    Odd PWM fan voltage
    616
    • jnofsingerundefined
      jnofsinger
      I have this in my RR3.x configuration (see below) duet wifi 1.01 board
      Fan0 works as it is turned off at 0 and on when the slider increases all the way 100.
      Fan1 the hotend fan just stays on.. I don't mind as it is a 5v noctura so it is silent at least.
      Fan2 when the Duet is turned on it is 24v, when fan2 slider is moved to 100 it drops to 20v??
      From what I can tell are the PWM1/2 gone? I haven't done anything recently just tuned on the printer this morning. If that is the case I assume I can use a relay/extra pwm pin/power supply combo to make it work?
      I don't know what else to look for in determining what could be wrong, suggestions? Would inverting the PWM fan pin work?
      M106 P0 S0.0 H-1 ; set fan 0 value. Thermostatic control is turned off
      M950 F1 C"fan1" Q25000 ; create fan 1 on pin fan1 and set its frequency
      M106 P1 S1.0 H1 T45 ; set fan 1 value. Thermostatic control is turned on
      M950 F2 C"fan2" Q25000 ; create lights and set its frequency
      M106 P2 S0.0 H-1
        Can you post your full config.g and the responses from sending M122 and M98 P"config.g" please?
        jnofsingerundefined 1 Reply Last reply Reply Quote 0
          jnofsinger
          M122
          2/12/2021, 11:17:31 AM M122
          RepRapFirmware for Duet 2 WiFi/Ethernet version 3.2 running on Duet WiFi 1.0 or 1.01
          Board ID: 08DAM-999TL-MQ4S8-6J9D4-3SJ6N-K4B3W
          Used output buffers: 3 of 24 (24 max)
          Static ram: 23460
          Dynamic ram: 73540 of which 156 recycled
          Never used RAM 14924, free system stack 99 words
          Tasks: NETWORK(ready,163) HEAT(blocked,309) MAIN(running,452) IDLE(ready,19)
          Owned mutexes: WiFi(NETWORK)
          Last reset 22:30:09 ago, cause: power up
          Last software reset at 2021-02-11 12:33, reason: User, GCodes spinning, available RAM 14924, slot 1
          Error status: 0x04
          Aux0 errors 0,0,0
          MCU temperature: min 25.1, current 33.0, max 40.3
          Supply voltage: min 23.9, current 24.3, max 24.7, under voltage events: 0, over voltage events: 0, power good: yes
          Driver 0: position -600, standstill, SG min/max 0/344
          Driver 1: position 450, standstill, SG min/max 66/310
          Driver 2: position 11982, standstill, SG min/max not available
          Driver 3: position 0, standstill, SG min/max 0/1023
          Driver 4: position 0, standstill, SG min/max not available
          Driver 5: position 0
          Driver 6: position 0
          Driver 7: position 0
          Driver 8: position 0
          Driver 9: position 0
          Driver 10: position 0
          Driver 11: position 0
          Date/time: 2021-02-12 11:17:27
          Slowest loop: 217.12ms; fastest: 0.16ms
          === Storage ===
          Free file entries: 10
          SD card longest read time 52.5ms, write time 11.0ms, max retries 1
          DMs created 83, maxWait 2521067ms, bed compensation in use: mesh, comp offset 0.113
          === MainDDARing ===
          Scheduled moves 7237, completed moves 7237, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 8, 5], CDDA state -1
          === AuxDDARing ===
          Heater 0 is on, I-accum = 0.0
          Heater 1 is on, I-accum = 0.5
          Segments left: 0
          Movement lock held by null
          HTTP is idle in state(s) 0
          Telnet is idle in state(s) 0
          File is idle in state(s) 0
          USB is idle in state(s) 0
          Aux is idle in state(s) 0
          Trigger is idle in state(s) 0
          Queue is idle in state(s) 0
          LCD is idle in state(s) 0
          Daemon is idle in state(s) 0
          Code queue is empty.
          === Network ===
          Slowest loop: 200.38ms; fastest: 0.00ms
          HTTP sessions: 2 of 8
          • WiFi -
            Network state is active
            WiFi firmware version 1.25
            WiFi MAC address 5c:cf:7f:2b:ee:bf
            WiFi Vcc 3.48, reset reason Turned on by main processor
            WiFi flash size 4194304, free heap 24576
            WiFi IP address 172.16.37.118
            WiFi signal strength -55dBm, mode 802.11n, reconnections 0, sleep mode modem
            Clock register 00002002
            jnofsinger
            @Phaedrux said in Odd PWM fan voltage:
            M98 P"config.g
            2/12/2021, 11:18:49 AM Error: in file macro line 85: M280: parameter 'P' too high
            2/12/2021, 11:18:48 AM M98 P"config.g"
            HTTP is enabled on port 80
            FTP is enabled on port 21
            TELNET is disabled
              jnofsinger
              entire config.g
              ; generated by RepRapFirmware Configuration Tool v3.1.4 on Thu Aug 27 2020 15:36:37 GMT-0400 (Eastern Daylight Time)
              M550 P"Ender3" ; set printer name Ender3!
