capacitive sensors PNP (NC) 10-24V for endstops on a Duet Wifi
@Gerd said in capacitive sensors PNP (NC) 10-24V for endstops on a Duet Wifi:
duet wifi 1.02 with RRF v3.2
Great. Thanks.
Have you started the Object Model browser plug-in? It would appear as an option in the DWC Settings section.
@fcwilt said in capacitive sensors PNP (NC) 10-24V for endstops on a Duet Wifi:
Great. Thanks.
not yet
not yet
You may want to do that as it makes it easy to verify what the firmware is seeing on the inputs.
no option, i've to look for this plugin.
Select "Allgemein" and check the PLUGINS there.
in both situations
My apologies.
I should have mentioned in the upper right of the Object Model browser there is a "Refresh" button that needs to be clicked to be sure that data displayed is correct.
See if that makes a difference in what you are seeing.
My apologies.
no difference, both situations the same. Control LED switched on/off.
Hmm...
The leads to a few questions:
- is there an LED on your inductive sensor the shows it's state?
- you measured the voltage at the end stop input pin?
- you are connected to and checking the correct end stop input?
Hmm...
yes, it also switches on/off. not triggered-on and triggered-off
I changed R1 to 56k and now measure 3,4V untriggered and a few mV triggered
Yes, correct endstop
I am at a loss
It seems like everything is correct yet not working - that is hard to understand.
How about the end stop LED on the duet - does it track the state of the LED on the inductive sensor?
Have you tried the other end stop inputs?
Yes the control LED on the board did track the situation, triggered - on, untriggered -off.
I tested with a microswitch, everything works fine.
Gerd
i think there was a post a while back that the signal can be strong enought for the led to change but not the processor to pick up the signal
Gerd
Well I'm at a loss as to what is going wrong.
When you say you measured the signal level at the board input pin did you actually touch the meter probe to the pin itself?
@Veti said in capacitive sensors PNP (NC) 10-24V for endstops on a Duet Wifi:
measurements are 3,4V (untriggered) and a few mV (triggered)
Gerd
at the end where the two resistors are connected
maybe @dc42 can comment on that.
Gerd
I measured at the pin now, 3,4V (untriggered) and 1,45V !!!!! (triggered)
why this?
Well there is the problem - both of those states are the same logic level as far as the board is concerned.
You must have a wiring error.
