    Problems with IDEX printer configuring
    1.2k
    • Visionaryundefined
      Visionary
      My machine is markforged kinematics style IDEX printer.
      ; generated by RepRapFirmware Configuration Tool v3.2.0 on Tue Dec 29 2020 21:29:27 GMT+0200 (Itä-Euroopan normaaliaika)
      G90                                                ; send absolute coordinates...
      M83                                                ; ...but relative extruder moves
      M550 P"My Printer"                                 ; set printer name
      M669 K11 Y-1:-1:0:1
      M552 P0.0.0.0 S1                                   ; enable network and acquire dynamic address via DHCP
      M586 P0 S1                                         ; enable HTTP
      M586 P1 S0                                         ; disable FTP
      M586 P2 S0                                         ; disable Telnet
      M569 P0.0 S1                              		   ; physical drive 0.0 goes forwards X
      M569 P0.1 S1                               		   ; physical drive 0.1 goes forwards U
      M569 P0.2 S1                                       ; physical drive 0.2 goes forwards Y
      M569 P0.3 S1                                       ; physical drive 0.3 goes forwards Z
      M569 P0.4 S1                                       ; physical drive 0.4 goes forwards E0
      M569 P0.5 S1                                       ; physical drive 0.5 goes forwards E1
      M584 X0.1 U0.0 Y0.2 Z0.3 E0.4:0.5                          	; set drive mapping
      M350 X16 U16 Y16 Z16 E16:16 I1                              ; configure microstepping without interpolation
      M92 X80.00 U80.00 Y80.00 Z640.00 E2700:250          		; set steps per mm
      M566 X600.00 U600.00 Y600.00 Z60.00 E40.00:300              ; set maximum instantaneous speed changes (mm/min)
      M203 X12000.00 U12000.00 Y12000.00 Z180.00 E1800.00:1000          ; set maximum speeds (mm/min)
      M201 X1000.00 U1000.00 Y1000.00 Z20.00 E120.00:600                ; set accelerations (mm/s^2)
      M906 X1200 U1200 Y1000 Z1000 E980:980 I45                    	; set motor currents (mA) and motor idle factor in per cent
      M84 S30                                            				; Set idle timeout
      M569 P0.0 V25 H25 D3
      M569 P0.1 V25 H25 D3
      M569 P0.2 V25 H25 D3
      M915 P0.0 S3 R0 H134 T25 F1
      M915 P0.1 S3 R0 H134 T25 F1
      M915 P0.2 S3 R0 H134 T25 F1
      M208 X-38 U41 Y0 Z0 S1                                   ; set axis minima
      M208 X475 U439.5 Y400 Z375 S0                             ; set axis maxima
      M574 X1 S1 P"!^io1.in"                             ; configure active-high endstop for low end on X via pin !^io2.in
      M574 U2 S1 P"!^io2.in"                             ; configure active-high endstop for high end on U via pin !^io1.in
      M574 Y1 S1 P"io5.in"                             ; configure active-high endstop for low end on Y via pin !^io3.in
      M574 Z1 S1 P"!^io4.in"                             ; configure active-high endstop for low end on Z via pin !^io4.in
      M558 P0 H5 F120 T6000                              ; disable Z probe but set dive height, probe speed and travel speed
      M557 X15:215 Y15:195 S20                           ; define mesh grid
      M308 S0 P"temp0" Y"thermistor" T100000 B3974       ; configure sensor 0 as thermistor on pin temp0
      M950 H0 C"out0" T0                                 ; create bed heater output on out0 and map it to sensor 0
      M307 H0 B1 S1.00                                   ; enable bang-bang mode for the bed heater and set PWM limit
