Error: bad Command XXX W/RRF 3.2 and leveling issue
Scratch that, it still crashes... I thought testing it ten times was enough but it did it the right after writing the reply. lol
Its so intermittent, its going to make it harder to catch.
@3DPrintingWorld I remember that back off of Y before doing separate motor/endstop homing was causing crashing with mine. It was 5 mm in your config, I lowered it to 2 and never got a crash since
@martin7404 I'm not sure if this is the cause because I'm realizing that its the initial homing of U before it start homing Y where the issue lies. The crash happens while its homing Y but that's because U was not homed properly and is not in the correct position when the Y axis homing starts.
I'm realizing that the issue started to happen when I added the filament sensors which is when I moved the U endstop to the Duex5. I'm going to remove the filament sensors and put the endstop back on the WIFI and see if that fixes the issue.
Thats the issue!!! When I have the endstop on Duex5 I get a crash every 10-20 times, when its on wifi it works perfectly. I'll open a new issue on this but I think its related to the bed leveling issue as well because those motor are also on the duex 5. So is the Tool1 fan that turns on every other time for no reason.
@martin7404 That is looking good! That's a genuine Hiwin rail and bearing with a slight preload?
@3DPrintingWorld yes , they are 3 Types thus is Z0
@3DPrintingWorld said in Error: bad Command XXX W/RRF 3.2 and leveling issue:
You did update to 3.2.2?
Did you verify with M122? I've had occasions where the update seemed to go fine (no errors reported) but nothing actually was updated.
As you may recall I have 3 Z steppers on my Duex 5 along with their associated endstop sensors and 3.2.2 solved all of my problems with regards to missing endstop sensor activation.
@fcwilt Yes, switching to 3.2.2 fixed the issue. I was advised to start another thread because this one got long and contained too many topics. The endtop issue is now fixed, but I still have a issue with the bed leveling to an out of level plane.
So you started a new topic for that issue?
