    New to the duet COMPLETE NEWBIE
    5.4k
    • gabrealekundefined
      gabrealek @Phaedrux
      @Phaedrux okay so do is erase something out of my config? or rather where do i put this into the config
        gabrealek @Phaedrux
        @Phaedrux said in New to the duet COMPLETE NEWBIE:
        M558 P0 H5 F300 T6000 G31 x0 y0 z0 P500
        Okay i think i see . .
        M558 P0 H18 F120 T480000 ; disable Z probe but set dive height, probe speed and travel speed
        M557 X10:220 Y10:220 S20 ; define mesh grid
        replace with
        G31 x0 y0 z0 P500
          Replace with:
          G31 x0 y0 z0 P500
          gabrealekundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
            gabrealek @Phaedrux
            @Phaedrux
            G91
            G1 H1 Z-400 F3000
            G92 Z0 ; change Z0 to match the actual Z co-ordinate at which the Z end stop triggers
            G1 Z10
            G1 H1 X-300 Y-300
            G1 X5 Y5
            G1 H1 X-6 Y-6 F300
            G90
            change to
            G91
            G1 X150 Y150 F6000
            G30
            Do i leave everything under this there or void?
            G1 Z10
            G1 H1 X-300 Y-300
            G1 X5 Y5
            G1 H1 X-6 Y-6 F300
            G90
              For homeall try this
              G91 ; relative positioning
              G1 H1 X-300 Y-300 F3000 ; move quickly to X and Y axis endstops and stop there (first pass)
              G1 H1 X-300 Y-300 F3600 ; move slowly to X and Y axis endstops once more (second pass)
              G90 ; absolute positioning
              G1 X150 Y150 F6000 ; move to center
              G30 ; probe the bed
              G1 X10 Y10 Z10 ; move to parking position
              gabrealekundefined 1 Reply Last reply Reply Quote 0
                gabrealek @Phaedrux
                @Phaedrux YESSS !! it worked perfectly!!
                  gabrealek
                  @Phaedrux Hello again. Ive been trying to fix this issue all day to no avail. After i home my printer and start the print it does not go down to the bed. its about 2mm above and it doesn't print. Ive checked the settings in cura and i cant figure out where its going left. . . Ill post the first few lines. THANKS for helping me once again.
                  ;FLAVOR:RepRap
                  ;TIME:9734
                  ;Filament used: 17.6452m
                  ;Layer height: 0.32
                  ;MINX:41.27
                  ;MINY:49.81
                  ;MINZ:0.32
                  ;MAXX:211.803
                  ;MAXY:236.543
                  ;MAXZ:99.84
                  ;Generated with Cura_SteamEngine 4.8.0
                  T0
                  M190 S60
                  M104 S220
                  M109 S220
                  M82 ;absolute extrusion mode
                  M83 ;relative extrusion mode
                  G1 F1800 E-3
                  ;LAYER_COUNT:313
                  ;LAYER:0
                  M107
                  G0 F6000 X121.857 Y55.934 Z0.32
                  ;TYPE:SKIRT
                    Phaedrux Moderator @Phaedrux
                    G31 x0 y0 z0 P500
                    Did you change your G31 command in the config.g to have Z0?
                      gabrealek @Phaedrux
                      @Phaedrux
                      yes
                      G31 x0 y0 z0 P500
                      Do you think its something with my homeall?
                      idk what to do. . ill post my config here as well
                      ; generated by RepRapFirmware Configuration Tool v3.2.1 on Tue Jan 19 2021 17:33:25 GMT-0500 (Eastern Standard Time)
                      M550 P"Creola" ; set printer name
                      M552 S1 ; enable network
                      M586 P0 S1 ; enable HTTP
                      M586 P1 S0 ; disable FTP
                      M586 P2 S0 ; disable Telnet
                      M569 P0 S0 ; physical drive 0 goes backwards
                      M92 X80.00 Y80.00 Z400.00 E97.08 ; set steps per mm
                      M203 X6000.00 Y6000.00 Z600.00 E1200.00 ; set maximum speeds (mm/min)
                      M201 X500.00 Y500.00 Z120.00 E250.00 ; set accelerations (mm/s^2)
                      M84 S30 ; Set idle timeout
                      M208 X300 Y300 Z400 S0 ; set axis maxima
                      M574 Z1 S1 P"!zstop" ; configure active-high endstop for low end on Z via pin !zstop
                      G31 x0 y0 z0 P500
                      M308 S0 P"bedtemp" Y"thermistor" T98801 B4185 ; configure sensor 0 as thermistor on pin e0temp
                      M950 H0 C"bedheat" T0 ; create bed heater output on e0heat and map it to sensor 0
                      M143 H0 S80 ; set temperature limit for heater 0 to 80C
                      M308 S1 P"e1temp" Y"thermistor" T98801 B4185 ; configure sensor 1 as thermistor on pin e1temp
                      M950 H1 C"e1heat" T1 ; create nozzle heater output on e1heat and map it to sensor 1
                      M950 F0 C"fan0" Q20 ; create fan 0 on pin fan0 and set its frequency
                      M106 P0 C"PartCool" S0 H-1 ; set fan 0 name and value. Thermostatic control is turned off
                      M950 F1 C"fan1" Q20 ; create fan 1 on pin fan1 and set its frequency
                      M106 P1 S1 H T45 ; set fan 1 value. Thermostatic control is turned on
                      M563 P0 S"Hotend" D0 H1 F0 ; define tool 0
                      M911 S21 R23 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss
                      T0 ; select first tool
                      Also my homeall
                      ; homeall.g
                      ; called to home all axes
                      G30 ; probe the bed
                                ; set Z position to axis minimum (you may want to adjust this)
                      ;G91 ; relative positioning
                      ;G1 Z18 F8000 ; lift Z relative to current position
                      ;G90 ; absolute positioning
                      • Vetiundefined
                        Veti
                        now you need to calibrate the trigger height of the probe
                        https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe#Section_Calibrate_the_Z_probe_trigger_height
                        gabrealekundefined Phaedruxundefined 2 Replies Last reply Reply Quote 1
                          gabrealek @Veti
                          @Veti ok thank you . ill do it after my errand and keep you all posted
                            Phaedrux Moderator @Veti
                            @Veti said in New to the duet COMPLETE NEWBIE:
                            No probe involved in this case. Just manual probing due to a broken Z endstop.
                              gabrealek @Phaedrux
                              @Phaedrux yes, I figured after trying to follow along with it. It’s working for the most part now though. I’m having some mechanical issues at this point. My feeding gears were all off and I releveled the bed. I’m about to try a print now. Thank you all for the consistent help.
                              • gabrealekundefined gabrealek referenced this topic
