    New to the duet COMPLETE NEWBIE
    5.5k
      Phaedrux Moderator @gabrealek
      @gabrealek said in New to the duet COMPLETE NEWBIE:
      @Phaedrux I inverted it and it went down so far it cracked the glass . 😞
      Ah nuts. Sorry about that.
      I'm wondering if your Z endstop wiring is not correct.
      Regardless of the ! being there or not, if it's electrically connected to the Duet it should report as stopped/not stopped and change state if the switch is actually clicked at the time when you send M119.
      Can you post a photo of the endstop wiring at the board? The creality endstops should be wired to the 2 outside pins of the endstop connector.
      gabrealekundefined 1 Reply Last reply Reply Quote 1
      • gabrealekundefined
        gabrealek @Phaedrux
        @Phaedrux its okay. I can always get another . no worries.
          Ok, I can mostly see the endstops and they all look like they are connected correctly with the wires going to the outside pins, so that's a good start.
          Now to make sure the wires are actually connected electrically.
          Send M119 and see what the Z stop says.
          Then hold down the Z switch and send M119 again while holding it clicked and see if the status changes.
          gabrealekundefined 1 Reply Last reply Reply Quote 0
            gabrealek @Phaedrux
            @Phaedrux
            Its being so mean 😂
            1/22/2021, 4:44:48 PM M119
            Endstops - X: not stopped, Y: not stopped, Z: not stopped, Z probe: at min stop
            1/22/2021, 4:44:33 PM M119
              So being clicked or not it's not registering? Just as a control, text the other endstops as well.
              If that is the case that pressing the endstop isn't registering at all then there could be a break in the wire or poor connection. In which case reseating the z endstop plug on the board may help. If you have a multimeter you can check the wire for continuity and whether the endstop switch will complete or break a circuit.
                gabrealek @Phaedrux
                @Phaedrux
                Okay. So how would i test with a multimeter? As in where to on the Z? Im still new at using this multimeter , ill post a pic to know exactly which setting to set it to. Also which command do i sent to test only for Z? THANKKASSSS621C9C88-A4C3-4363-9EB1-286D307B0B1E.jpeg
                  This might help.
                  https://www.youtube.com/watch?v=OOK8np4t40c&ab_channel=HelpfulDIY
                  When set to ohms (orange on the left side, infact the symbol below the 600 may be intended specifically for continuity the arrow and the beep symbol), you can touch the two probe tips together and the display number should change, and maybe beep. Meaning there is a connection between them. Touch something metal and it should do the same. Touch two ends of a wire, same thing.
                  It will probably be easiest to remove the endstop from the printer entirely so that you can check the wire more easily. You'd basically want to touch one of the wires at the end that plugs into the printer, and the other end at the endstop itself.
                  gabrealekundefined 2 Replies Last reply Reply Quote 0
                    gabrealek @Phaedrux
                    @Phaedrux
                    Yeahhh .. . so i think its the actual endstop. Its really wiggly. . i don't think its suppose to be this way . . i just ordered some new ones, and new cables to dead this whole issue. by the time i'm done ill probably have enough supplies for another printer.
                      gabrealek @Phaedrux
                      @Phaedrux BUT THANK YOU THOUGH!! NOW I KNOW HOW TO USE IT THE RIGHT WAY. 🙂
                        Hmm, yeah wiggly isn't great.
                        There is a way to get up and running without a Z endstop at all though. You can configure it to ask you to jog the print head down so that the nozzle touches the bed to set the Z height. Manual probing.
                        You'd need to change your config.g
                        M558 P0 H5 F300 T6000
                        G31 x0 y0 z0 P500
                        And then in homeall and homez where it says
                        G1 H1 Z-405 F3000 ; move Z down until the endstop is triggered
                        G92 Z0 ; set Z position to axis minimum (you may want to adjust this)
                        replace that with
                        G1 X150 Y150 F6000
                        G30
                        Then when you try and home it will do xy, move to the center(ish) and there will be a pop up asking you to move Z jog it down carefully and when the nozzle is just touching the bed, hit OK.
                        Pretty handy in cases like this. I used this the other week when I broke a BLTouch pin.
                          gabrealek @Phaedrux
                          This post is deleted!
                            Haha, good luck with your first print.
                              gabrealek @Phaedrux
                              @Phaedrux
                              I am SO SCARED. . lol thanks for the luck . . I NEED ITTTT
                                gabrealek @Phaedrux
                                @Phaedrux okay so do is erase something out of my config? or rather where do i put this into the config
                                  gabrealek @Phaedrux
                                  @Phaedrux said in New to the duet COMPLETE NEWBIE:
                                  M558 P0 H5 F300 T6000 G31 x0 y0 z0 P500
                                  Okay i think i see . .
                                  M558 P0 H18 F120 T480000 ; disable Z probe but set dive height, probe speed and travel speed
                                  M557 X10:220 Y10:220 S20 ; define mesh grid
                                  replace with
                                  G31 x0 y0 z0 P500
                                    Replace with:
                                    G31 x0 y0 z0 P500
                                    gabrealekundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
                                      gabrealek @Phaedrux
                                      @Phaedrux
                                      G91
                                      G1 H1 Z-400 F3000
                                      G92 Z0 ; change Z0 to match the actual Z co-ordinate at which the Z end stop triggers
                                      G1 Z10
                                      G1 H1 X-300 Y-300
                                      G1 X5 Y5
                                      G1 H1 X-6 Y-6 F300
                                      G90
                                      change to
                                      G91
                                      G1 X150 Y150 F6000
                                      G30
                                      Do i leave everything under this there or void?
                                      G1 Z10
                                      G1 H1 X-300 Y-300
                                      G1 X5 Y5
                                      G1 H1 X-6 Y-6 F300
                                      G90
                                        For homeall try this
                                        G91 ; relative positioning
                                        G1 H1 X-300 Y-300 F3000 ; move quickly to X and Y axis endstops and stop there (first pass)
                                        G1 H1 X-300 Y-300 F3600 ; move slowly to X and Y axis endstops once more (second pass)
                                        G90 ; absolute positioning
                                        G1 X150 Y150 F6000 ; move to center
                                        G30 ; probe the bed
                                        G1 X10 Y10 Z10 ; move to parking position
                                          gabrealek @Phaedrux
                                          @Phaedrux YESSS !! it worked perfectly!!
                                            gabrealek
                                            @Phaedrux Hello again. Ive been trying to fix this issue all day to no avail. After i home my printer and start the print it does not go down to the bed. its about 2mm above and it doesn't print. Ive checked the settings in cura and i cant figure out where its going left. . . Ill post the first few lines. THANKS for helping me once again.
                                            ;FLAVOR:RepRap
                                            ;TIME:9734
                                            ;Filament used: 17.6452m
                                            ;Layer height: 0.32
                                            ;MINX:41.27
                                            ;MINY:49.81
                                            ;MINZ:0.32
                                            ;MAXX:211.803
                                            ;MAXY:236.543
                                            ;MAXZ:99.84
                                            ;Generated with Cura_SteamEngine 4.8.0
                                            T0
                                            M190 S60
                                            M104 S220
                                            M109 S220
                                            M82 ;absolute extrusion mode
                                            M83 ;relative extrusion mode
                                            G1 F1800 E-3
                                            ;LAYER_COUNT:313
                                            ;LAYER:0
                                            M107
                                            G0 F6000 X121.857 Y55.934 Z0.32
                                            ;TYPE:SKIRT
