    Update CR-10+Duet wifi from 2.05.1 to 3.0 firmware
    Firmware installation
    7.9k
      Ok. So your router is setting the IP address to a different subnet. So your PC can't reach it.
      Can you try using your phone to connect to the duet? If they are both on WiFi they will likely be in the same subnet. Use your phone browser to go to the IP of the duet.
      192.168.0.23
      Hélder Rochaundefined 1 Reply Last reply Reply Quote 0
      • Hélder Rochaundefined
        Hélder Rocha @Phaedrux
        @Phaedrux rien de rien... no luck
          Hélder Rocha
          shouldn t be th fact that i upload from the RRF diffrent IP and gateway?
            Well you can try.
            When connected with usb terminal send the commands to set an IP address.
            M552 P192.168.1.190
            But you'll need to be sure to pick an IP address that isn't already in use. Ping it first to check.
              @Phaedrux i beleave there is a misscomunication here, sorry... inglish is not my mother language!
              what im trying to say is that, after i upload the new firmware, i used the RRF config tool to give the right parameters to my duet.
              In the end, i left the ip, the gateway and the subnet mask as they were there by defaul, and I thought those were the correct ones. But they were not.
              So, i beleave i sent to the config of the board, different ip etc etc, and now it doesnt connect.
              Could it be right? If it is, do you know any way to solve this?
              Using your last suggestion....please,, can you tell me what is the M Commando i should use to set a new IP adress?
                @Phaedrux said in Update CR-10+Duet wifi from 2.05.1 to 3.0 firmware:
                M552 P192.168.1.190
                This sets the IP address.
                You can edit the config.g and enter that or you can test it first over USB terminal.
                M550 "CR-10"
                M552 S1 ; enable network
                M586 P0 S0 ; disable HTTP
                M586 P1 S0 ; disable FTP
                M586 P2 S0 ; disable Telnet
                Change that section to be
                M550 "CR-10"
                M552 S1 P192.168.1.190 ; enable network
                M553 P255.255.255.0 ; set netmask
                M554 P192.168.1.1 ; set gateway
                The commands are described here: https://duet3d.dozuki.com/Wiki/Gcode?revisionid=HEAD#Section_M552_Set_IP_address_enable_disable_network_interface
                  Hélder Rocha
                  now i having problems on yat... doesn give any access to any port!
                  Stephen6309undefined 1 Reply Last reply Reply Quote 0
                    Hélder Rocha
                      Hélder Rocha
                      is there a way to reset all things and start over?
                      • Stephen6309undefined
                        Stephen6309 @Hélder Rocha
                        @Hélder-Rocha Try running YAT in adminstrator mode. Right click and select Run as adminstrator.
                          Hélder Rocha @Stephen6309
                          @Stephen6309 the same appens... as i turn it on, it runs all the terminals avaiable and at the end, shows me the same message!
                          "YAT - [[Terminal21]-COM 5-Closed]
                            Hélder Rocha
                            Most problems are solved, but now i have this on YAT:
                            Warning: IP 192.168.1.2 requested file 'R/A3EKIDA4MTg1NDgxYm...' from HTTP server, possibly a virus attack
                              Phaedrux Moderator @Hélder Rocha
                              @Hélder-Rocha said in Update CR-10+Duet wifi from 2.05.1 to 3.0 firmware:
                              https://forum.duet3d.com/topic/18054/virus-warning-message?_=1612110244839
                              See here.
