Preview version of CNC optimized DWC.
Do you have your machine configured for CNC?
There should be an M453 somewhere in your config to enable CNC mode.
@Alpenprinter you need to put M453 to activate cnc mode and with that the dwc for cnc will appear!!
@Sindarius said in Preview version of CNC optimized DWC.:
M453
You are the best! Looking great!
Could s.o. please post the config.g and the homing files, for a e axis mill, so I have a starting point for configuration?
Hi All, hope you're well. I'm getting my head into this and have a couple of [newbie] questions:
- I'm setting up a z-probe but there is no z probe value on display - should I do the the calibration on the classic DWC then switch over to CNC? Same applies for endstop switches I guess.
- The set work Xyz button: does that link to a macro or does is just trigger a G92 command?
Really think this is a great project!
Thanks,
Neil
@neilo said in Preview version of CNC optimized DWC.:
Those are items that will be addressed in a future version of the DWC-CNC ui.
It is issuing a G10 L20 command to set the WCS.
My understanding and someone please correct me if I am wrong G92 changes all of the WCS so I avoided it in this case.
Thanks,
Neil -
G92 does not affect WCS offsets.
Awesome thanks both!
I’ve been using the preview version for a few jobs and find it a big improvement on the standard DWC for CNC. A couple of thoughts from this experience are:
The X and Y are displayed to 1 decimal place. For me it would be useful to be able to see 2 decimal places, perhaps selectable as a machine specific option, or maybe just on the DRO plug-in screen?
In the jog plug-in screen, buttons to set X,Y and Z to zero in the current work coordinate system would be very useful (as has been mentioned by others).
However, perhaps a better option might be to provide access to macro buttons on the right hand side of either the jog screen or DRO screen and then we can define our own macros to set XY, do Z-probing etc.?
@cjm Thank you for the feedback. As mentioned some of these items are on my todo list. The extra decimal places make sense to me as well. I will play with the jog control a bit more. Probably switch the home buttons out and put in a home machine and go to zero set of buttons.
@Adamfilip Thanks for the feedback.
I need to look further into continuous movement. I tried some experiments with it and the problem that I ran into is that it tends to overshoot because the gcode commands are queued. The other jog control plugin that I wrote for gamepads has a similar issue.
As far as frequency that is driven by the DWC getting updates from the Duet. Under machine specific you can adjust the frequency of updates (Default is 250ms). Lowering that number will increase the number of updates which will cause the UI to refresh quicker.
An idea that just came to my mind: how about a user-switch to select between incremental and continuous movement and the latter will accumulate all jog commands until the user stops sending movement commands for e.g. 1s (possibly configurable). While this time show a small indicator on where the journey will end and only send the movement once this "presetting" is done?
Not sure if it's a good idea to do it like that. But I wanted to toss it into the ring.
@wilriker I do something similar to what mention with my gamepad jogging plugin. When you first hold down a control on the game pad the first few moves stutter a little before moving at a smooth pace.
The CNC control I have personally used the most uses a USB connection so it doesn't have to worry about packet travel.
It's worth playing with it some more, I do understand the desire for continuous jogging especially on larger machines.
Hi guys, I'm not really into this whole github thing. I think you are doing AN AMAZING work here. But I have no idea how i can run DWC-CNC on my Duet2wifi... can somebody give an idiot(me^^) a hint?!
(I uploaded the files of the release:
into my www-folder of the SD Card.. But my interface still looks like the 3D-printer interface:
@AverageUser Perhaps it's still cached. Try pressing Ctrl+Shift+R to reload DWC.
@chrishamm already tried: did not change.
@AverageUser You can upload the DWC-SD ZIP file on the System page too. Does that work?
@chrishamm And what do I do with the files inside the www-folder then? Erase them?
@AverageUser Under normal circumstances you don't need to worry about extra files, they don't take up much space. When you upload the ZIP bundle on the System Files page, the existing files in /www are automatically overwritten.
@chrishamm Okey i put the zip.file in the sys-folder:
and deleted all the files in the www-folder. Let's see what happens.
Im completely lost with this... lol ^^
