    Tool Fan selector in Duet Web Control
    Duet Web Control
    1.9k
      The tool fan number is the one defined in the F parameter of the M563 command for the current tool. The default is fan 0. The point of the tool fan slider is that in an IDEX machine or tool changer, you don't need to worry about which fan the current tool is using.
      You may prefer to omit the name "Cooling" from your M106 P0 command so that the fan doesn't show up twice.
      • appjawsundefined
        appjaws
        Tried that I now have 2 buttons "TOOL FAN" and " FAN 0"
        appjaws - Core XYUV Duet Ethernet Duex5
        firmware 3.5.0-rc.4 Web Interface 3.5.0-rc.4
        Ormerod 1-converted to laser engraver, Duet wifi
        OpenSCAD version 2024.03.18
        Simplify3D 5.1.2
          dc42 administrators @appjaws
          @appjaws said in Tool Fan selector in Duet Web Control:
          In Duet Web Control 2.0.7 there is a "Change visibility" link that you can click on to select which fans you want to be visible.
          • appjawsundefined
            appjaws
            I am using Duet Web Control 2.0.7 but can't find the "Change visibility" link
            Where is it?
            Simplify3D 5.1.2
              • appjawsundefined
                appjaws
                Thanks for your reply @dc42,
                This is the Dashboard screen, as you can see it lists the "TOOL FAN" and " FAN0" buttons.
                They both do the same thing but I can't remove either of them and still have a working fan
                This is the Status screen with the "TOOL FAN" not selected and the "FAN0" selected
                Simplify3D 5.1.2
                  One for @chrishamm I think.
                  toddelundefined 1 Reply Last reply Reply Quote 0
                  • toddelundefined
                    toddel @dc42
                    @dc42 Hi...
                    I have the same issue... "TOOL FAN" controls just X1 Part Cooling. Useless...
                    Is there already a solution?
                    M950 F0 C"fan0" Q20000												; Define Fan0 for T0 Part Cooling
                    M106 P0 S0 H-1 C"X1 Part Cooling"									; Set Fan0 to default off, manual control
                    M950 F1 C"fan1"														; Define Fan1 for T0 Hotend cooling
                    M106 P1 S1 H1 T45 C"Hotend1"											; Set Fan1 to Thermostatic control, max RPM at 45C
                    M950 F2 C"duex.fan3" Q20000												; Define Fan0 for T0 Part Cooling
                    M106 P2 S0 H-1 C"X2 Part Cooling"									; Set Fan0 to default off, manual control
                    M950 F3 C"duex.fan4"														; Define Fan1 for T0 Hotend cooling
                    M106 P3 S1 H1 T45 C"Hotend2"											; Set Fan1 to Thermostatic control, max RPM at 45C
                    Board: Duet 2 WiFi (2WiFi)
                    Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 3.2-beta2 (2020-10-05b2)
                    Duet WiFi Server Version: 1.24beta2-05b1
                    Duet Web Control 3.2.0-beta2
                    Thanks in advance....
                      Phaedrux Moderator @toddel
                      @toddel Can you post your tool definition section of the config as well?
                      Also, 3.2 final is now available. https://github.com/Duet3D/RepRapFirmware/releases/tag/3.2
                      • Nellorundefined
                        Nellor
                        I can confirm this. It becomes visible (TOOL FAN) at the Dashboard when you switch the heater to active.
                        RepRapFirmware for Duet 3 MB6HC 3.2
                        M563 P0 S"Extruder" D0 H1 F0:1               ; define tool 0
                        G10 P0 X0 Y0 Z0                              ; set tool 0 axis offsets
                        G10 P0 R0 S0                                 ; set initial tool 0 active and standby temperatures to 0C
                        M950 F0 C"out9" Q200                         ; create fan 0 (print cooling fan) on pin out9 and set its frequency
                        M106 P0 C"Part Cooling" S0 H-1               ; set fan 0 custom name and value. Thermostatic control (H-1) is turned off
                        M950 F1 C"out7" Q500                         ; create fan 1 (hot end fan) on pin out7 and set its frequency
                        M106 P1 S1.0 H1 T45         		     ; set fan 1 name and value. Thermostatic control (H1) is turned on
                          Phaedrux Moderator @Nellor
                          @Nellor What exactly are you confirming?
                          The Tool Fan slider will control the fan of the currently selected tool. You only have one tool defined, so Tool fan will control the fan called "Part Cooling".
                          That should be F0 and not F0:1 since your fan1 is thermostatically controlled.
                          • Nellorundefined
                            Nellor
                            Ok, thanks for the hint this is indeed wrong.
                            What I don't understand is why I have two sliders at the dashboard then?
                            So typically TOOL FAN and F0 or the custom name for F0.
                            I want only one to be visible in that case then TOOL FAN as there is only one tool.
                            And this was also the question from the thread opener:
                              @Nellor On the status page there is a button to "Change Visibility" of the fans there. See if hiding the tool fan there also hides it on the dashboard. If it doesn't that could be a feature request.
                              Nellorundefined 1 Reply Last reply Reply Quote 0
                              • Nellorundefined
                                Nellor @Phaedrux
                                @Phaedrux
                                Doesn't work, already tried... it hides only at the status page...
                                • Nellorundefined
                                  Nellor
                                  @Phaedrux said in Tool Fan selector in Duet Web Control:
                                  This is the thing what I wanted to confirm from the both guys before me 😉
                                    @Nellor I've brought that forward as a request. Until then, best just ignore it? Just try to keep in mind that it makes a lot more sense when multiple tools (or even LEDs on a fan header) are involved.
                                    • Nellorundefined
                                      Nellor @Phaedrux
                                      @Phaedrux
                                      Thank you!
                                      Of course I understand the intention in that case and it makes sense....
                                      • DK4YAundefined
                                        DK4YA
                                        I'll try here. There is still no solution for the double controller with the same function?
                                          Phaedrux Moderator @DK4YA
                                          @DK4YA said in Tool Fan selector in Duet Web Control:
                                          The solution is to hide the slider if you don't want to see it duplicated.