      M140 H0                                            ; map heated bed to heater 0
      M143 H0 S130                                       ; set temperature limit for heater 0 to 120C
      M308 S1 P"temp1" Y"thermistor" T100000 B4725 C7.06e-8       ; configure sensor 1 as thermistor on pin temp2
      M950 H1 C"out1" T1                                 ; create nozzle heater output on out1 and map it to sensor 1
      M307 H1 B0 S1.00                                   ; disable bang-bang mode for heater  and set PWM limit
      M143 H1 S280                                       ; set temperature limit for heater 1 to 280C
      M308 S2 P"temp2" Y"thermistor" T100000 B4725 C7.06e-8       ; configure sensor 1 as thermistor on pin temp2
      M950 H2 C"out2" T2                                 ; create nozzle heater output on out1 and map it to sensor 1
      M307 H2 B0 S1.00                                   ; disable bang-bang mode for heater  and set PWM limit
      M143 H2 S280                                       ; set temperature limit for heater 1 to 280C
      M307 H0 A110 C180 D5 B1 						   ; Bed slow temperature rise
      M950 F0 C"out7" Q500                               ; create fan 0 on pin out7 and set its frequency
      M106 P0 S0 H-1                                     ; set fan 0 value. Thermostatic control is turned off
      M950 F1 C"out8" Q500                               ; create fan 1 on pin out8 and set its frequency
      M106 P1 S0 H-1                                     ; set fan 1 value. Thermostatic control is turned off
      ; Tools ################################################
      ;M563 P2 D0:1 H1:2 X0:3 F1:1                                  ; define tool 0
      ;G10 P2 R0 S0 X50 U-50 Y0 Z0
      ; tool 0, X-axis
      M563 P0 D0 H1 X0 F0                                 ; define tool 0
      G10 P0 R0 S0 X0 Y0 Z0                                    ; set tool 0 axis offsets
      ; tool 1, U-axis
      M563 P1 D1 H2 X3 F1
      G10 P1 R0 S0 Y0 U0 Z0                                      ; set initial tool 1 active and standby temperatures to 0C
      M575 P1 S1 B57600                                  ; enable support for PanelDue
      T0													; select tool
      Issues:
      -During dual tool print when the other tool/extruder print starts the other tool/extruder does not move out of the way. I copied tpost and tfree files from dozuki IDEX guide.
      • When pausing dual extruder/tool print, one tool is chosen and jogging X or U axis moves only this axis.
        Also when this happens X and U coordinates are the same if I home those axes. Homing move of X and U axis is normal and does move as it is suppose to but does not set position correctly
      -Tool 1 heater can't be set active (for example heater to 180C) if homing is not done prior to it.
      Error message: "T1" "Error: G0/G1 insufficient axes homed".
      -When trying to heat up tools, The machine waits until the other tool has reached its temperature before the other tool can start to heat up. Shouldn't they be able to heat up concurrently?
      -When switching heating off/on I get message:
      "T-1 Warning: Obsolete use of S parameter on G1 command. Use H parameter instead."
      Main printer: 3-5 Axis, 400x400x450 Duet 6HC || https://grabcad.com/eetu-4/models
        Post your tool change files as well please.
        What firmware version? 3.2?
        Visionaryundefined 1 Reply Last reply Reply Quote 0
          Visionary @Phaedrux
          @Phaedrux
          Firmware version is 3.2-RC2.
