    Update CR-10+Duet wifi from 2.05.1 to 3.0 firmware
    Firmware installation
    7.6k
    • Hélder Rochaundefined
      Hélder Rocha @Phaedrux
      @Phaedrux said in Update CR-10+Duet wifi from 2.05.1 to 3.0 firmware:
      Just change the url.
      HTTP: instead of HTTPS:
      it changes again to HTTPS...i erase the "s" but doesnt work
        Phaedrux Moderator @Hélder Rocha
        @Hélder-Rocha I don't know if that's a problem or just what it normally does when it can't reach the site.
        Are you able to connect the duet to your home wifi?
        Hélder Rochaundefined 1 Reply Last reply Reply Quote 0
          Hélder Rocha
          even if i try the duettest.local... it changes to the https followed by the ip number
            no... i am trying by the access point given by the board
              Hélder Rocha
              the blue led on the board is lit... the duet is working fine... after dinner ill try a different computer
                @Hélder-Rocha said in Update CR-10+Duet wifi from 2.05.1 to 3.0 firmware:
                Yes I understand that, but do you have a local WIFI network that you can test connecting to?
                  @Phaedrux yes offcouse. Also tried that way... could get in!
                    Hélder Rocha
                    With my home network:
                    M122
                    RepRapFirmware for Duet 2 WiFi/Ethernet version 3.2 running on Duet WiFi 1.02 or later
                    Board ID: 08DGM-917DA-G4MSD-6J1F2-3S06L-T9VVB
                    Used output buffers: 1 of 24 (1 max)
                    Static ram: 23460
                    Dynamic ram: 77144 of which 40 recycled
                    Never used RAM 11436, free system stack 170 words
                    Tasks: NETWORK(ready,408) HEAT(blocked,323) MAIN(running,474) IDLE(ready,19)
                    Owned mutexes: USB(MAIN)
                    Last reset 01:33:55 ago, cause: power up
                    Last software reset at 2021-01-30 15:46, reason: User, GCodes spinning, available RAM 15160, slot 2
                    Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00400000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a
                    Error status: 0x00
                    Aux0 errors 0,0,0
                    MCU temperature: min 20.1, current 25.6, max 26.4
                    Supply voltage: min 0.7, current 1.6, max 1.8, under voltage events: 0, over voltage events: 0, power good: no
                    Driver 0: position 0, ok, SG min/max not available
                    Driver 1: position 0, ok, SG min/max not available
                    Driver 2: position 0, ok, SG min/max not available
                    Driver 3: position 0, ok, SG min/max not available
                    Driver 4: position 0, ok, SG min/max not available
                    Driver 5: position 0
                    Driver 6: position 0
                    Driver 7: position 0
                    Driver 8: position 0
                    Driver 9: position 0
                    Driver 10: position 0
                    Driver 11: position 0
                    Slowest loop: 99.97ms; fastest: 0.14ms
                    === Storage ===
                    Free file entries: 10
                    SD card longest read time 0.7ms, write time 0.0ms, max retries 0
                    === MainDDARing ===
                    === AuxDDARing ===
                    Segments left: 0
                    Movement lock held by null
                    HTTP is idle in state(s) 0
                    Telnet is idle in state(s) 0
                    File is idle in state(s) 0
                    USB is ready with "M122" in state(s) 0
                    Aux is idle in state(s) 0
                    Trigger is idle in state(s) 0
                    Queue is idle in state(s) 0
                    LCD is idle in state(s) 0
                    Daemon is idle in state(s) 0
                    Code queue is empty.
                    === Network ===
                    Slowest loop: 199.51ms; fastest: 0.00ms
                    HTTP sessions: 0 of 8
                    • WiFi -
                      Network state is active
                      WiFi firmware version 1.25
                      WiFi MAC address cc:50:e3:0d:1f:26
                      WiFi Vcc 3.36, reset reason Turned on by main processor
                      WiFi flash size 4194304, free heap 28272
                      WiFi IP address 192.168.0.23
                      WiFi signal strength -56dBm, mode 802.11n, reconnections 0, sleep mode modem
                      Clock register 00002002
                      ok
                      Hélder Rocha
                      tried to access from a different computer, throw my home network and couldnt get there either.... what the hell can i be doing wrong!?
                        The duet IP address is 192.168.0.23
                        What is the IP address of your own computer?
                        Are they even in the same subnet?
                          @Phaedrux
                          IPv4 address.............192.168.1.2
                          subnet Mask.............255.255.255.0
                          Default Gateway.......192.168.1.1
                            Hélder Rocha @Hélder Rocha
                            @Hélder-Rocha i beleave i found the error.... when i was working on the RRF config tool, in the end, in the network setings panel, i havent change the Ip, nor the subnet mask or the gateway... i let it be as it was, thinking those were the correct ones!
                              so... whem i upload this settings as new config, i uploaded the wrong Ip etc etc
                                Are you assigning the IP address to the duet or is it getting a DHCP address?
                                If your PC is on 192.168.1 then the duet will also need to be on 182.168.1
                                  DHCP address
                                  I dont know....is there a way to find out?
                                    DHCP address
                                    it was the duet that gave me the ip address... i havnt select nothing!
                                      when i uploaded the new files, for mistake i sent completly differrent ip and gateway
                                        Hélder Rocha
                                        should i upload other DuetWiFiServer? To the card?
                                          Post your config.g please.
                                          No. Don't change any firmware at this point.
                                          I want to see if your are setting an IP address in your config.g or if it's set to get an address from the router.
                                          If the router is setting it and it's not in the same subnet as your PC that might mean the router needs to have some settings changed to let your wired and wireless devices communicate.
                                          What is your router?
                                            i dont have access to my DWC. should i take it from the sd card?
