    Update CR-10+Duet wifi from 2.05.1 to 3.0 firmware
    Firmware installation
    7.4k
      Well you can try.
      When connected with usb terminal send the commands to set an IP address.
      M552 P192.168.1.190
      But you'll need to be sure to pick an IP address that isn't already in use. Ping it first to check.
      Hélder Rochaundefined 1 Reply Last reply Reply Quote 0
      • Hélder Rochaundefined
        Hélder Rocha @Phaedrux
        @Phaedrux i beleave there is a misscomunication here, sorry... inglish is not my mother language!
        what im trying to say is that, after i upload the new firmware, i used the RRF config tool to give the right parameters to my duet.
        In the end, i left the ip, the gateway and the subnet mask as they were there by defaul, and I thought those were the correct ones. But they were not.
        So, i beleave i sent to the config of the board, different ip etc etc, and now it doesnt connect.
        Could it be right? If it is, do you know any way to solve this?
        Using your last suggestion....please,, can you tell me what is the M Commando i should use to set a new IP adress?
          @Phaedrux said in Update CR-10+Duet wifi from 2.05.1 to 3.0 firmware:
          M552 P192.168.1.190
          This sets the IP address.
          You can edit the config.g and enter that or you can test it first over USB terminal.
          M550 "CR-10"
          M552 S1 ; enable network
          M586 P0 S0 ; disable HTTP
          M586 P1 S0 ; disable FTP
          M586 P2 S0 ; disable Telnet
          Change that section to be
          M550 "CR-10"
          M552 S1 P192.168.1.190 ; enable network
          M553 P255.255.255.0 ; set netmask
          M554 P192.168.1.1 ; set gateway
          The commands are described here: https://duet3d.dozuki.com/Wiki/Gcode?revisionid=HEAD#Section_M552_Set_IP_address_enable_disable_network_interface
            Hélder Rocha
            now i having problems on yat... doesn give any access to any port!
            Stephen6309undefined 1 Reply Last reply Reply Quote 0
              Hélder Rocha
                Hélder Rocha
                is there a way to reset all things and start over?
                • Stephen6309undefined
                  Stephen6309 @Hélder Rocha
                  @Hélder-Rocha Try running YAT in adminstrator mode. Right click and select Run as adminstrator.
                    Hélder Rocha @Stephen6309
                    @Stephen6309 the same appens... as i turn it on, it runs all the terminals avaiable and at the end, shows me the same message!
                    "YAT - [[Terminal21]-COM 5-Closed]
                      Hélder Rocha
                      Most problems are solved, but now i have this on YAT:
                      Warning: IP 192.168.1.2 requested file 'R/A3EKIDA4MTg1NDgxYm...' from HTTP server, possibly a virus attack
                        Phaedrux Moderator @Hélder Rocha
                        @Hélder-Rocha said in Update CR-10+Duet wifi from 2.05.1 to 3.0 firmware:
                        https://forum.duet3d.com/topic/18054/virus-warning-message?_=1612110244839
                        See here.
