    Update CR-10+Duet wifi from 2.05.1 to 3.0 firmware
    Firmware installation
    8.0k
    • Hélder Rochaundefined
      Hélder Rocha @Phaedrux
      @Phaedrux yes offcouse. Also tried that way... could get in!
        Hélder Rocha
        With my home network:
        M122
        RepRapFirmware for Duet 2 WiFi/Ethernet version 3.2 running on Duet WiFi 1.02 or later
        Board ID: 08DGM-917DA-G4MSD-6J1F2-3S06L-T9VVB
        Used output buffers: 1 of 24 (1 max)
        Static ram: 23460
        Dynamic ram: 77144 of which 40 recycled
        Never used RAM 11436, free system stack 170 words
        Tasks: NETWORK(ready,408) HEAT(blocked,323) MAIN(running,474) IDLE(ready,19)
        Owned mutexes: USB(MAIN)
        Last reset 01:33:55 ago, cause: power up
        Last software reset at 2021-01-30 15:46, reason: User, GCodes spinning, available RAM 15160, slot 2
        Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00400000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a
        Error status: 0x00
        Aux0 errors 0,0,0
        MCU temperature: min 20.1, current 25.6, max 26.4
        Supply voltage: min 0.7, current 1.6, max 1.8, under voltage events: 0, over voltage events: 0, power good: no
        Driver 0: position 0, ok, SG min/max not available
        Driver 1: position 0, ok, SG min/max not available
        Driver 2: position 0, ok, SG min/max not available
        Driver 3: position 0, ok, SG min/max not available
        Driver 4: position 0, ok, SG min/max not available
        Driver 5: position 0
        Driver 6: position 0
        Driver 7: position 0
        Driver 8: position 0
        Driver 9: position 0
        Driver 10: position 0
        Driver 11: position 0
        Slowest loop: 99.97ms; fastest: 0.14ms
        === Storage ===
        Free file entries: 10
        SD card longest read time 0.7ms, write time 0.0ms, max retries 0
        === MainDDARing ===
        === AuxDDARing ===
        Segments left: 0
        Movement lock held by null
        HTTP is idle in state(s) 0
        Telnet is idle in state(s) 0
        File is idle in state(s) 0
        USB is ready with "M122" in state(s) 0
        Aux is idle in state(s) 0
        Trigger is idle in state(s) 0
        Queue is idle in state(s) 0
        LCD is idle in state(s) 0
        Daemon is idle in state(s) 0
        Code queue is empty.
        === Network ===
        Slowest loop: 199.51ms; fastest: 0.00ms
        HTTP sessions: 0 of 8
        • WiFi -
          Network state is active
          WiFi firmware version 1.25
          WiFi MAC address cc:50:e3:0d:1f:26
          WiFi Vcc 3.36, reset reason Turned on by main processor
          WiFi flash size 4194304, free heap 28272
          WiFi IP address 192.168.0.23
          WiFi signal strength -56dBm, mode 802.11n, reconnections 0, sleep mode modem
          Clock register 00002002
          ok
          Hélder Rocha
          tried to access from a different computer, throw my home network and couldnt get there either.... what the hell can i be doing wrong!?
            Phaedrux Moderator @Hélder Rocha
            The duet IP address is 192.168.0.23
            What is the IP address of your own computer?
            Are they even in the same subnet?
            Hélder Rochaundefined 1 Reply Last reply Reply Quote 0
              @Phaedrux
              IPv4 address.............192.168.1.2
              subnet Mask.............255.255.255.0
              Default Gateway.......192.168.1.1
                Hélder Rocha @Hélder Rocha
                @Hélder-Rocha i beleave i found the error.... when i was working on the RRF config tool, in the end, in the network setings panel, i havent change the Ip, nor the subnet mask or the gateway... i let it be as it was, thinking those were the correct ones!
                  @Hélder-Rocha said in Update CR-10+Duet wifi from 2.05.1 to 3.0 firmware:
                  so... whem i upload this settings as new config, i uploaded the wrong Ip etc etc
                    Are you assigning the IP address to the duet or is it getting a DHCP address?
                    If your PC is on 192.168.1 then the duet will also need to be on 182.168.1
                      @Phaedrux said in Update CR-10+Duet wifi from 2.05.1 to 3.0 firmware:
                      DHCP address
                      I dont know....is there a way to find out?