          tfree0.g
          M83 				; relative extruder movement
          ;G1 E-2 F3600 		; retract 2mm
          M106 S0           	; turn off our print cooling fan
          G91 				; relative axis movement
          G1 Z3 F500 			; up 3mm
          G90 				; absolute axis movement
          G1 S2 X-48 F6000 	; park the X carriage at -37mm
          tfree1.g
          G1 Z3 F500 					; up 3mm
          G1 S2 U440 F6000 			; park the U carriage at +440mm
          tfree2.g
          G1 Z3 F500 						; up 3mm
          G28 X U 						; home the X and U carriages
          tpost0.g
          M106 R2           		; restore print cooling fan speed
          M116 P0 				; wait for tool 0 heaters to reach operating temperature
          ;G1 E2 F3600 			; extrude 2mm
          tpost1.g
          M116 P1 			; wait for tool 1 heaters to reach operating temperature
          tpost2.g
          M116 P2 			; wait for tool 2 heaters to reach operating temperature
          M567 P2 E1:1 		; set tool mix ratio
          M568 P2 S1 			; turn on mixing
          G1 E2 F3600 		; extrude 2mm from both extruders
            3.2 final is available now. Please update by uploading the zip file to the system tab: https://github.com/Duet3D/RepRapFirmware/releases/download/3.2/Duet2and3Firmware-3.2.zip
            Or if using the SBC and unstable branch use the instructions here: https://github.com/Duet3D/RepRapFirmware/releases/tag/3.2
            @Visionary said in Problems with IDEX printer configuring:
            This is because your tool change files are using G1 S moves instead of G1 H.
            This is likely because you have G28 X Y in your tol change files, but your homex and homey likely also have Z movements that occur when the Z axis isn't yet homed?
            Post your homing files.
              Visionary @Phaedrux
              @Phaedrux
              homeall.g
              ; Haq xy homing X,U,Y,Z-axes:
              G91
              G1 H2 Z7 F200 					; raise head 7mm to keep it clear of the bed
              G1 H1 X-405 U405 Y-405 F3000 ;S1 ; coarse home X, Y and U
              G1 H2 X5 Y5 U-5 F600              ; move 4mm away from the homing switches
              G1 H1 X-10 U10 Y-10     ;S1      ; fine home X, Y and U
              G1 H1 Z-380 F360                ; move Z down stopping at the endstop
              G90
              ;G91                    ; relative positioning
              ;G1 Z5 F100             ; lift Z relative to current position
              ;G90                    ; absolute positioning
              homeu.g
              G1 H2 Z5 F2000    ; lift Z relative to current position
              G1 H1 U475 F1800 ; move quickly to X axis endstop and stop there (first pass)
              G1 U5 F6000       ; go back a few mm
              G1 H1 U475 F600  ; move slowly to X axis endstop once more (second pass)
              G1 H2 Z-0.5 F6000   ; lower Z again
              homex.g
              G1 H1 X-475 F1800 ; move quickly to X axis endstop and stop there (first pass)
              G1 X5 F2000       ; go back a few mm
              G1 H1 X-475 F600  ; move slowly to X axis endstop once more (second pass)
              G1 H2 Z-5 F6000   ; lower Z again
              homey.g
              G91
              G1 H2 Z5 F6000    ; lift Z relative to current position
              G1 H1 Y-405 F1800 ; move quickly to Y axis endstop and stop there (first pass)
              G1 Y5 F6000       ; go back a few mm
              G1 H1 Y-405 F600  ; move slowly to Y axis endstop once more (second pass)
              homez.g
              G1 H1 Z-380 F1800 ; move Z down until the endstop is triggered
              G92 Z0            ; set Z position to axis minimum (you may want to adjust this)
              The homing files do have z-movement.
                They do, but they correctly use H2 so that's not the source of the errors. So that narrows it down to the G1 S2 commands and probably the G1 Z commands.
                  Visionary
                  I got rid of the errors (at least those that are given in normal use), but still got a few problems/unclear things to me:
                  • Paneldue jogging doesn't work the same as DWC jogging: DWC works as intended but paneldue moves sometimes axes back to previous position (home) when trying to jog another axis. When trying to move those axes that went to previous position even by 1mm they move back to position where they were before going back.
                  • When using tool 2 (U-axis extruder) to print DWC shows tool 2 coordinates as X-axis position instead of as U-axis position. Is this how it should work?
                  • Standby temperatures set in Cura are not used during dual material/color printing. Instead standby temperatures are set to printing temperatures for both extruders for entire print job. I got around this by adding extruder start G-codes that set standby temperatures to extruders each time tool is changed. This though mean that standby temperatures are constant and are used with both extruders even when both extruders are not used.
