    Manual Bed Levelling & Mesh Levelling on a corexy printer?
    1.9k
    • fcwiltundefined
      fcwilt @natty15d
      @natty15d said in Manual Bed Levelling & Mesh Levelling on a corexy printer?:
      @fcwilt should z be set at 0 or - 99999?
      So if I set it up correctly and run the g32 command the print bed will go to zero, then the print head moves to the 1st set point and I level the bed with the corresponding screw, accept when level and the print head moves to the next set point?
      If this is what happens why does it have to be split between the config.g and bed file instead of a macro?
      Sorry for all the questions, this level of printer control is new to me and still getting to grips with everything the duet has to offer
      I prefer to have X=0 Y=0 at the center of my bed. So the ranges for my X and Y axes, as set in my config file, are -150 to +150.
      Here is the essence of my bed.g file:
      G1 X{-sensors.probes[0].offsets[0]}, Y{-sensors.probes[0].offsets[1]}, F6000 ; move probe to center of bed
      G30                              ; probe bed and set Z=0 datum
      M671 X-160:-160:160  Y-160:160:0 ; specify where bed leveling adjustment screws are located
      G30 P0 X-130 Y-130  Z-99999      ; probe near adjusting screw #1 (left front  )
      G30 P1 X-130 Y130   Z-99999      ; probe near adjusting screw #2 (left rear   )
      G30 P2 X130  Y0     Z-99999 S3   ; probe near adjusting screw #3 (right middle) and compute results
      To invoke bed.g I execute G32 from the DWC.
      The results of probing the bed are displayed AFTER the probing is complete. Then I use the instructions contained in the results and adjust each screw as best I can.
      I then repeat G32 as many times as it takes to get things perfect.
      You cannot do this in config.g as the required conditions do not exist until after config.g is executed.
      You should not attempt to perform ANY motions commands in config.g.
      natty15dundefined 1 Reply Last reply Reply Quote 0
      • natty15dundefined
        natty15d @fcwilt
        @fcwilt so m671 can be added to the bed file rather than the config.g file?
        Would that same coding work if added as a macro rather than added to the bed file?
        That way I wouldn't have to remember g32 to activate it as the macro has a dedicated on screen button nothing needs to be saved as the bed is levelled manually by using the screws?
        • fcwiltundefined
          fcwilt @natty15d
          Yes - there are many things that most folks put into the config.g file that I put in other macros to keep related commands together.
          It most likely would but then the G32 command would not work.
          If you want a dedicated macro button just create one with a G32 command and use bed.g as intended.
          That way the DWC menu command True Bed Leveling works as well as your macro button.
          And if for some reason G32 does something behind the scenes that we are not aware of everything will still work.
          • natty15dundefined
            natty15d @fcwilt
            @fcwilt thank you that's a massive help, will try that out tomorrow and let you know how it goes
            • natty15dundefined
              natty15d
              Setting up the Manual Bed Leveling Assistant (MBLA)
              Measured the printer today and have located all the screws relative to Home position 0,0 which is Front Left on my CoreXY.
              I've listed the screws in config.g in order Rear Left, Rear Right, Front Right & Front Left
              ; generated by RepRapFirmware Configuration Tool v3.1.4 on Wed Nov 04 2020 17:51:25 GMT+0000 (Greenwich Mean Time)
              M550 P"Eniac40" ; set printer name
              M669 K1 ; select CoreXY mode
              M671 X-34:413:413:-34 Y434:434:13:13 P0.5 ; 1screwRL(-34,434), 2screwRR(413,434), 3screwFR(413,13), 4screwFL(-34,13), thread pitch 0.5mm
              M552 S1 ; enable network
              M586 P0 S1 ; enable HTTP
              M586 P1 S0 ; disable FTP
              M586 P2 S0 ; disable Telnet
              M569 P2 S0 ; physical drive 2 goes backwards
              M92 X80.24 Y80.24 Z399.44 E412.00 ; set steps per mm
              M566 X900.00 Y900.00 Z60.00 E3000.00 ; set maximum instantaneous speed changes (mm/min)
              M203 X15000.00 Y15000.00 Z720.00 E15000.00 ; set maximum speeds (mm/min)
              M201 X1000.00 Y1000.00 Z100.00 E5000.00 ; set accelerations (mm/s^2)
              M906 X1700 Y1700 Z1700 E680 I30 ; set motor currents (mA) and motor idle factor in per cent
              M84 S30 ; Set idle timeout
              M208 X380 Y423 Z405 S0 ; set axis maxima
              M574 X1 S1 P"!xstop" ; configure active-high endstop for low end on X via pin !xstop
              M574 Y1 S1 P"!ystop" ; configure active-high endstop for low end on Y via pin !ystop
              M574 Z1 S1 P"!zstop" ; configure active-high endstop for low end on Z via pin !zstop
              M558 P0 H2 F120 T15000 ; disable Z probe but set dive height, probe speed and travel speed
              M308 S0 P"bedtemp" Y"thermistor" T100000 B4092 ; configure sensor 0 as thermistor on pin bedtemp
              M307 H0 A84.5 C94.6 D0.7 S1.00 V11.9 B0 ; PID heated bed
              M143 H0 S80 ; set temperature limit for heater 0 to 80C
              M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin e0temp
              M307 H1 A298.1 C175.7 D3.8 S1.00 V11.8 B0 ; PID hotend heater
              M950 F2 C"fan2" Q500 ; create fan 2 on pin fan2 and set its frequency
              M106 P2 S1 H1 T180 ; set fan 2 value. Thermostatic control is turned on
              M591 D0 P2 C"e0_stop" S1 ; filament monitor connected to E0_stop
              T0 ; select first tool
              Then in bed.g i listed the probe points in the same order RL, RR, FR, FL. I also added M561 to clear any previous settings, & deactivated M401 & M402 as i dont have a z probe and want to use the 4 manual levelling screws to adjust the bed hieght, is that the right thing to do?