                        DHCP address
                        it was the duet that gave me the ip address... i havnt select nothing!
                          when i uploaded the new files, for mistake i sent completly differrent ip and gateway
                            Hélder Rocha
                            should i upload other DuetWiFiServer? To the card?
                              Post your config.g please.
                              No. Don't change any firmware at this point.
                              I want to see if your are setting an IP address in your config.g or if it's set to get an address from the router.
                              If the router is setting it and it's not in the same subnet as your PC that might mean the router needs to have some settings changed to let your wired and wireless devices communicate.
                              What is your router?
                                i dont have access to my DWC. should i take it from the sd card?
                                  Hélder Rocha
                                  Here it goes:
                                  <; Configuration file for Duet WiFi (firmware version 3)
                                  ; generated by RepRapFirmware Configuration Tool v3.2.2 on Sat Jan 30 2021 16:42:08 GMT+0000 (Hora padrão da Europa Ocidental)
                                  M550 P"CR-10" ; set printer name
                                  M918 P1 E4 F2000000 ; configure direct-connect display
                                  M550 "CR-10"
                                  M552 S1 ; enable network
                                  M586 P0 S0 ; disable HTTP
                                  M586 P1 S0 ; disable FTP
                                  M586 P2 S0 ; disable Telnet
                                  M569 P0 S0 ; physical drive 0 goes backwards
                                  M92 X80.00 Y80.00 Z400.00 E93.00 ; set steps per mm
                                  M566 X1200.00 Y1200.00 Z24.00 E300.00 ; set maximum instantaneous speed changes (mm/min)
                                  M203 X9000.00 Y9000.00 Z180.00 E6000.00 ; set maximum speeds (mm/min)
                                  M201 X500.00 Y500.00 Z100.00 E5000.00 ; set accelerations (mm/s^2)
                                  M906 X800 Y800 Z800 E1000 I50 ; set motor currents (mA) and motor idle factor in per cent
                                  M84 S30 ; Set idle timeout
                                  M208 X300 Y300 Z400 S0 ; set axis maxima
                                  M950 S0 C"exp.heater3" ; create servo pin 0 for BLTouch
                                  M558 P9 C"^zprobe.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
                                  M558 H30 ;*** Remove this line after delta calibration has been done and new delta parameters have been saved
                                  G31 P500 X10 Y-40 Z2.5 ; set Z probe trigger value, offset and trigger height
                                  M557 X20:300 Y20:300 S40 ; define mesh grid
                                  M308 S0 P"bedtemp" Y"thermistor" T100000 B4092 ; configure sensor 0 as thermistor on pin bedtemp
                                  M143 H0 S150 ; set temperature limit for heater 0 to 150C
                                  M308 S1 P"e0temp" Y"thermistor" T100000 B4092 ; configure sensor 1 as thermistor on pin e0temp
                                  M143 H1 S290 ; set temperature limit for heater 1 to 290C
                                  M950 F2 C"fan2" Q500 ; create fan 2 on pin fan2 and set its frequency
                                  M106 P2 S1 H1:0 T45 ; set fan 2 value. Thermostatic control is turned on
                                  ; Custom settings are not defined>
                                    Ok. So your router is setting the IP address to a different subnet. So your PC can't reach it.
                                    Can you try using your phone to connect to the duet? If they are both on WiFi they will likely be in the same subnet. Use your phone browser to go to the IP of the duet.
                                    192.168.0.23
                                      @Phaedrux rien de rien... no luck
                                        Hélder Rocha
                                        shouldn t be th fact that i upload from the RRF diffrent IP and gateway?
                                          Well you can try.
                                          When connected with usb terminal send the commands to set an IP address.
                                          M552 P192.168.1.190
                                          But you'll need to be sure to pick an IP address that isn't already in use. Ping it first to check.
                                            @Phaedrux i beleave there is a misscomunication here, sorry... inglish is not my mother language!
                                            what im trying to say is that, after i upload the new firmware, i used the RRF config tool to give the right parameters to my duet.
                                            In the end, i left the ip, the gateway and the subnet mask as they were there by defaul, and I thought those were the correct ones. But they were not.
                                            So, i beleave i sent to the config of the board, different ip etc etc, and now it doesnt connect.
                                            Could it be right? If it is, do you know any way to solve this?
                                            Using your last suggestion....please,, can you tell me what is the M Commando i should use to set a new IP adress?
