PT100 with a Duet-3-6HC & Tool-Board-LC1 ?
@jay_s_uk said in PT100 with a Duet-3-6HC & Tool-Board-LC1 ?:
@JayJay none of us are stopping you from changing.
just please don't install the version of RRF for the GTR as I'd rather not have to help you with supportWhich part of Klipper/Octoprint is RRF ? i dont think it does have a RRF component in it, the best thing that was going for the Duet was the DWC and the fact that Klipper can now run DWC means people are no longer tied to the hardware to run the DWC.
@JayJay thats good. if you don't know about the STM port of RRF, I won't tell you
@JayJay said in PT100 with a Duet-3-6HC & Tool-Board-LC1 ?:
i on the other hand have no issues with my duet 3 or with any of my other boards running RRF
lucky you, but I suppose its too much to expect for it to do something so simple, and will be looked upon much like the "special use case" deckingman endures.
I saw my name mentioned. For what it's worth, I used to run PT100s on my gen 2 Duet Ethernet but ditched them long ago (well before I "upgraded" to gen 3) and reverted back to simple thermistors. They were just more trouble than they were worth IMO. The main problem being susceptibility to noise which I never fully cured (tried 4 wire mode, screened cable and all that stuff). PT100s may be inherently more accurate but if the signal is noisy, that simply negates any benefits.
I've made it fairly clear that I'm not the biggest fan of Duet Gen3 but personally, I wouldn't use the lack of support for PT100s as a reason to ditch it.
@Veti said in PT100 with a Duet-3-6HC & Tool-Board-LC1 ?:
i would suggest getting a pt1000 sensor
Thats not happening, if the supposed best control board cant accept an analog input from a P100 amplifier thats a pretty poor show.
I would rather rip out the Duet-3 , install the 32bit GTR PRO V1.0 and run Klipper/Octoprint with the dwc2-for-klipper-socket, a board I know is going to accept an analog signal.
The way you've responded comes off more as a troll than someone with an actual issue. So I'm clear, you're asking (demanding) that the TOOLBOARD support a PT100 sensor, but if it can't and won't, you're going to rip it out, buy new hardware, and HAVE to route wires from the head to the main board anyway, something that was a plausible solution with using the Duet3. You then say you're not willing to use a PT1000 because you'd have to buy additional hardware, and wait for it's delivery, so instead, that too is why you'd rip out a Duet3 and buy (and wait) for an entire new controller and hardware. Because why spend more money when you have parts.
I wanted to make sure I understand this logic.
i was using pt100 sensors instead of standard 104gt thermistor input years ago .
amplifiers are not necessary if you dont need very high accuracy .
if you must use pt100 i'm sure its possible to connect it to the tool board instead of pt1000 , and use level amplifier +series resistor for correct reading .
level amplifier as this one from e3d
https://e3d-online.com/products/pt100-amplifier-board?_pos=1&_sid=a6c5927e4&_ss=rboth pt1000 and pt100 sensors are linear , one has x10 more resistance then other , thats all .
your threats of changing board type are stupid and just annoy people . if you move to gtr board you wont be using tool board anyways , so why are you using one with the duet ?
Anyone from the Official Duet Support team care to comment.
The tool board is designed to support PT1000 sensors natively. PT1000 sensors are easier to read than PT100 sensors because they do not require an additional chip. The tool board does not have space to accommodate our PT100 daughter board.
E3D lists PT1000 sensors on their web site, but unfortunately they have been out of stock for some time. However, there are 3mm cartridge sensors available from other suppliers, for example https://reprap.world/products/extruder/extruder_parts/temperature_sensors/_pt1000_sensor_with_cartridge/, https://www.aliexpress.com/item/32859917151.html and https://www.hydraresearch3d.com/parts/nytmzmdl2wpnhxy84s8uvw9qhsdby5.
cough cough
And when i also have a few GTR V1.0 boards, if im going to have to rewire anyway why should I stick with the Duet if it cant do simple things.
@hackinistrator said in PT100 with a Duet-3-6HC & Tool-Board-LC1 ?:
I was using a toolboard for one reason, to save me having to send more wires to the head. its a simple fact if that I am either going to have purchase further hardware (A PT1000) and the associated wait for said hardware, or rewire, you cannot argue with that as that is the choices.
The toolboard still doesnt support heater autotuning (yes its allegedly coming, but thats been said for a long time) and the fan boys can wail all they want, in my opinion this is just another nail in the coffin in the list of things about the board that pi**es me off, one that has finally made me think sod it this hardware is not worth it anymore, I feel there is less and less positive reasons to keep using the Duet-3 as it has no benefits over other hardware anymore, for me personally the only thing that was keeping me using it was the DWC, but time has passed and there are evidently alternatives.
Im not asking anyone to agree with me, and everyone is entitle to have and voice their own opinion, and just as i am entitled to my opinion, and that is how my user experience with the Duet-3 has made me feel, and for me its time to move on from it to something else.
Sorry for the frustrations.
E3D had PT1000 sensors in stock again, https://e3d-online.com/products/pt1000-temperature-sensor.
Tool board heater auto tuning is available in firmware 3.3beta1 which was released last weekend.
