    BLTouch Config.
    2.3k
    • Hélder Rochaundefined
      Hélder Rocha
      the config you see, i have "Z" value at "0", because i put it to "0" before a leave my printer last night. I intent to restart the configuration today.
      • Vetiundefined
        Veti
        post your homeall
        Hélder Rochaundefined 1 Reply Last reply Reply Quote 0
          Hélder Rocha @Veti
          @Veti can you tell me how to use the </>? I dont know how and i´ll like to do it correctly!
            Hélder Rocha
            ; homeall.g
            ; called to home all axes
            ; generated by RepRapFirmware Configuration Tool v3.2.2 on Sun Jan 31 2021 16:45:05 GMT+0000 (Hora padrão da Europa Ocidental)
            G91 ; relative positioning
            G1 H1 X-305 Y-305 F3000 ; move quickly to X and Y axis endstops and stop there (first pass)
            G1 H2 X5 Y5 F6000 ; go back a few mm
            G1 H1 X-305 Y-305 F240 ; move slowly to X and Y axis endstops once more (second pass)
            G90 ; absolute positioning
            G1 X200 Y150 F6000 ; go to first bed probe point and home Z
            ;G91 ; relative positioning
            ;G90 ; absolute positioning
            • Vetiundefined
              Veti
              @Hélder-Rocha said in BLTouch Config.:
              G31 P25 X-40 Y-10 Z1.20 ; Set Z probe trigger value, offset and trigger height
              your original value was far bigger
                Hélder Rocha @Veti
                @Veti it was not workig correctly either with the old firmware. After update the firmware, i already tried with 1.60 and it stops at 0,40mm.... the question is: Dont matter the value i define in G31 "Z", the probe will allways stop at 0,40 mm plus 5mm(because G1 Z5 F100 ) above the bed. If i down the nozzle by 5mm, in the DWC will show the "Z" Value defined on G31, but when i go measure with the wedge feeler, it is 0,40mm above the bed. Allways!
                • Vetiundefined
                  Veti @Hélder Rocha
                  0,40
                  do you use , or . ?
                  since you never posted the config with a value in it its hard to tell
                    Hélder Rocha @Veti
                    @Veti yes... is with "."
                    • Vetiundefined
                      Veti
                      send the G31 command to verify that your offset is put in correctly
                        Phaedrux Moderator @Hélder Rocha
                        When you click that button in the post creation window it adds a section between three dots above and below. Put your code in the middle where it says code_text.
                        code_text
                        • shubharora734undefined
                          shubharora734
                          This post is deleted!