                    What paneldue firmware version are you using?
                    For the cura standby temps, it might make more sense to set the standby temp with G10 and then use your tool change macros instead of relying on cura to set the temps.
                      Visionary @Phaedrux
                      @Phaedrux
                      I'm not sure which version paneldue firmware is, but I got it from Reprap configurator 1,5 - 3,5 months ago. Is there way to check it?
                        Yes you can check the PanelDue firmware version in the setup page on the PanelDue.
                        And update it like this
                        https://duet3d.dozuki.com/Wiki/PanelDue_Firmware_update
                          Visionary
                          I got the printer working otherwise but:
                          • X-axis positions relation between extruders seems to change randomly. This is seen as offset on dual color/material prints. Something seems to affect homing accuracy.
                          • Something caused offset on print bottom infill in relation to walls of the print. The other side of the print has more outer walls than the other even though they slicer shows the same amount of lines.Too many lines.png
                          • I need stealthchop tune move macro
                            Is the Z axis intentionally compressed for shorter prints?
                            Maybe try some IDEX calibration prints to get it tuned in?
                            There are many variations. Here is one.
                            https://www.thingiverse.com/thing:4565745
                              Visionary
                              The print objects are compressed on purpose to shorten print time and minimize print material usage. I've tried printing "proper" dual calibration models but those are hard to check for alignment because the tips of the spikes are often quite nonuniform (especially when prints don't seem to stick well to my print bed that is made of glass). Printing two cubes with the other on top the other allows feeling the edges of the cubes on each side. It should be accurate.
                              I just found a post that explains possible causes of inaccurate homing:
                              @dc42 said in Z homing fails often after update from 3.1.1 to 3.2:
                              It's as I expected. If two endstops are triggered with a delay of about 2.2ms between them, only the first one is registered until another input changes. When the delay is shortened to 1ms or lengthened to 5ms, the problem does not occur.
                              Now I can test fixes.
                              So I changed homingall.g move distances so that each axis is home slightly different time than the others. I'm still testing if this is the case.
                                Visionary
                                Repeating same print job without changing offsets in config or changing any slicer settings resulted with two prints that had different offsets on X/U-axis. The difference was 0,5 mm.
                                I also tested repeatability of X- and U-axis endstops by homing them and moving back 10 to 100mm and homing again and repeating. They seemed to be fine as difference for each measurement was within 0,05 mm.
                                I'm not sure what causes this. Position of Y-axis doesn't matter and Z-axis moves very slowly and it too has variance with position, but that is most likely just because heat expansion.
                                  Visionary
                                  I solved the issue with first layers (brim) not aligning with body of the part. It was caused by lost steps when tools are switched and the other extruder went to its minimum axis location and hit the other extruder slightly. This only happens with first layer and not with higher layers.
                                  I still have problems with setting offsets. If I calibrate the extruders with any calibration object to correct offsets, offsets on prints will eventually change to something else and a new calibrations is required. This happens relatively randomly and I got about 10 print jobs done with one calibration and after that even the calibration was hard as correcting the values did not give the results it should have.
                                    Visionary
                                    I think found the issue: printed parts (ABS) on X- and U-gantries were attached by M3 bolts were loose. The printed part had given in slightly. Weird thing is that it didn't seem to affect one extruder printing (no shifted layers during printing).
                                      I'm glad you solved it. Nice frog print!
                                        Visionary @dc42
                                        Thanks. I still need to do some tuning, but I think I'm getting close. It is possible to see some inconsistencies in black parts of the frog (green glitter hides those inconsistencies). I had line width set
                                        to low (0,38) on the frog, which probably causes the issue along with not quite right extrusion multipliers.
                                        I'll probably post more detailed description on my machine on "my Duet controlled machine" -section when I got the time.
                                          FWIW I printed the same frog some time ago.
                                            Visionary @dc42
                                            Nice!
                                            In your print layers are consistent so lines don't bulge randomly as in mine.
