    Tool Fan selector in Duet Web Control
    Duet Web Control
    1.8k
    • appjawsundefined
      appjaws
      I am using Duet Web Control 2.0.7 but can't find the "Change visibility" link
      Where is it?
      appjaws - Core XYUV Duet Ethernet Duex5
      firmware 3.5.0-rc.4 Web Interface 3.5.0-rc.4
      Ormerod 1-converted to laser engraver, Duet wifi
      OpenSCAD version 2024.03.18
      Simplify3D 5.1.2
        dc42 administrators @appjaws
        • appjawsundefined
          appjaws
          Thanks for your reply @dc42,
          This is the Dashboard screen, as you can see it lists the "TOOL FAN" and " FAN0" buttons.
          They both do the same thing but I can't remove either of them and still have a working fan
          This is the Status screen with the "TOOL FAN" not selected and the "FAN0" selected
          Simplify3D 5.1.2
            One for @chrishamm I think.
            toddelundefined 1 Reply Last reply Reply Quote 0
            • toddelundefined
              toddel @dc42
              @dc42 Hi...
              I have the same issue... "TOOL FAN" controls just X1 Part Cooling. Useless...
              Is there already a solution?
              M950 F0 C"fan0" Q20000												; Define Fan0 for T0 Part Cooling
              M106 P0 S0 H-1 C"X1 Part Cooling"									; Set Fan0 to default off, manual control
              M950 F1 C"fan1"														; Define Fan1 for T0 Hotend cooling
              M106 P1 S1 H1 T45 C"Hotend1"											; Set Fan1 to Thermostatic control, max RPM at 45C
              M950 F2 C"duex.fan3" Q20000												; Define Fan0 for T0 Part Cooling
              M106 P2 S0 H-1 C"X2 Part Cooling"									; Set Fan0 to default off, manual control
              M950 F3 C"duex.fan4"														; Define Fan1 for T0 Hotend cooling
              M106 P3 S1 H1 T45 C"Hotend2"											; Set Fan1 to Thermostatic control, max RPM at 45C
              Board: Duet 2 WiFi (2WiFi)
              Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 3.2-beta2 (2020-10-05b2)
              Duet WiFi Server Version: 1.24beta2-05b1
              Duet Web Control 3.2.0-beta2
              Thanks in advance....
                Phaedrux Moderator @toddel
                @toddel Can you post your tool definition section of the config as well?
                Also, 3.2 final is now available. https://github.com/Duet3D/RepRapFirmware/releases/tag/3.2
                • Nellorundefined
                  Nellor
                  I can confirm this. It becomes visible (TOOL FAN) at the Dashboard when you switch the heater to active.
                  RepRapFirmware for Duet 3 MB6HC 3.2
                  M563 P0 S"Extruder" D0 H1 F0:1               ; define tool 0
                  G10 P0 X0 Y0 Z0                              ; set tool 0 axis offsets
                  G10 P0 R0 S0                                 ; set initial tool 0 active and standby temperatures to 0C
                  M950 F0 C"out9" Q200                         ; create fan 0 (print cooling fan) on pin out9 and set its frequency
                  M106 P0 C"Part Cooling" S0 H-1               ; set fan 0 custom name and value. Thermostatic control (H-1) is turned off
                  M950 F1 C"out7" Q500                         ; create fan 1 (hot end fan) on pin out7 and set its frequency
                  M106 P1 S1.0 H1 T45         		     ; set fan 1 name and value. Thermostatic control (H1) is turned on
                    Phaedrux Moderator @Nellor
                    @Nellor What exactly are you confirming?
                    The Tool Fan slider will control the fan of the currently selected tool. You only have one tool defined, so Tool fan will control the fan called "Part Cooling".
                    That should be F0 and not F0:1 since your fan1 is thermostatically controlled.
                    • Nellorundefined
                      Nellor
                      Ok, thanks for the hint this is indeed wrong.
                      What I don't understand is why I have two sliders at the dashboard then?
                      So typically TOOL FAN and F0 or the custom name for F0.
                      I want only one to be visible in that case then TOOL FAN as there is only one tool.
                      And this was also the question from the thread opener:
                        @Nellor On the status page there is a button to "Change Visibility" of the fans there. See if hiding the tool fan there also hides it on the dashboard. If it doesn't that could be a feature request.
                        Nellorundefined 1 Reply Last reply Reply Quote 0
                        • Nellorundefined
                          Nellor @Phaedrux
                          @Phaedrux
                          Doesn't work, already tried... it hides only at the status page...
                          • Nellorundefined
                            Nellor
                            @Phaedrux said in Tool Fan selector in Duet Web Control:
                            This is the thing what I wanted to confirm from the both guys before me 😉
                              @Nellor I've brought that forward as a request. Until then, best just ignore it? Just try to keep in mind that it makes a lot more sense when multiple tools (or even LEDs on a fan header) are involved.
                              • Nellorundefined
                                Nellor @Phaedrux
                                @Phaedrux
                                Thank you!
                                Of course I understand the intention in that case and it makes sense....
                                • DK4YAundefined
                                  DK4YA
                                  I'll try here. There is still no solution for the double controller with the same function?
                                    Phaedrux Moderator @DK4YA
                                    @DK4YA said in Tool Fan selector in Duet Web Control:
                                    The solution is to hide the slider if you don't want to see it duplicated.
