    Update CR-10+Duet wifi from 2.05.1 to 3.0 firmware
    Firmware installation
    7.9k
    • Hélder Rochaundefined
      Hélder Rocha
      do you have an idea abou the trigger height i should give to the Bltouch?
      • Vetiundefined
        Veti
        take the value from your old config
          Hélder Rocha @Hélder Rocha
          @Hélder-Rocha said in Update CR-10+Duet wifi from 2.05.1 to 3.0 firmware:
          @Veti said in Update CR-10+Duet wifi from 2.05.1 to 3.0 firmware:
          looks ok.
          the bltouch port depends on the port where you connected it
          Yes... i have it on the 4th pin near the red and the broun. I beleave is nº7
          I change it to heater 3... the connections are just like the ones you find here:
          https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe#Section_BLTouch
            Hélder Rocha
            Done...i am now uploading the new config
              https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Mini+5++Guide+Part+2:+Configuration/88
              Here's a walk through of the config tool for RRF3 and an Ender3, which is pretty similar to the CR-10.
              Hélder Rochaundefined 1 Reply Last reply Reply Quote 0
                Hélder Rocha @Phaedrux
                @Phaedrux Tks.... at the momment im with other problem. Forgot to include in the new config file the access point and now, i cant get access to it!
                  If it was added once before the SSID should be saved on the wifi module itself and sending M552 S1 should enable the module and it will try to connect to the strongest SSID it knows about.
                  If it doesn't seem to be doing that you can try re-adding it. Same steps as initial connection.
                  https://duet3d.dozuki.com/Guide/1.)+Getting+Connected+to+your+Duet/7
                    @Phaedrux I think i messed this up... it steel giving me the message that the access point is working, and i can connect to it, but i dont know why, im not ablet to accesse the IP... "page not work"
                      Are you sure the IP address is the same?
                      If you send M552 the Duet will respond with what the current IP address is.
                      What is the exact error message?
                        @Phaedrux yap....is the same
                        Hélder Rochaundefined Vetiundefined 2 Replies Last reply Reply Quote 0
                          Could be anything in the new config i uploaded?
                          • Vetiundefined
                            Veti @Hélder Rocha
                            that is not the exact error message
                              Try clearing your browser cache.
                              And if that doesn't work, I would check the /www folder on the SD card and replace the files there with a fresh copy of DWC.
                              https://github.com/Duet3D/RepRapFirmware/releases/download/3.2/DuetWebControl-SD.zip
                                Hélder Rocha
                                at the momment on YAT, it is sayng that the wifi module is connected to my home network! Do you know ohow to disable it, and reeturn to Duet access point?
                                • Vetiundefined
                                  Veti
                                  Send M552 S2 to start up in access point mode (if it is already running in station mode then you need to send M552 S0 first).
                                    Hélder Rocha @Veti
                                    @Veti keeps saying "Enable to connect after i digit the IP on adress bar. I can stablish the access point, but cant access the DWC.
                                      Hélder Rocha
                                      The blue signal on the board is lit
                                        Phaedrux Moderator @Hélder Rocha
                                        Are you wanting to run in access point mode where you connect to the Duet directly with your PC/phone? Or normal mode where the Duet connects to your home wifi network?
                                        In access point mode you need to connect to the Duet SSID with your PC.
                                          @Phaedrux yes i know. After i upload my new config, i stoped having accesse to my DWC pannel. Because of that, i used M587 to privid me a different door to the DWC. Now i have a mess in my hands!!! I still can create a wifi signal from the Duet, the access point, but i cant open the DWC pannel. Says "Enable to connect".
                                            It would help to see exactly what gcodes you are sending and what the responses are.
                                            I still don't know if you're trying to use access point mode or not.
