    Error: bad Command XXX W/RRF 3.2 and leveling issue
    147
    10.3k
    • martin7404undefined
      martin7404 @Guillaume G.
      @Guillaume-G
      I fail to understand the logic in M669
      Muldex IDEX Duet2+Duex5
      Custom CoreXY 600x400 Hemera , Duet3+Toolboard+1HCL closed loop
      Sapphire Pro with Duet2, with closed-loop motors
      custom high temp E3D tool changer with Duet2+Duex
      Guillaume G.undefined 3DPrintingWorldundefined 2 Replies Last reply Reply Quote 0
      • Guillaume G.undefined
        Guillaume G. @martin7404
        @martin7404
        Yes I took me some time to understand the matrix concept the M669 description refers to.
        I use
        M669 K0 Y1:1:0:1
        K0 is for Cartesian
        The rest is about which axis interacts with which.
        On the Muldex, Y movement causes X and U to move with a ratio of 1 and the other axes movements are considered independent.
        This should speak better than words:
        martin7404undefined 3DPrintingWorldundefined 4 Replies Last reply Reply Quote 0
          @Guillaume-G Thank you Now I understand
          • 3DPrintingWorldundefined
            3DPrintingWorld @martin7404
            @martin7404 said in Error: bad Command XXX W/RRF 3.2 and leveling issue:
            I did not understand the logic either. I found it defined on the forum somewhere but it did not work for me as written so I swamped the numbers around until it worked... I was hoping that I was not going to have to admit that.😉
              3DPrintingWorld @Guillaume G.
              @Guillaume-G Thanks for that, I studied the documentation for a while but could not understand it, now I do. I'll remove the negative.
                @Guillaume-G
                I found the original topic. You can see that DC has a negative number in the M669 he suggest for the user to use as well.
                https://forum.duet3d.com/topic/7796/haq-xy/17?_=1614288039698
                  3DPrintingWorld @Phaedrux
                  @Phaedrux I plan on moving to a new thread and only cover one topic, I just wanted to try a couple things before I do but I have not had the chance.
                    @Guillaume-G said in Error: bad Command XXX W/RRF 3.2 and leveling issue:
                    I use
                    M669 K0 Y1:1:0:1
                    Gui, I was able to remove the negative by reversing the direction of both Y motors. Thanks!
                    martin7404undefined 1 Reply Last reply Reply Quote 0
                      martin7404 @3DPrintingWorld
                      @3DPrintingWorld Noted I will follow
                      BTW today assembled the original HIWIN MGN9Z0 ( by book it is 0 tolerance rail to balls) rail on the 2020 extrusion. I mounted the new carriage with 2 bolts and there is No play at all compared to LDO MGN9 that have. OF course, the real test will be when I swap the whole thing into the printer
                        3DPrintingWorld @3DPrintingWorld
                        @3DPrintingWorld said in Error: bad Command XXX W/RRF 3.2 and leveling issue:
                        G1 H2 X5 U-5 F7500 ; go back a few mm
                        I think I resolved the issue with the "Probe was not triggered" error. When I split the Y axis and home it to two different switches, this movement causes the U axis to move towards the endstop. I think if the Y axis is to much out of skew when the homing starts, it would cause the U axis to already be past the endstop switch.
                        My guess is I only saw this issue when I uploaded changes to the config was because I recycled power which would allow the y-axis to relax and skew.
                        I changed the line above to G1 H2 X5 U-10 F7500, and have not had it happen yet.
                        3DPrintingWorldundefined 1 Reply Last reply Reply Quote 0
                          Scratch that, it still crashes... I thought testing it ten times was enough but it did it the right after writing the reply. lol
                          Its so intermittent, its going to make it harder to catch.
                            @3DPrintingWorld I remember that back off of Y before doing separate motor/endstop homing was causing crashing with mine. It was 5 mm in your config, I lowered it to 2 and never got a crash since
                              @martin7404 I'm not sure if this is the cause because I'm realizing that its the initial homing of U before it start homing Y where the issue lies. The crash happens while its homing Y but that's because U was not homed properly and is not in the correct position when the Y axis homing starts.
                              I'm realizing that the issue started to happen when I added the filament sensors which is when I moved the U endstop to the Duex5. I'm going to remove the filament sensors and put the endstop back on the WIFI and see if that fixes the issue.
                                3DPrintingWorld
                                Thats the issue!!! When I have the endstop on Duex5 I get a crash every 10-20 times, when its on wifi it works perfectly. I'll open a new issue on this but I think its related to the bed leveling issue as well because those motor are also on the duex 5. So is the Tool1 fan that turns on every other time for no reason.
                                  martin7404
                                  So last post here.
                                  mounted Hiwin MGn9Z0 and there is no play in a carriage at all.
                                    @martin7404 That is looking good! That's a genuine Hiwin rail and bearing with a slight preload?
                                      @3DPrintingWorld yes , they are 3 Types thus is Z0
                                      • fcwiltundefined
                                        fcwilt @3DPrintingWorld
                                        You did update to 3.2.2?
                                        Did you verify with M122? I've had occasions where the update seemed to go fine (no errors reported) but nothing actually was updated.
                                        As you may recall I have 3 Z steppers on my Duex 5 along with their associated endstop sensors and 3.2.2 solved all of my problems with regards to missing endstop sensor activation.
                                          3DPrintingWorld @fcwilt
                                          @fcwilt Yes, switching to 3.2.2 fixed the issue. I was advised to start another thread because this one got long and contained too many topics. The endtop issue is now fixed, but I still have a issue with the bed leveling to an out of level plane.
                                          • fcwiltundefined
                                            So you started a new topic for that issue?
