    Feedback wanted: conditional GCode without indentation
    Future Direction
    28
    54
    4.0k
    • DaveAundefined
      DaveA @fcwilt
      @fcwilt Yeah, I can agree with you on C++. I'd rather stick with straight C as most of my experience was with windows device drivers. In any case, it's better than Python. 🙂
      • zaptaundefined
        zapta @fcwilt
        @fcwilt said in Feedback wanted: conditional GCode without indentation:
        END by itself is easy but if you don't see it in context you don't know what it is the end of. It might be better to have unique keywords - ENDWHILE, ENDIF or something along those lines.
        One option is to annotate it with comments.
        END ; while xyz
        BTW, I am also not a fan of white space indentation having semantic meaning. It's too fragile, event with language specific editors that support it.
        fcwiltundefined 1 Reply Last reply Reply Quote 2
        • reghend79undefined
          reghend79
          I think both keyword-delimiting and indentation-delimiting should be permitted in the same file to allow for flexibility and varying degrees of clarity. I'm working on analyzing print data in Matlab to create feedback control, and I am quite fond of using both indentations and "end" statements at the same time. The indentations are not normally required in Matlab, but they're done automatically to help visualize the blocks.
          • zaptaundefined
            zapta @reghend79
            @reghend79 said in Feedback wanted: conditional GCode without indentation:
            That's a good point, END should still allow indentation for code clarity, though the indentation would have no semantic impact. E.g. these code snippet should have the same meaning
                        IF
                 COMMAND1
              COMMAND2
            COMMAND3
                END
            IF
            COMMAND1
            COMMAND2
            END
            IF
                COMMAND1
                COMMAND2
                END
            IF
                COMMAND1
                COMMAND2
            END
            • fcwiltundefined
              fcwilt @zapta
              @zapta said in Feedback wanted: conditional GCode without indentation:
              END ; while xyz
              True but with specific keywords I'm forced to do the "right" thing. 😉
              • alankilianundefined
                alankilian
                Here's one way to "DO" it. 🙂
                https://www.cnccookbook.com/cnc-g-code-macro-conditions-looping/
                • garyd9undefined
                  garyd9 @fcwilt
                  @garyd9 said in Feedback wanted: conditional GCode without indentation:
                  Can you please give an example of a gcode sequence that would impractical with the current space delimiting blocks?
                  The issue is gcode files as generated by a slicer - not the files you would create yourself on the duet.
                  That doesn't answer the question. Without an example of the problem, it's difficult to give a reasonable opinion on a proposed solution.
                  fcwiltundefined dc42undefined 2 Replies Last reply Reply Quote 0
                  • botundefined
                    bot
                    I think removing all indentation/whitespace from the syntax is a good idea. I also think a single END keyword is best. Multiple end keywords is just unnecessary. Keep track of the ENDs the same way one keeps track of the }s.
                    *not actually a robot
                    • fcwiltundefined
                      fcwilt @garyd9
                      As dc42 said in his opening post:
                      However, the need to indent the body of a conditional or loop makes it impractical to use a while-loop to create a looping GCode file, for example for a belt printer.
                      That seems clear enough.
                        dc42 administrators @garyd9
                        Suppose you generate a GCode file using a slicer. But you have a belt printer and you want to print it 10 times, with a belt movement between each iteration.
                        Using existing slicers, there is no way to use the slicer start and end scripts to achieve this.
                        You could achieve it by editing the GCode file, but then you would have to indent almost the whole GCode file so that it became the body of the while-loop.
                        If we offer the option to delimit if- and while-commands explicitly, then you could insert one line near the start of the file (the 'while' line), and one near the end (the 'end' line). You might even be able to put the 'while' line in your slicer start script, and the 'end' line in the end script, so that you don't need to edit the file at all.
                        Does that make the reason for this proposal clearer?
                        garyd9undefined theruttmeisterundefined OwenDundefined 3 Replies Last reply Reply Quote 2
                        • fcwiltundefined
                          fcwilt @bot
                          @bot said in Feedback wanted: conditional GCode without indentation:
                          '}' symbols are evil incarnate.
