    DWC crashing; repeatedly
    Firmware installation
    8
    37
    4.2k
      When DWC reports an Ajax error, at the bottom of the message box it reports "Error reason:" followed by some text. I want to know what that text is. If it's not there, take a screenshot showing the Ajax message box and post that.
      Also please tell us what version of DWC you are using.
      • Cinproundefined
        Cinpro
        It just did it, and the last line this time says "error reason is timeout" I do not remember seeing this before now other than when I turn the machine off myself.
        • Cinproundefined
          Cinpro
          lots of family things to do, so not much time to play with the printer I'm afraid. Will post a screen of the error next time I get it.
          • Cinproundefined
            Cinpro
            Well the card died, it's bad enough that the SD card format app locks up. I got a new card but can only connect via USB. I emptied the WWW folder and unzipped straight into it using Win zip. The M552 is set as M552 P192.168.1.149 S1. I also tried all Zeros for the address. Internet here is spotty at best due to some recent storms. Will check back when I can thanks.
            • BMMalundefined
              BMMal
              I'm having a similar problem. At first it seemed to only be when I uploaded large files. Then it was even if I put the large file on the SD card first. Now it's I can't upload or put any file on the SD card. The printer will still print from SD if I go through Repetier Host to start it, but the web control is not very useful and seems to be unstable. It gets hung up looking like the below images where it is trying to load gcodes, macros, etc but never does and eventually times out.
              I'm using Chrome Version 59.0.3071.115 (Official Build) (64-bit)
              Duet WiFi 1 + DueX5
              FW 1.18.2 (2017-06-16)
              WiFi Server 1.03 ch fork
              Web Interface 1.15a
              Duet Ethernet - Most likely the most recent Edge firmware
              Duet X5
              7" Panel Due V2
              Cartesian, 4 Nozzles with Flex3Drives, Heated Chamber, Simple Switch Filament Sensing
              • TYPPA Albert Einsteinundefined
                Same for me !!!
                AJAX error
                I have no special talent. I am only passionately curious.
                -Albert Einstein
                • fcwiltundefined
                  fcwilt
                  I occasionally have this problem - it seems to be related to WiFi signal strength.
                  I added an unique SSID to the nearest WiFi access point in my home and used it for my printers and it improved things quite a bit - not perfect but much better.
                  I have been meaning to try placing an WiFi access point in the same room as my printers to what effect, if any, that has on the problem.
                  Is there a G-code to that can be used to display signal strength information?
                    Have you tried increasing the maximum number of AJAX retries? See the screenshot 2 posts above.
                    Series 1.19 firmware includes the WiFi signal strength in the M122 report.
                    • BMMalundefined
                      BMMal
                      @dc42:
                      Mine is set to 10 retries.
                      Duet X5
                      7" Panel Due V2
                        @dc42:
                        M122
                        Network state is running
                        WiFi firmware version 1.19beta9
                        WiFi MAC address 5c:cf:7f:ee:63:dc
                        WiFi Vcc 3.08, reset reason Turned on by main processor
                        WiFi flash size 4194304, free heap 38168
                        WiFi IP address 192.168.1.80
                        WiFi signal strength -59db ?????
                        HTTP sessions: 1 of 8
                        Socket states: 2 0 0 0 0 0 0 0
                        Responder states: HTTP(1) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
                        -Albert Einstein
                        • BMMalundefined
                          BMMal
                          I should add, that eventually the run, download, and delete buttons will show up next to the gcode files. Once this happens, it seems that things go back to normal and I have good stability.
                          Duet X5
                          7" Panel Due V2
                            @TYPPA:
                            @dc42:
                            M122
                            -59db is a good strength. I get -52db from a Duet WiFi about 2m from the router. See https://support.randomsolutions.nl/827069-Best-dBm-Values-for-Wifi.
                            I'll change it to say dBm instead of db in the next firmware, technically db is a relative signal strength.
                              @dc42:
                              @TYPPA:
                              @dc42:
                              M122
                              ok now Maximum number of AJAX retries: is 10 for the moment is not disconnect …. 😉
                              WiFi signal strength -59db / -68db at 8 mt.... 😉
                              -Albert Einstein
                              • BMMalundefined
                                BMMal
                                When I run an SD file from Repetier, the log has a bunch of the below lines in it. I noticed in DWC that the object height, layer height, filament usage, and generated by fields all say "loading." The Macros and System Editor file pages all say loading as well. I have not tested, but I think this started to become an issue when I switched from S3D to the beta of Kisslicer. Is it possibly an issue with the way kisslicer stores its settings in the gcode file or something along those lines? An example file is here: https://pastebin.com/YT10MAgr
                                12:57:56.056 : Request: fileinfo?name=0%3A%2Fgcodes%2F20mmTestCube_repaired.gcode fragment 2147483648
                                Duet X5
                                7" Panel Due V2
                                • BMMalundefined
                                  BMMal
                                  If I try to release the SD card via M22 while this issue is occurring, the console will display the following in DWC:
                                  1:41:01 PMCan't open 0:/gcodes/20mmTestCube.gcode to read, error code 12
                                  Duet X5
                                  7" Panel Due V2
                                    You are the first person I know of to use M22 to release a card! After releasing a card, you must use M21 to mount it again.
                                    Releasing card 0 is not advised because it contains files essential to the operation of the Duet, for example the homing files, macro files, bed.g, heightmap.csv etc.
                                    • BMMalundefined
                                      BMMal
                                      I upgraded the firmware to the new experimental stuff which seems to have improved, if not eliminated, the problem I was having.
                                      The new firmware definitely seems more sensitive to the wifi signal strength. Admittedly, mine is not very good at -69dB with the control box door open and -72dB or not able to connect with it closed. Previously, I rarely had a problem connecting and errors due to signal strength were uncommon enough that it wasn't a problem, even with the door closed.
                                      Duet X5
                                      7" Panel Due V2
                                      • fcwiltundefined
                                        fcwilt
                                        Using an AP (recent model dual radio b/g/n and ac/n) in a nearby room my signal strength by was reported via DWC as -67.
                                        I could stay connected a good while when actively using DWC but if I left for a while and returned it was usually to a disconnect error.
                                        As a test I installed a simple AP (older model single radio b/g only) four feet away from the printer.
                                        The signal strength is now -46 and DWC has remained connected for several hours with no errors as of yet.
                                        Just FYI
                                          It's important that the wifi antenna is not shielded from radio waves. This is especially important if the printer is enclosed. On my delta, I have it poking through a slot in a plastic side panel. That same panel also provides access to the USB connector and SD card, and the LEDEs along that edge of the board can been seen through it.
                                          • MrBlomundefined
                                            MrBlom
                                            also having a lot of problem with wifi and the betas
                                            timo outs or can't connect
                                            start to get very frustrating
                                            Please prioritize this
