0x200043c0 Task MAIN Freestk 968 ok
                                Stack: 20020000 00000000 2000444f 9d03b470 00000046 0041fbb5 00428840 610e0000 bf800000 00000000 3edb6db7 b8ac9c00 3331bb4c 40000000 3f317200 b5ddea0e 388a851a bb35d196 3d5dbc4d 00000000 00000000 38533333 00000000 00000000 60000010 200025a8 0007a0e7
                                Error status: 0x00
                                Aux0 errors 0,0,0
                                MCU temperature: min 20.7, current 21.4, max 21.7
                                Date/time: 2021-02-01 09:51:32
                                Cache data hit count 30320382
                                Slowest loop: 3.20ms; fastest: 0.20ms
                                === Storage ===
                                === MainDDARing ===
                                === AuxDDARing ===
                                Segments left: 0
                                === Network ===
                                Slowest loop: 140.03ms; fastest: 0.00ms
                                - WiFi -
                                WiFi flash size 4194304, free heap 25632
                                WiFi signal strength -69dBm, mode 802.11n, reconnections 0, sleep mode modem
                                  Wow, 106Mb gcode file. I'll try simulating it myself.
                                    I was able to simulate that gcode file on a Duet2 with fw 3.2 on the internal SD card without error. I don't have the ribbon cable connected for the PanelDue SD card slot, so I can't test that.
                                    You could try reducing the baud rate on the PanelDue and in your M575 P1 B57600 S1 command to see if that improves it.
                                    • felekundefined
                                      felek @Phaedrux
                                      @Phaedrux internal SD card works great but external SD has issues.
                                      PanelDue is not problem in this case.
                                      I enabled debugPrint in CoreNG and M111 S1 P10 (Storage) in order to find bug.
                                      This log below is while simulating and refreshing DWC (sd_mmc errors)
                                      Read 1 1 97118<LF>
                                      Read 1 1 97119<LF>
                                      Read 1 1 9508<LF>
                                      Read 1 1 97120<LF>
                                      Read 1 1 97121<LF>
                                      Read 1 1 97122<LF>
                                      Read 1 1 97123<LF>
                                      Read 1 1 97124<LF>
                                      Read 1 1 97125<LF>
                                      Read 1 1 97126<LF>
                                      Read 1 1 97127<LF>
                                      Read 1 1 9508<LF>
                                      Read 1 1 97128<LF>
                                      Read 1 1 97129<LF>
                                      Read 1 1 97130<LF>
                                      Read 1 1 97131<LF>
                                      Read 1 1 97132<LF>
                                      Read 1 1 97133<LF>
                                      Read 0 1 16384<LF>
                                      Read 0 1 16385<LF>
                                      Read 0 1 35584<LF>
                                      Read 0 1 16384<LF>
                                      Read 0 1 16385<LF>
                                      Read 0 1 35584<LF>
                                      Read 0 1 16384<LF>
                                      Read 0 1 16385<LF>
                                      Read 0 1 35584<LF>
                                      Read 0 1 35840<LF>
                                      Read 1 1 97134<LF>
                                      Read 1 1 97135<LF>
                                      Read 1 1 9508<LF>
                                      Read 1 1 97136<LF>
                                      Read 1 1 97137<LF>
                                      Read 0 1 16384<LF>
                                      Read 0 1 16385<LF>
                                      Read 0 1 35584<LF>
                                      Read 0 1 35968<LF>
                                      Read 0 1 16384<LF>
                                      Read 0 1 16385<LF>
                                      Read 0 1 35584<LF>
                                      Read 0 1 41088<LF>
                                      Read 0 4 36096<LF>
                                      Read 0 4 41216<LF>
                                      Read 0 4 36100<LF>
                                      sd_mmc_spi_adtc_start: cmd 12, arg 0x00000000, R1 timeout<LF>
                                      <CR>sd_mmc_spi_adtc_start: cmd 12, arg 0x00000000, R1 timeout<LF>
                                      <CR>Read 0 4 41220<LF>
                                      Read 1 1 97138<LF>
                                      Read 1 1 97139<LF>
                                      Read 1 1 97140<LF>
                                      Read 1 1 97141<LF>
                                      Read 1 1 97142<LF>
                                      Read 1 1 97143<LF>
                                      Read 1 1 9508<LF>
                                      Read 1 1 97144<LF>
                                      Read 1 1 97145<LF>
                                      I figured out that ctrl_access.c is vulnerable and two task might have access in the same time so there can be a race condition.
                                      I also noticed that there is support for FreeRTOS but is disabled by default. I enabled FreeRTOS from FreeRTOS project and now it works flawlessly.
                                      I'm testing this solution on my desk now, but I looks promising.
                                      Now I can simulating and refreshing in the same time and I works stable. I can even upload files on internal SD card during simulating from external SD card - it takes a bit longer but it is still stable.
                                      I did this modyfication on 2.05 firmware.
                                        I spotted a week or two ago that the Atmel/Microchip SD card stack shares data across multiple devices (i.e. HSMCI and SPI) and flagged this for investigation. So yes, I do think there is likely to be an issue with concurrent access to the external and on-board SD card. My preference is to stop using shared data, because there is already a per-volume mutex, and I'd prefer that using the external SD card for something didn't slow down the internal one. I'll schedule this for implementation in firmware 3.3.
                                        felekundefined 1 Reply Last reply Reply Quote 1
                                        • felekundefined
                                          felek @dc42
                                          @dc42 Okey, It sounds great.
                                          So what do you prefer? Should I write some bypass (just omit ctrl_access.c) for this library and use direct fuctions between FatFS and HSMCI/SPI?
                                          In this way I don't need to use extra mutex and internal SD card won't slow down.
                                          Do you see any dangerous?
                                          Are you going to implement this only for 3.3?
                                            dc42 administrators @felek
                                            I think the problem is the static variables in sd_mmc.c:
                                            //! SD/MMC card list
                                            //DC added __nocache for SAME70 because 'csd' is read by DMA
                                            static __nocache struct sd_mmc_card sd_mmc_cards[SD_MMC_MEM_CNT];
                                            //! Index of current slot selected
                                            static uint8_t sd_mmc_slot_sel;
                                            //! Pointer on current slot selected
                                            static struct sd_mmc_card *sd_mmc_card;
                                            //! Number of block to read or write on the current transfer
                                            static uint16_t sd_mmc_nb_block_to_tranfer = 0;
                                            //! Number of block remaining to read or write on the current transfer
                                            static uint16_t sd_mmc_nb_block_remaining = 0;
                                            The first one should be OK because there is one entry per SD card, but the other four are not, assuming they are used for both HSMCI and SPI transfers. So I think that sd_mmc_slot_sel needs to be passed around as a parameter, then the second one replaced by indexing into sd_mmc_cards (i.e. initialise a local sd_mmc_card variable at the start of each function that uses it), then the other two can be turned into arrays indexed by slot (strictly speaking, one element per channel would be enough, but one per slot is simpler).
                                            I will probably only implement it for 3.3, although it's looking likely that there will be a 3.2.1, so the fix may get back-ported to that if it is simple enough.
