    Duet 3 HC6 one final try before i give up.
    Duet Web Control
    621
    • Nuramoriundefined
      Nuramori
      First thing that stands out, you’re missing the declaration of the kinematic style at the top. are you running a Cartesian, xy, or delta? The machine has no idea what to do. You need a M669 command
      Snippyundefined 1 Reply Last reply Reply Quote 1
      • Snippyundefined
        Snippy
        Allso is it possible to update 3.1.1 to 3.2 from webcontroll?
        Since the update via usb takes around 4 hours to get the board out of its hideyhole and dont have a laptop to avoid ground loops.
        • Vetiundefined
          Veti @Snippy
          @Snippy said in Duet 3 HC6 one final try before i give up.:
          yes
          see
          https://duet3d.dozuki.com/Wiki/Installing_and_Updating_Firmware#Section_Usual_procedure
          but since you did the update to 3.1.1 not via web interface you might be missing the 3.0 files.
          Snippyundefined 1 Reply Last reply Reply Quote 0
          • Snippyundefined
            Snippy @Nuramori
            @Nuramori Never had any print quality issues, if it desides to load the gcode.
            Its a cartesian system.
            • Snippyundefined
              Snippy @Veti
              @Veti
              O lord have mercy.
              • fcwiltundefined
                fcwilt @Snippy
                @Snippy
                Sorry to hear you are having problems.
                Could you provide me with brief list of the things that are not working for you?
                I have a MBH6C board on my workbench at the moment and it is working fine. It's very likely I can get yours working for you as well.
                I have printers running both 3.1.1 and 3.2.
                • jrocklandundefined
                  jrockland @Snippy
                  @Snippy I just copi/pasted from the reprap gcode page, about how to use m552
                  • Snippyundefined
                    Snippy
                    WOW... the webcontroll update from 3.1.1 to 3.2 worked without a sacrifice.
                    • fcwiltundefined
                      fcwilt @Snippy
                      Just so you know 3.2 has issues of it's own that occur in certain configurations that are somewhat uncommon.
                      • Snippyundefined
                        Snippy @fcwilt
                        @fcwilt was not supriced 🙂
                        • Snippyundefined
                          Snippy
                          Well the update seems to have increased the upload speed significantly.
                          • Snippyundefined
                            Snippy
                            allso now my independent twin print cooling systems seems to work.