              M552 S1 ; enable network
              M586 P0 S1 ; enable HTTP
              M586 P1 S1 ; disable FTP
              M586 P2 S0 ; disable Telnet
              M569 P0 S0 ; physical drive 0 goes backwards
              M569 P3 S1 ; physical drive 3 goes backwards
              M92 X200.00 Y100.00 Z400.00 E869.11 ; set steps per mm
              M566 X800 Y800 Z24 E3000 ; set maximum instantaneous speed changes (mm/min)
              M203 X9000 Y9000 Z180 E6000 ; set maximum speeds (mm/min)
              M201 X500.00 Y500.00 Z100 E5000.00 ; set accelerations (mm/s^2)
              M906 X800 Y800 Z800 E1000 I50 ; set motor currents (mA) and motor idle factor in per cent
              M84 S30 ; Set idle timeout
              M208 X-3.0:232.5 Y4.5:212.0 Z0:250 ; set axis minima and maxima
              M950 S0 C"exp.heater7" ; create servo pin 0 for BLTouch
              M558 P9 C"^zprobe.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds use P9 for BLTouch
              G31 P500 X-57 Y-10 Z3.150 ; set Z probe trigger value, offset and trigger height
              M557 X25:172.6 Y25:203.9 S20 ; define mesh grid
              M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin e0temp
              M308 S3 P"spi.cs1" Y"thermocouple-max31856" ; configure sensor 2 as thermocouple via CS pin spi.cs1
              ;M950 H3 C"e1heat" T3 ; create chamber heater output on e1heat and map it to sensor 2
              ;M307 H3 B1 S1.00 ; enable bang-bang mode for the chamber heater and set PWM limit
              ;M141 H3 ; map chamber to heater 3
              M307 H1 R3.710 C142.5 D1.45 S1.00 V24.6 ; PID tune e0heat new style v6
              M307 H0 R0.294 C414.8 D0.66 S1.00 V24.4 ; PID tune bedheat winter
              M106 P2 S0.0 H-1 ; set lights0 value. Thermostatic control is turned off
              T0 ; select first tool
              ; Pressure Advance
              M572 D0 S0.060 ; pressure advance for a direct drive setup (aka retration)
              ; BLTouch startup
              G4 S2 ; Pause a couple seconds
              M280 P64 S160 ; Clear any alarms
              M402 ; retract pin just in case
                jnofsinger @Phaedrux
                @Phaedrux
                files posted. Thanks for looking Phaedrux
                Jim
                  Phaedrux Moderator @jnofsinger
                  @jnofsinger said in Odd PWM fan voltage:
                  This would be from this line:
                  In RRF3 the servo pin is defined by the M950 command as servo pin 0. So the M280 command needs to reference servo pin 0 as well. 64 was for the Maestro in RRF2.
                  So it should be M280 P0 S160
                    Is that still the case with the PWM frequency at the default Q500 instead of Q25000?
                    Are you aware of any potential shorts with the fans or at the hotend?
                    Can you examine the board closely to check if the fan mosfets look damaged at all?
                    https://duet3d.dozuki.com/Wiki/Connector_and_spare_part_numbers#Section_Fan_mosfet
                    Damaged mosfets could explain the behaviour you describe.
                    Do the fans work correctly when connected to the working Fan0 port?
                      @Phaedrux
                      That would certainly explain why the errors would never clear unless the printer was powered off. Thanks for the explanation.
                        @Phaedrux
                        I will investigate and report the results.
                          jnofsinger
                          So this is now fixed! The mosfets were damaged. The ones I had are black so they are very difficult to see the damage till I took the board out of the printer.
                          I ordered the newer ones from Digikey before the storm, so they Monday.
                          I can say this is the first time I replaced such a small part on the board, but with enough patience and practice on a scrap board it is completely do-able without expensive gear. I just have a regular $50.00 iron and a very small tip.. I then just dragged it over the ends and the solder stuck!
                          it was just pretty strange the under-voltage issue with the broken mosfets... not sure how long they were blown as the heater fan I have is 5v and it was pulling 4.4v for awhile.
                          Thanks again for your help!
                          Jim