                          botundefined zaptaundefined 2 Replies Last reply Reply Quote 0
                          • botundefined
                            bot @fcwilt
                            @fcwilt } // they don't seem so bad to me
                            • tekkydaveundefined
                              tekkydave @dc42
                              @dc42 curly braces for me every time. I don't see the point of adding extra keywords that just take up space.
                              ~ tekkydave ~
                              D-Bot: 300x300mm | Duet WiFi + Duex2 | 3 independent z motors | X,Y & Z linear rails | E3D Titan Aero + V6 | Precision Piezo z-probe
                              FreeCAD, PrusaSlicer
                                tekkydave @fcwilt
                                @fcwilt I once used a language called pl/9 that had a repeat...until. I miss it from every other language I've used since.
                                ~ tekkydave ~
                                • fcwiltundefined
                                  fcwilt @tekkydave
                                  @tekkydave said in Feedback wanted: conditional GCode without indentation:
                                  I never heard of PL/9 - I used PL/1 for a bit - it's looping syntax was flexible and consistent.
                                  My programming language of choice is Delphi.
                                  • fcwiltundefined
                                    fcwilt @tekkydave
                                    Keywords have a mnemonic value that isolated arbitrary symbols lack.
                                    • garyd9undefined
                                      garyd9 @dc42
                                      @dc42 said in Feedback wanted: conditional GCode without indentation:
                                      Yes, much clearer. Thank you.
                                      I'm not familiar with belt printers and how this might be used - which left (and still leaves) my understanding lacking.
                                      That being said, can the problem be addressed using macros? Can a print job's gcode use M28/M29 to create new files?
                                      ; ----- start gcode
                                      ; inital printer setup
                                      M28 job.gcode ; cause the actual gcode to be written to job.gcode
                                      ; ------- actual print gcode generated by slicer
                                      ; --------- end gcode
                                      M29  ; stop/save job.gcode
                                      ;  -- here would be the loop for running the print job
                                      while (some_condition)
                                             ; belt movement
                                             M32 job.gcode
                                      <eof>
                                      (I have no idea if a gcode file can use M28/m29 to create another gcode file, but if it can...)
                                      • theruttmeisterundefined
                                        theruttmeister @dc42
                                        That could be simplified down to a gcode command that executed a specific .gcode file multiple times:
                                        Mxxx thisprintjob.gcode S10
                                        For example.
                                        That has the advantage of not needing anything like the complexity of conditionals.
                                        I think the fact that it is a programming loop is making people think that the solution is to create the ability in g-code to code loops. Where as in fact for the described use case at least, its not really a loop, its just a way to not have the file be 10 times longer than it needs to be.
                                        At there other things that actually are conditional and not just 'do x, y number of times'?
                                        (in fact, all this could be done in DWC... which in some ways makes more sense).
                                        Isolate, substitute, verify.
                                        • zaptaundefined
                                          zapta @fcwilt
                                          The Duet's firmware is full of them, don't bring it into your home. 😉
                                          https://github.com/Duet3D/RepRapFirmware/blob/dev/src/Movement/DriveMovement.cpp
                                          • garethkyundefined
                                            garethky
                                            1. end is fine
                                            2. I would pick just 1 way to do it, even if that way breaks existing code. Now is the time to make breaking changes. I don't want to imagine a) what tricky things users will think up to fool themselves b) what implementation bugs will arise due to the complexity of having 2 ways to do it.
                                            3. As a software engineer, this question makes my skin crawl. I really wouldn't do anything for whole files, just blocks. But if you really want to mix both styles, I would do this: require unintended blocks to have a begin and end keywords, on their own lines, to delimit the block. That way begin/end can be used with all of the existing block types without renaming them (the names are perfectly good as-is).
                                            if foo == bar
                                                begin
                                            ; begin unruly slicer generated gcode
                                            G10
                                            G1 X50 Y50 F5000
                                            ; and so on ...
                                                end
                                            This is basically a friendlier versions of parens{<block>}. You could also postfix the if statement with python's : to indicate an unintended block start but this is so subtle and easy to miss that I think it is visiting an evil on the intended audience.
                                            Visual Basic has "OrElse" and "AndAlso", because they refused to re-define the meaning of "or" and "and". Don't be Visual Basic.
