    BLTouch Config.
    2.3k
    • Hélder Rochaundefined
      Hélder Rocha @Veti
      @Veti Hi, thank you for the reply.
      In the first point you mention, how do i determine the beta value?
      In the second point, yes, i know. I have allready stablish "z" with the value the DWC determinate after G30 S-. In fact, i´ve give it different vlues, seen the first time, it stys 0,40 above the bed. I tried to low the nozzle a litle, increasing the "Z" value, but it stays allways at 0,40... regardless the value i have on "Z"!
      Hélder Rochaundefined 1 Reply Last reply Reply Quote 0
        Hélder Rocha @Hélder Rocha
        @Hélder-Rocha "G30 S-1"
        • Vetiundefined
          Veti
          so modify the G31 in the config and test the homing.
            Hélder Rocha @Veti
            @Veti i have done it several times...i´ve defined Z to 0.23, the first value obtained with G30 S-1. After restart the duet, and do homing, the zozzle stoped 0,40 mm above the bed, but the Z value on the DWC is 0,23mm!
            After that, i encreased the Z value 10 by 10 to check if the nozzle wold get closer to the bed! But nothing, it stays at 0,40mm all the times.
              Hélder Rocha
              the config you see, i have "Z" value at "0", because i put it to "0" before a leave my printer last night. I intent to restart the configuration today.
              • Vetiundefined
                Veti
                post your homeall
                  Hélder Rocha @Veti
                  @Veti can you tell me how to use the </>? I dont know how and i´ll like to do it correctly!
                    Hélder Rocha
                    ; homeall.g
                    ; called to home all axes
                    ; generated by RepRapFirmware Configuration Tool v3.2.2 on Sun Jan 31 2021 16:45:05 GMT+0000 (Hora padrão da Europa Ocidental)
                    G91 ; relative positioning
                    G1 H1 X-305 Y-305 F3000 ; move quickly to X and Y axis endstops and stop there (first pass)
                    G1 H2 X5 Y5 F6000 ; go back a few mm
                    G1 H1 X-305 Y-305 F240 ; move slowly to X and Y axis endstops once more (second pass)
                    G90 ; absolute positioning
                    G1 X200 Y150 F6000 ; go to first bed probe point and home Z
                    ;G91 ; relative positioning
                    ;G90 ; absolute positioning
                    • Vetiundefined
                      Veti
                      @Hélder-Rocha said in BLTouch Config.:
                      G31 P25 X-40 Y-10 Z1.20 ; Set Z probe trigger value, offset and trigger height
                      your original value was far bigger
                        Hélder Rocha @Veti
                        @Veti it was not workig correctly either with the old firmware. After update the firmware, i already tried with 1.60 and it stops at 0,40mm.... the question is: Dont matter the value i define in G31 "Z", the probe will allways stop at 0,40 mm plus 5mm(because G1 Z5 F100 ) above the bed. If i down the nozzle by 5mm, in the DWC will show the "Z" Value defined on G31, but when i go measure with the wedge feeler, it is 0,40mm above the bed. Allways!
                        • Vetiundefined
                          Veti @Hélder Rocha
                          0,40
                          do you use , or . ?
                          since you never posted the config with a value in it its hard to tell
                            Hélder Rocha @Veti
                            @Veti yes... is with "."
                            • Vetiundefined
                              Veti
                              send the G31 command to verify that your offset is put in correctly
                                Phaedrux Moderator @Hélder Rocha
                                When you click that button in the post creation window it adds a section between three dots above and below. Put your code in the middle where it says code_text.
                                code_text
                                • shubharora734undefined
                                  shubharora734
                                  This post is deleted!