              ; bed.g
              ; G29 ; probe the bed and enable compensation
              G28 ; home
              ; M401 ; deploy Z probe (disabled)
              G30 P0 X87 Y314 Z-99999 ; probe near an adjusting screw RL
              G30 P1 X293 Y314 Z-99999 ; probe near an adjusting screw RR
              G30 P2 X293 Y110 Z-99999 ; probe near an adjusting screw FR
              G30 P3 X87 Y110 Z-99999 S4 ; probe near an adjusting screw FL and report adjustments needed
              ; M402 ; retract probe (disabled)
              Does that look like a useable Config.g & Bed.g or have i missed anything?
              Nathan
              • fcwiltundefined
                fcwilt
                Are those probe points as close to the adjustment screws as you can get?
                natty15dundefined 2 Replies Last reply Reply Quote 0
                • natty15dundefined
                  natty15d @fcwilt
                  @fcwilt using those positions gives me a large level area covering roughly 3/5ths of the glass and is big enough for 99% of what I print. This means I don't have to run a mesh levelling routine to compensate for any uneveness.
                  If I level at the extremes then only the outer front and rear edges are printable and the centre section is too high and I'd have to use mesh compensation all the time when I just want to use it for very occasional prints
                  • natty15dundefined
                    natty15d @fcwilt
                    @fcwilt Just a thought, could I set the following as a macro and use it for regular sized prints that don't need mesh bed compensation
                    ; macro to perform manual bed levelling assistance
                    ; Preheat PLA
                    M140 S60;
                    M104 S180 T0;
                    G28 ; home
                    Then have my bed.g file, that i'd activate with G32, with a different set of probe co-ordinates closer to the edge, and then follow that up with mesh bed compensation?
                    • fcwiltundefined
                      fcwilt
                      Have you done anything with the conditional gcode feature of v3 firmware?
                      I use it to control things like choosing between mesh compensation being enabled or not at the start of a print.
                      Since v3 doesn't currently have variables I used dummy fan names as a text variable that I could set and test.
                      If you would like I could give you the details.
                      natty15dundefined 1 Reply Last reply Reply Quote 1
                      • natty15dundefined
                        natty15d @fcwilt
                        @fcwilt No I haven't read up on those
                        I have the code ready and will try it tomorrow morning but worried I'm going to damage my printer if i mess this code up or it doesn't do what I think it'll do
                        How i want it to operate is run G32,
                        the print head will move to P0 and the bed will hit the mechanical end stop and stop at "0"
                        then i adjust the screw on the bed corner to allow a sheet of paper to just pass between the bed and the nozzle, then tell the printer to move to the next point and so on till all four corners are level
                        Is this what will happen with this code?
                        ; bed.g
                        G28 ; home
                        • fcwiltundefined
                          fcwilt @natty15d
                          ; bed.g
                          G28 ; home
                          No it doesn't work that way.
                          It will probe all for points first and then calculate the required adjustments and display them.
                          At least that is how it works with an actual Z probe.
                          Have you considered getting one for your printer?
                          • natty15dundefined
                            natty15d @fcwilt
                            @fcwilt Thought about it but only need it for prints that take up the entire bed which for me is rare, and it'll add extra weight the carriage.
