capacitive sensors PNP (NC) 10-24V for endstops on a Duet Wifi
@Gerd said in capacitive sensors PNP (NC) 10-24V for endstops on a Duet Wifi:
I measured at stop (signal) pin 0V when closed and 2.95V when opened.
Those values should be fine.
However your description of how the resistors are connected does not match the documentation you linked to.
Perhaps you description is simply incorrect because the documentation is consistent with my tests.
What board are you using?
What firmware is it running?
The diagram is consistent with your description.
It's just different from the suggested circuit in the documentation.
But what matters is the resultant signal levels and they appear to be good if they are measured on the input pin.
@fcwilt said in capacitive sensors PNP (NC) 10-24V for endstops on a Duet Wifi:
But what matters is the resultant signal levels and they appear to be good if they are measured on the input pin.better?
what is about config.g? could there something be wrong?
Well only you know what you actually wired.
If the new diagram is correct it IS consistent with the documentation AND makes more sense based on my tests.
But, as mentioned, the signal levels are what matter and they seem fine.
Now back to my questions:
What board are you using and what version of firmware is it running?
duet wifi 1.02 with RRF v3.2
Great. Thanks.
Have you started the Object Model browser plug-in? It would appear as an option in the DWC Settings section.
Great. Thanks.
not yet
not yet
You may want to do that as it makes it easy to verify what the firmware is seeing on the inputs.
no option, i've to look for this plugin.
Select "Allgemein" and check the PLUGINS there.
in both situations
My apologies.
I should have mentioned in the upper right of the Object Model browser there is a "Refresh" button that needs to be clicked to be sure that data displayed is correct.
See if that makes a difference in what you are seeing.
My apologies.
no difference, both situations the same. Control LED switched on/off.
Hmm...
The leads to a few questions:
- is there an LED on your inductive sensor the shows it's state?
- you measured the voltage at the end stop input pin?
- you are connected to and checking the correct end stop input?
Hmm...
yes, it also switches on/off. not triggered-on and triggered-off
I changed R1 to 56k and now measure 3,4V untriggered and a few mV triggered
Yes, correct endstop
I am at a loss
It seems like everything is correct yet not working - that is hard to understand.
How about the end stop LED on the duet - does it track the state of the LED on the inductive sensor?
Have you tried the other end stop inputs?
Yes the control LED on the board did track the situation, triggered - on, untriggered -off.
I tested with a microswitch, everything works fine.
Gerd
