    Duet Wifi Powers Off when turning on Hot End
    354
    • PeteIHughesundefined
      PeteIHughes
      I'm setting up a newish CR10s.
      Have used the board successfully before.
      The Duet Wifi powers off immediately when I try to set any hot end temp.
      Wire connections all appear solid.
      Thermocouple reads approx room temp.
      Heated bed works fine (although it is a KEENOVO mains powered via a relay).
      Here is the config.g and M122 console log after the power down
      ; config.g
      ; config file for Duet WiFi
      ; General
      G90 ; absolute coordinates
      M83 ; relative extruder moves
      M550 P"CR10S" ; printer name
      M552 S1 ; enable network
      M586 P0 S1 ; enable HTTP
      M586 P1 S0 ; disable FTP
      M586 P2 S0 ; disable Telnet
      M569 P0 S0 ; drive 0 (x-axis) goes backwards
      M569 P1 S0 ; drive 1 (y-axis) goes backwards
      M569 P2 S1 ; drive 2 (z-axis) goes forwards
      M569 P3 S1 ; drive 3 (extruder) goes forwards
      M584 X0 Y1 Z2 E3 ; drive mapping
      M350 X16 Y16 Z16 E16 I1 ; microstepping
      M92 X80 Y80 Z400 E420 ; steps per mm
      M566 X900 Y900 Z12 E120 ; maximum instantaneous speed changes (mm/min)
      M203 X6000 Y6000 Z2000 E1200 ; maximum speeds (mm/min)
      M201 X500 Y500 Z20 E250 ; accelerations (mm/s^2)
      M906 X800 Y800 Z800 E800 I30 ; motor currents (mA) and motor idle factor (%)
      M84 S60 ; idle timeout
      M208 X-30 Y-20 Z-10 S1 ; axis minima
      M208 X280 Y280 Z360 S0 ; axis maxima
      M574 X1 S1 P"xstop" ; active-high x-axis endstop low end
      M574 Y1 S1 P"ystop" ; active-high y-axis endstop low end
      M574 Z1 S1 P"zstop" ; active-high z-axis endstop low end
      M950 S0 C"exp.heater7" ; servo pin 0 for BL Touch
      M558 P9 C"^zprobe.in" ; Z probe type - bltouch
      M558 P9 H5 F120 T6000 ; dive height + speeds
      G31 P500 X25 Y0 Z2.5 ; Z probe trigger value, offset + trigger height
      M557 X25:275 Y-5:285 S50 ; define mesh grid
      ; Bed
      M308 S0 P"bedtemp" Y"thermistor" ; sensor 0 as thermistor on pin bedtemp
      M308 S0 T100000 B4138 ; thermistor resistance and beta value
      M950 H0 C"bedheat" T0 ; output on bedheat and map to sensor 0
      M143 H0 S120 ; bed temperature limit - 120C
      ; Hot-End
      M308 S1 P"e0temp" Y"thermistor" ; sensor 1 as thermistor on pin e0temp
      M308 S1 T100000 B4138 ; thermistor resistance and beta value
      M950 H1 C"e0heat" T1 ; output on e0heat and map to sensor 1
      M143 H1 S280 ; hot-end temperature limit - 280C
      M307 H1 B0 S1.00 ; disable bang-bang and set PWM limit
      M303 H1 S240 ; test
      M912 P0 S-8.7 ; calibrate the MCU temp
      M950 F0 C"fan0" Q500 ; fan 0 on pin fan0 and set its frequency
      M106 P0 S0 H-1 ; thermostatic control is turned off
      M950 F1 C"fan1" Q500 ; fan 1 on pin fan1 and set its frequency
      M106 P1 S1 H1 T45 ; set fan 1 value. thermostatic control is turned on
      M106 P2 T28:65 H100:101:102 ; turn on MCU fan at 30
      T0 ; select first tool
      M122 after shutdown
      M122
      RepRapFirmware for Duet 2 WiFi/Ethernet version 3.0 running on Duet WiFi 1.02 or later
      Board ID: 08DGM-9T6BU-FG3S0-7J9FJ-3SN6L-KS6VG
      Used output buffers: 1 of 24 (10 max)
      Static ram: 30516
      Dynamic ram: 91680 of which 32 recycled
      Exception stack ram used: 224
      Never used ram: 8620
      Tasks: NETWORK(ready,688) HEAT(blocked,1232) MAIN(running,3748) IDLE(ready,156)
      Owned mutexes:
      Last reset 00:00:20 ago, cause: power up
      Last software reset at 2021-02-19 13:46, reason: User, spinning module GCodes, available RAM 8620 bytes (slot 1)
      Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f000 BFAR 0xe000ed38 SP 0xffffffff Task 0x4e49414d
      Error status: 0
      Free file entries: 10
