    How to add translation code(scpecific screen communication) ?
    Firmware developers
    593
    • alankilianundefined
      alankilian
      Maybe it has something to do with this?
      http://www.dwin.com.cn/home/english/news_detail.html?nId=1181
      • pavelsplavelundefined
        pavelsplavel
        @alankilian You right! I want to connect DWIN screen
        @dc42 DWIN communication protocol and address to drive the serial port:
        5A A5 04 82 1000 01 (5A A5 is the framehead, 04 is the datalength, 82 means read, 1000 means VP address (shall be same as your photo), 01 is the data.
        What is the Duet 2 wifi communication protocol and address which drives the serial port?
          pavelsplavel
          @dc42 here is the link:
          https://drive.google.com/file/d/1fhcOW1s-67v5Vx8_pmW1Grp9FbZ7RrR2/view
          • wilrikerundefined
            wilriker @pavelsplavel
            @pavelsplavel So as of now RepRapFirmware uses a plain-text communication on the serial port. It expects to receive GCodes and sends out whatever the result is - when communicating with a PanelDue this will always be JSON.
            Unfortunately the document you linked in Google Drive is access restricted and I cannot view it. The page linked by @alankilian only gives a coarse overview.
            So from this sparse information you either need to adjust DWINOS to deal with the JSON that RepRapFirmware sends or you need to implement a driver that is able to talk the DWIN protocol in RepRapFirmware.
            Manuel
            My Tool Collection
              pavelsplavel
              Development Guide of T5L ASIC_20200624 .pdf
              @wilriker So, i attached here
              • wilrikerundefined
                @pavelsplavel Unfortunately this document is not very helpful as it describes the processor and how it is programmed. I think instead you need to search and provide the documentation of the communication protocol you described above.
                Manuel
                My Tool Collection
                  pavelsplavel
                  @wilriker Soon i will upload here the documentation of the DWIN communication protocol.
                  By the way DWIN asked me to get the documentation of the DUET communication protocol. Does somebody can give it to me ?
                    T3P3Tony administrators @wilriker
                    @pavelsplavel I think it would be better to adapt the DWIN OS to communicate with RRF using the UART. @wilriker describes it here:
                    @wilriker said in How to add translation code(scpecific screen communication) ?:
                    So you send plain text GCODE command and parse the JSON response.
                      pavelsplavel
                      @wilriker @T3P3Tony Okay. Thank you!
                        dc42 administrators @alankilian
                        @alankilian said in How to add translation code(scpecific screen communication) ?:
                        Malwarebytes thinks that page carries a trojan.
                          alankilian
                          @dc42 said in How to add translation code(scpecific screen communication) ?:
                          Bummer.
                          It comes out clean with other scanners, but.... Better safe than sorry.
                            pavelsplavel
                            Protocol communication_PNG.png @wilriker @dc42
                            Hey there!
                            Here is serial protocol communication of Dwin screen.![0_1612172004966_Protocol communication.jfif](Uploading 100%)
