DWC 3.1.1
Duet Web Control
6.1k
    luca Massimiliano
    DWC 3.1.1 not compatible only javaScript000000000000000000000000000.JPG but displays only a and a bed if I deactivate it it displays everything ok bed plus two heaters, but it is not possible to use it all buttons blockedSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSS.JPG thank you is there a solution ?
      jay_s_uk
      thats not DWC 3.1.1
        luca Massimiliano
        TI RINGRAZIO , MA MI TROVO INDIFFICOLTA' A RICONOSCERE LA VERSIONE VISTA.JPG E EVIDENTE HO ERRATO NELLISATLLAZIONE
          jay_s_uk
          you need to install this. https://github.com/Duet3D/DuetWebControl/releases/download/v3.2.2/DuetWebControl-SD.zip
          best thing to do is delete the contents www folder from the sd and then unzip the contents of the above zip file into the www folder.
          also you should update from 3.2 to 3.2.2
          undefined 1 Reply Last reply 9 Mar 2021, 13:26 Reply Quote 0
            luca Massimiliano @jay_s_uk
            TI RINGRAZIO MOLTISSIMO , ORA NON POSSO FARLO PER IMPEGNO INDEROGABILE ,MA FRA 2 ORETTE CI PROVO , E TI OGGIONO SULLA RISOLUZIONE GRAZIE
              luca Massimiliano
              ti chiedo perdono, ho provato solo ora, mi ha dato questo erroreYour Duet rejected the HTTP request: page not found
              Check that the SD card is mounted and has the correct files in its /www folder proverò a rricipiare lo direttory www con il tua procedura
                jay_s_uk
                @luca-Massimiliano said in DWC 3.1.1:
                sounds like you didnt extract the contents into the www folder
                  Extract the contents of this zip file into the /www folder on your SD card.
                  The error means that it can't find the DWC files.
                  The www folder should contain this:
                  └── www
                  ├── css
                  │ ├── Lumen.theme.css.gz
                  │ ├── Sandstone.theme.css.gz
                  │ ├── Slate.theme.css.gz
                  │ ├── Superhero.theme.css.gz
                  │ ├── United.theme.css.gz
                  │ ├── bootstrap.theme.css.gz
                  │ └── dwc.css.gz
                  ├── favicon.ico.gz
                  ├── fonts
                  │ ├── glyphicons.eot.gz
                  │ ├── glyphicons.svg.gz
                  │ ├── glyphicons.ttf.gz
                  │ ├── glyphicons.woff.gz
                  │ └── glyphicons.woff2.gz
                  ├── html404.htm
                  ├── js
                  │ └── dwc.js.gz
                  ├── language.xml.gz
                  └── reprap.htm.gz
                    luca Massimiliano
                    Si l ho fatto ma devo verificare se tutto ok . sono sicuro che il procedimento indicato da te carissimo amico sia giusto , devo solo metterlo in pratica . ti ringrazio molto appena sarò sicuro ti do la conferma della nuovo dwc grazie buona serata.
                      luca Massimiliano
                        With the SD card in the Duet send M122 and report the results here.
                          luca Massimiliano
                          )1)non posso dare nessun comando .
                          quando estraggo il file zip dopo aver cancellato tutto ,non compare file dwc.json erore solito e' nessuna applicazione e concesso di usare la porta.
                          )2) se estraggo il file zip previa svuotamento www rimane la versione precedente
                            luca Massimiliano
                            )2) se estraggo il file zip senza svuotamento www rimane la versione precedente
                              luca Massimiliano
                              posso fare m122 versione senza dwc3.1.1
                                luca Massimiliano
                                7f70f20f-bdc6-4d7c-ac1d-6a0fcf55ebd2-image.png lo ripete ciclo for nest una chiamata indirizzo diverso dall'attuale . scusatemi
                                  luca Massimiliano
                                  difetti scheda improbabile
                                  difetto ssd comprata nuova ieri pari alla vecchia
                                  mi rimane la procedura ma identica alla vostra consigliata
                                  problemi sistema operativo ,preciso originale .
                                  chiedo aiuto se avete un caso analogo. grazie sempre gentilissimi
                                    When connected to USB terminal, send M122 and share the results here so we can see what it says about the SD card.