      MCU temperature: min 17.2, current 20.0, max 20.1
      Supply voltage: min 24.0, current 24.0, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes
      Date/time: 2021-02-19 16:40:20
      Cache data hit count 43016209
      Slowest loop: 1.17ms; fastest: 0.09ms
      Hiccups: 0(0), FreeDm: 169, MinFreeDm: 169, MaxWait: 0ms
      === MainDDARing ===
      === AuxDDARing ===
      Heater 1 is on, I-accum = 0.0
      Segments left: 0
      Movement lock held by null
      http is idle in state(s) 0
      telnet is idle in state(s) 0
      file is idle in state(s) 0
      serial is idle in state(s) 0
      aux is idle in state(s) 0
      daemon is idle in state(s) 0
      queue is idle in state(s) 0
      Code queue is empty.
      === Network ===
      Slowest loop: 22.52ms; fastest: 0.00ms
      Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
      HTTP sessions: 1 of 8
      • WiFi -
        Network state is running
        WiFi firmware version 1.22
        WiFi MAC address 84:f3:eb:42:ac:44
        WiFi Vcc 3.46, reset reason Turned on by main processor
        WiFi flash size 4194304, free heap 29408
        WiFi IP address 10.0.0.15
        WiFi signal strength -69dBm, reconnections 0, sleep mode modem
        PeteIHughes
        BTW, the heater cartridge says on it "B30-24v 30W"
        The power supply is a meanwell 24v
        https://www.amazon.com/MEAN-WELL-SE-450-24-Supply-Single/dp/B005T6NNKO/ref=sr_1_17?dchild=1&keywords=MEAN+WELL+24v+20a&qid=1612568396&s=electronics&sr=1-17
        • The Docundefined
          The Doc
          Check the resistance of the cartridge. 30W at 24V should be ~19.2 ohms. If the resistance is a lot lower, you could have a bad cartridge or a short. If the resistance is correct, check the PSU. Put a few amps of load on it and see if it cuts out.
          • alankilianundefined
            alankilian
            I'm thinking your hotend heater is not electrically isolated from the rest of your system.
            • Try disconnecting the heater wires at the DUET and see if you can set a temp.
            • Try reconnecting them, and disconnecting them at the cartridge heater.
            Do you have a meter?
            Turn everything off, unplug, disconnect the heater wires at the Duet and get some Ohm reading from each wire to the Duet's GROUND. (Power-supply ground will be fine.)
              PeteIHughes
              Thanks for the Ideas guys.
              Checked the resistance at 21.6 ohms, so I am guessing that's close enough.
              While checking the PSU, ran into a "small" problem.
              How can I test a few amps of load on it?
              I thought, simple, just connect the heater cartridge directly across it.
              I "probably" should have been testing the 24v side, but no,
              somehow I connected it across 115vac.
              Turns out the heater cartridge probably worked, as it went from
              room temp to white hot in less than a second.
              I'll be ordering a new PSU this weekend.☹
              Looking on the bright side, It was probably that anyway 🙂
              Report back in a few days
              Pete
              The Docundefined 1 Reply Last reply Reply Quote 0
                Trial by fire! 😳
                PeteIHughesundefined 1 Reply Last reply Reply Quote 0
                  PeteIHughes @Phaedrux
                  @Phaedrux Literally!!!
                  Still have a lingering smell of heater cartridge inners.
                  • The Docundefined
                    The Doc @PeteIHughes
                    @PeteIHughes said in Duet Wifi Powers Off when turning on Hot End:
                    Pete
                    I hope it is the PSU and not a MOSFET on the board.
                    Good luck.