                            Came across a post by @Phaedrux who did something very close to what i want to do so I've altered it to this
                            ; macro to perform manual bed levelling assistance to the centre of the bed only for regular prints
                            ; Preheat PLA
                            M140 S60;
                            M104 S180 T0;
                            G28 X ; home X
                            G28 Y ; home Y
                            G28 Z ; home Z
                            ; Move nozzle to leveling points and prompt user to level bed at each point
                            M291 P"Nozzle will now move to the 4 leveling points RL, RR, FR & FL." S1 T2
                            ; Move to Rear Left leveling point P0
                            G1 Z5 ; move to z5 for travel
                            G1 X87 Y314 ; Move to rear left corner
                            G1 Z0 ; move to z0 to level the bed
                            M400
                            M291 P"Adjust RL using a piece of paper, when set click Confirm to go to RR" R"CONFIRM" S2 Z0
                            ; Move to Rear Right leveling point P1
                            G1 X293 Y314 ; Move to rear right corner
                            M400
                            M291 P"Adjust RR using a piece of paper, when set click Confirm to go to FR" R"CONFIRM" S2 Z0
                            ; Move to Front Right leveling point P2
                            G1 X293 Y110 ; Move to front right corner
                            M400
                            M291 P"Adjust FR using a piece of paper, when set click Confirm to go to FL" R"CONFIRM" S2 Z0
                            ; Move to Front Left leveling point P3
                            G1 X87 Y110 ; Move to front left corner
                            M400
                            M291 P"Adjust FL using a piece of paper, when set click Confirm" R"CONFIRM" S2 Z0
                            ; Move Z
                            G1 Z50 ; Drop bed to z50 for nozzle clearance
                            M291 P"The bed has been mechanically leveled" S2
                            • fcwiltundefined
                              fcwilt @natty15d
                              That might work. You may have to run it more than once.
                              The actual Manual Bed Leveling Assistant (which works best with a Z probe) takes into account how each adjustment screw will interact with the others and the suggested adjustments reflect that.
                              • natty15dundefined
                                natty15d @fcwilt
                                @fcwilt Just created a second one to level the entire bed, then ill follow that up with Mesh Bed Compensation. That's going to be another head scratcher LOL
                                ; macro to perform manual bed levelling assistance to the Entire bed for large prints
                                ; Preheat PLA
                                M140 S60;
                                M104 S180 T0;
                                G28 X ; home X
                                G28 Y ; home Y
                                G28 Z ; home Z
                                G1 X40 Y372 ; Move to rear left corner
                                M400
                                G1 X340 Y372 ; Move to rear right corner
                                M400
                                G1 X340 Y52 ; Move to front right corner
                                M400
                                G1 X40 Y52 ; Move to front left corner
                                M400
                                ; Move Z
                                M291 P"The entire bed has been mechanically leveled, now perform Mesh Bed Compensation" S2
                                  That macro worked well for me because I can easily visually see how close the nozzle is to the bed so a tiny adjustment to the screw is needed and it stays put for a long time. I have it do two passes of the 3 screws and it's enough for me. YMMV
                                  • natty15dundefined
                                    natty15d @Phaedrux
                                    @Phaedrux @fcwilt thank you for your assistance, with your help i've managed to setup the printer with manual bed levelling and no sensor, tested it, tweaked and its now good to go 🙂
                                    fcwiltundefined natty15dundefined 2 Replies Last reply Reply Quote 1
                                    • fcwiltundefined
                                      fcwilt @natty15d
                                      @natty15d
                                      Very glad to hear you got it working.
                                      If you get tired to doing it manually a 8mm inductive sensor like mine only weighs 43 grams. I would imagine your existing extruder assembly weighs a good deal more than that.
                                      • natty15dundefined
                                        natty15d @natty15d
                                        @Phaedrux @fcwilt I used Mesh Bed Compensation for the first time and it worked perfectly. What id like to know is now that I've switched the printer off, when i turn it back on is the MBC still on or do i have activate it with G29 S1.
                                        Is there a way to see if the MBC is active or inactive on the paneldue or web interface?
                                        Thanks
                                        Nathan
                                        • fcwiltundefined
                                          fcwilt @natty15d
                                          The height map you created with G29 or G29 S0 is saved and can be re-loaded at any time with G29 S1.
                                          But you do have to re-load it. I do it at the start of each print and unload it at the end of each print as it really serves no purpose when you are not printing.
                                          All slicers that I have used have a way to execute user created gcode.
                                          My approach is to have a macro called print_begin.g and another called print_end.g.
                                          In the slicer I have M98 P"print_begin.g" and M98 P"print_end.g" in the appropriate places the slicer provides for entering user code.
                                          The macros do everything required to prepare to start a print or finish up at the end of a print.
                                            https://duet3d.dozuki.com/Wiki/Using_mesh_bed_compensation