                                    undefined 3 Replies Last reply 11 Mar 2021, 19:17 Reply Quote 0
                                      luca Massimiliano @Phaedrux
                                      PRIMA DELL AGGIORNAMENTO
                                      M122
                                      RepRapFirmware for Duet 2 WiFi/Ethernet version 3.2 running on Duet WiFi 1.02 or later
                                      Board ID: 08DGM-917NK-F23T0-6JTD0-3S46T-TGA0F
                                      Used output buffers: 3 of 24 (16 max)
                                      Static ram: 23460
                                      Dynamic ram: 72904 of which 0 recycled
                                      Never used RAM 15716, free system stack 189 words
                                      Tasks: NETWORK(ready,221) HEAT(blocked,309) MAIN(running,452) IDLE(ready,19)
                                      Owned mutexes: WiFi(NETWORK) HTTP(MAIN)
                                      Last reset 00:02:07 ago, cause: power up
                                      Last software reset at 2021-02-17 13:39, reason: User, GCodes spinning, available RAM 15680, slot 2
                                      Error status: 0x00
                                      Aux0 errors 71,71,71
                                      MCU temperature: min 32.1, current 35.6, max 36.0
                                      Supply voltage: min 11.3, current 11.4, max 11.5, under voltage events: 0, over voltage events: 0, power good: yes
                                      Driver 0: position 62571, standstill, SG min/max not available
                                      Driver 1: position 62571, standstill, SG min/max not available
                                      Driver 2: position 62571, standstill, SG min/max not available
                                      Driver 3: position 0, standstill, SG min/max not available
                                      Driver 4: position 0, standstill, SG min/max not available
                                      Driver 5: position 0
                                      Driver 6: position 0
                                      Driver 7: position 0
                                      Driver 8: position 0
                                      Driver 9: position 0
                                      Driver 10: position 0
                                      Driver 11: position 0
                                      Date/time: 2021-03-11 20:14:51
                                      Cache data hit count 156303538
                                      Slowest loop: 7.39ms; fastest: 0.20ms
                                      === Storage ===
                                      Free file entries: 10
                                      SD card longest read time 3.7ms, write time 0.0ms, max retries 0
                                      === MainDDARing ===
                                      === AuxDDARing ===
                                      Segments left: 0
                                      Movement lock held by null
                                      HTTP is ready with "M122 " in state(s) 0
                                      Telnet is idle in state(s) 0
                                      File is idle in state(s) 0
                                      USB is idle in state(s) 0
                                      Aux is assembling a command in state(s) 0
                                      Trigger is idle in state(s) 0
                                      Queue is idle in state(s) 0
                                      LCD is idle in state(s) 0
                                      Daemon is idle in state(s) 0
                                      Code queue is empty.
                                      === Network ===
                                      Slowest loop: 29.58ms; fastest: 0.00ms
                                      HTTP sessions: 1 of 8
                                      • WiFi -
                                        Network state is active
                                        WiFi firmware version 1.25
                                        WiFi MAC address 84:0d:8e:b3:ae:3e
                                        WiFi Vcc 3.42, reset reason Turned on by main processor
                                        WiFi flash size 4194304, free heap 24912
                                        WiFi IP address 192.168.178.105
                                        WiFi signal strength -74dBm, mode 802.11n, reconnections 0, sleep mode modem
                                        Clock register 00002002
                                        Socket states: 0 2 0 0 0 0 0 0
                                        DOPO AGGIORNAMENTO
                                        20:18:53M122
                                        Used output buffers: 7 of 24 (10 max)
                                        Static ram: 23460
                                        Never used RAM 15716, free system stack 199 words
                                        Tasks: NETWORK(ready,245) HEAT(blocked,307) MAIN(running,466) IDLE(ready,19)
                                        Last reset 00:00:23 ago, cause: power up
                                        Error status: 0x00
                                        Aux0 errors 18,18,18
                                        MCU temperature: min 32.0, current 35.1, max 35.5
                                        Date/time: 2021-03-11 20:18:50
                                        Cache data hit count 27845843
                                        Slowest loop: 14.50ms; fastest: 0.20ms
                                        === Storage ===
                                        SD card longest read time 0.9ms, write time 0.0ms, max retries 0
                                        === MainDDARing ===
                                        === AuxDDARing ===
                                        Segments left: 0
                                        === Network ===
                                        Slowest loop: 28.05ms; fastest: 0.00ms
                                        Responder states: HTTP(0) HTTP(2) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions
                                        • WiFi -
                                          WiFi flash size 4194304, free heap 25680
                                          Socket states: 4 4 0 0 0 0 0 0
                                        undefined 1 Reply Last reply 11 Mar 2021, 19:32 Reply Quote 0
                                          E' UTILE PER CAPIRE?
                                          4 out of 114
