    Filament run out, tool sensitive?
    • Blacksheep99undefined
      Blacksheep99
      I've a dual extruder with two tools. Both have a simple run out sensor. I'm running 3.2 and having unloaded filament in T1 I want to run a print using just T0. T0 is active yet when I start the print it pauses telling me T1 is out of filament. I thought the FW was tool sensitive? Maybe I need to do something.
        Post your config?
          Blacksheep99
          config
          ; Configuration file for Duet Maestro (firmware version 3)
          ; generated by RepRapFirmware Configuration Tool v3.2.1 on Sat Jan 09 2021 18:02:08 GMT+0000 (Greenwich Mean Time)
          G90                                             ; send absolute coordinates...
          M83                                             ; ...but relative extruder moves
          M550 P"ST3Di280 Duet"                           ; set printer name
          M552 P192.168.0.60 S1                                ; enable network and acquire dynamic address via DHCP
          M586 P0 S1                                      ; enable HTTP
          M586 P1 S0                                      ; disable FTP
          M586 P2 S0                                      ; disable Telnet
          M569 P0 S1                                      ; physical drive 0 goes forwards
          M569 P1 S0                                      ; physical drive 1 goes backwards
          M569 P2 S1                                      ; physical drive 2 goes forwards
          M569 P3 S0                                      ; physical drive 3 goes backwards
          M569 P4 S1                                      ; physical drive 4 goes forwards
          M584 X0 Y1 Z2 E3:4                              ; set drive mapping
          M350 X16 Y16 Z16 E16:16 I1                      ; configure microstepping with interpolation
          M92 X91.4 Y105.29 Z1242.228  E103.93:109.13     ; set steps per mm
          M566 X1080.00 Y1080.00 Z60.00 E120.00:120.00    ; set maximum instantaneous speed changes (mm/min)
          M203 X6000.00 Y6000.00 Z180.00 E1200.00:1200.00 ; set maximum speeds (mm/min)
          M201 X420.00 Y420.00 Z20.00 E250.00:250.00      ; set accelerations (mm/s^2)
          M906 X800 Y800 Z800 E600:600 I30                ; set motor currents (mA) and motor idle factor in per cent
          M84 S30                                         ; Set idle timeout
          M208 X-150 Y-75 Z0 S1                           ; set axis minima
          M208 X150 Y75 Z150 S0                          ; set axis maxima
          M574 X1 S1 P"xstop"                             ; configure active-high endstop for low end on X via pin xstop
          M574 Y1 S1 P"ystop"                             ; configure active-high endstop for low end on Y via pin ystop
          M574 Z1 S2 										; configure Z-probe endstop for low end on Z
          ;M574 Z1 S1 									; Set endstops controlled by probe
          M950 S0 C"^zprobe.mod" 							; create servo pin 0 for BLTouch
          M558 P8 C"^zprobe.in" H3 F900 T6000 			; Set Z probe type to switch and the dive height + speeds
          G31 P50 X-52.5 Y5 Z1.825 							;Set Z probe trigger value, offset and trigger height 1.81
          M557 X-120:120 Y-65:75 S15                       ; define mesh grid
          M308 S0 P"bedtemp" Y"thermistor" A"Bed Heater" T100000 B3950  ; configure sensor 0 as thermistor on pin bedtemp
          M950 H0 C"bedheat" T0                           ; create bed heater output on bedheat and map it to sensor 0
          M307 H0 B0 S1.00                                ; disable bang-bang mode for the bed heater and set PWM limit
          M140 H0                                         ; map heated bed to heater 0
          M143 H0 S120                                    ; set temperature limit for heater 0 to 120C
          M308 S1 P"e0temp" Y"thermistor" A"Left Extruder" T100000 B3950   ; configure sensor 1 as thermistor on pin e0temp
          M950 H1 C"e0heat" T1                            ; create nozzle heater output on e0heat and map it to sensor 1
          M307 H1 B0 S1.00                                ; disable bang-bang mode for heater  and set PWM limit
          M143 H1 S300                                    ; set temperature limit for heater 1 to 280C
          M308 S2 P"e1temp" Y"thermistor" A"Right Extruder" T100000 B3950   ; configure sensor 2 as thermistor on pin e1temp
          M950 H2 C"e1heat" T2                            ; create nozzle heater output on e1heat and map it to sensor 2
          M307 H2 B0 S1.00                                ; disable bang-bang mode for heater  and set PWM limit
          M143 H2 S300                                    ; set temperature limit for heater 2 to 280C
          M950 F0 C"fan0" Q500                            ; create fan 0 on pin fan0 and set its frequency
          M106 P0 S0 H-1                                  ; set fan 0 value. Thermostatic control is turned off
          M950 F1 C"fan1" Q500                            ; create fan 1 on pin fan1 and set its frequency
          M106 P1 S1 H1:2 T45                             ; set fan 1 value. Thermostatic control is turned on
          M563 P0 S"Left" D0 H1 F0                       ; define tool 0
          G10 P0 X14.275 Y-0.25 Z0                                 ; set tool 0 axis offsets
          G10 P0 R0 S0                                    ; set initial tool 0 active and standby temperatures to 0C
          M563 P1 S"Right" D1 H2 F0                        ; define tool 1
          G10 P1 X-14.275 Y0 Z0                                 ; set tool 1 axis offsets
          G10 P1 R0 S0                                    ; set initial tool 1 active and standby temperatures to 0C
          M575 P1 S1 B57600								;PanelDue interface
          M572 D0:1 S0.4:0.4								;Pressure advance settings
          M912 P0 S1										;CPU Temp calibration
          M501											;Save to config.override heater tuning
          M911 S21 R23 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss
          M591 P1 C"e0stop" S1 D0   						;filament monitor left extruder connected to E0 endstop
          M591 P1 C"e1stop" S1 D1   						;filament monitor right extruder connected to E1 endstop
          T0												;Activate Extruder (Left)
          pause.g
          ; pause.g
          ; called when a print from SD card is paused
          M83            ; relative extruder moves
          G1 E-10 F3600  ; retract 10mm of filament
          G91            ; relative positioning
          G1 Z5 F360     ; lift Z by 5mm
          G90            ; absolute positioning
          G1 X0 Y0 F6000 ; go to X=0 Y=0
            Might just be easiest to send the command to disable monitoring of the sensor when not in use. Could even make it part of the tool change files. Have it monitor on tool selection and then stop monitoring in tpost.
            Blacksheep99undefined 1 Reply Last reply Reply Quote 0
              Blacksheep99 @Phaedrux
              @Phaedrux Thanks. I'll have a thing about how to work things.
